Old 02-28-2007, 11:50 PM   #7396
RLS
RLS's Avatar
My fiance asked me what I wanted for my Birthday. I told her I wanted a Novak GTB and that they're roughly the same price everywhere. She went online to Stormer to buy the Novak, read their homepage and bought me the Black Cyclone instead. She may not know much about RC but she knows a bargain when she sees one.
The car looks solid and from what I've read so far I only need to upgrade the bumper, diff screws, ball studs, and bones and pick up some extra steering blocks and I should be set. Can't wait to get it to the track.
RLS is offline   Reply With Quote
Old 03-01-2007, 12:14 AM   #7397
Trader Rating: 46 (100%+)
You won't be disappointed! I wondered why I did not buy the car earlier. Now I am thinking to keep the WCE order from tower or just to get another black version cyclone.
Yellowtaro is offline   Reply With Quote
Old 03-01-2007, 04:04 AM   #7398
BrainTeased's Avatar
Originally Posted by schreff
The only part on the car that seems to break easily is the steering block. It even takes a decent hit to break that too. Not using the small plastic bearing crush helps. If you do use that bearing crush, hitting something hard enough will usually break a steering block into 3 or more pieces.
what is the purpose of leaving in those bearing crush spacers?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 03-01-2007, 08:05 AM   #7399
stephen hilton's Avatar
Default mip driveshafts
hey guys just picked up some mip's what shims do you guys run on the end of them ie the ones the go in between the bearing and the pin?
also what spacers do you run on the one-way's i am currently runnin cop sil
on each side but it seems like there aint enought play?
cheers t.k.
stephen hilton is offline   Reply With Quote
Old 03-01-2007, 11:51 AM   #7400
dstyles's Avatar
Originally Posted by karlo511
the fastener-express ones match pretty well....
what servo is that? does it hang over by a lot?
dstyles is offline   Reply With Quote
Old 03-01-2007, 12:02 PM   #7401
Airtronics 94360
Tony Vega is offline   Reply With Quote
Old 03-01-2007, 12:05 PM   #7402
free2day77's Avatar
other than adding foams, and the obvious oil/spring changes, is there anything this car needs to run on carpet? There are other cars that need shock tower changes, some kind of chassis change etc to run well on carpet, so thats why I am asking.
Stormer Hobbies has these onsale for 199 and I am thinking of getting one.
free2day77 is offline   Reply With Quote
Old 03-01-2007, 12:19 PM   #7403
karlo511's Avatar
it's a Sanwa ERG-VRX = Airtronics 94360
karlo511 is offline   Reply With Quote
Old 03-01-2007, 12:49 PM   #7404
Does anyone of you have lweb inks to the titanium ball stud that some of you recommend using? Also, what is the part number is the diff screw that I should upgrade to? Thanks.
Old 03-01-2007, 01:08 PM   #7405
2-Bad's Avatar
Trader Rating: 24 (100%+)
Square website:
http://translate.google.com/translat...005-08,DVXA:en
Part numbers are:
Square SHP-11AX Titanium ball studs (4pcs/Replacement for 75115)
Square SHP-11BX Titanium ball studs (4pcs/Replacement for 75116)
I bought mine from Champ RC
http://rc-champ.co.jp/
As for the diff screw... there are only 2 types, the standard one (73522), and the titanium nitrided one (61089). "BOTH" can and will snap if the diff is not built correctly.
Hope this helps,
Peter
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 03-01-2007, 01:28 PM   #7406
cheers t.k.
Old 03-01-2007, 02:09 PM   #7407
2-Bad's Avatar
cheers t.k.
Replace that avatar and I'll tell you....
Old 03-01-2007, 02:19 PM   #7408
Team Speedy's Avatar
Trader Rating: 42 (100%+)
Wise investments might be,
1) BMI chassis around $145
2) Corally/Xray springs for carpet
3) 6* C-hubs
4) Ae Diff screw or a tit. one if you luck
5) Front Diff and a locked center pully along with shaft.
About all you need...
RcAmerica | Xray | Hudy | Motiv | Orca | Sanwa |
Team Speedy is offline   Reply With Quote
Old 03-01-2007, 02:47 PM   #7409
RC MARKET's Avatar
Originally Posted by 2-Bad
Square website:
Part numbers are:
Hope this helps,
Peter
or choice 3 racing cheaper !
RC MARKET is offline   Reply With Quote
Old 03-01-2007, 03:07 PM   #7410
Skill's Avatar
Yep, I've been using the 3Racing titanium ball studs on the steering knuckles and servo saver for a few meetings now and had no problems, seems to be a pretty good quality.
For the short ball studs I use Schumacher ones, I've found that these have been very strong.
Skill is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
