Old 02-28-2007, 01:15 PM   #7381
schreff's Avatar
Send a message via AIM to schreff
Hey guys, on a lighter side of things... I see these pics of Andy's car on the TITC thread and I see these nice purple screws.
Any idea where to get them? They match the car perfectly.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 02-28-2007, 01:17 PM   #7382
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
that's worth at least a teenth or 2 per lap
Old 02-28-2007, 01:18 PM   #7383
schreff's Avatar
Damn skippy.
-Jason Schreffler-
Old 02-28-2007, 01:21 PM   #7384
Super Moderator
Marcos.J's Avatar
Damn skippy.
thats what i need then
Old 02-28-2007, 01:39 PM   #7385
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking Cyclone MTF?
Fellow Cycloners: I have been experimenting with the rear CF brace of the Cyclone, the one that goes over the middle shaft where the Spur gear goes on...well, since the bulk heads are split on the CYclone, and what binds them together is that brace, maybe by just using just 2 screws instead of the 4 or 6, it might allow a bit more flex/traction at the rear, like the Xray MTF deal...I have tried it now, and with only 2 screws, I get a bit of understeer at front. I then use all 6, and the understeer goes away...hmmmm...it seems that with only 2 screws you get more flex/rear grip, thus a bit of push up front- with the full 6, then ints back to the original setting and reaction...has anyone given this a try?
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 02-28-2007, 01:42 PM   #7386
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
You shouldnt remove screws from this top plate. The 4 big ones are necessary to connect the 2 bulkheads together and the 2 small ones are just for extra support.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 02-28-2007, 02:05 PM   #7387
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Schreff try here I think this might be it
http://www.fastener-express.com/inde...S&Category=218
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 02-28-2007, 02:15 PM   #7388
Phil C's Avatar
Im fairly sure they are made by square, Ive just ordered a load from rc-mushroom and am awaiting the delivery. I know someone whos had some before and they do match the car perfectly.
Here are the 3x8mm ones for the topdeck etc.
http://rc-mushroom.com/product_info....oducts_id=4969
Hope this helps,
Phil.
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 02-28-2007, 02:40 PM   #7389
Super Moderator
Marcos.J's Avatar
you might want to work on your set up instead of removing the screws from the rear brace
Old 02-28-2007, 03:50 PM   #7390
schreff's Avatar
Hope this helps,
Phil.
Thanks Phil.
Now the main question is... Are they aluminum or Titanium?
For 3.30 for 4, they better be Titanium.
-Jason Schreffler-
Old 02-28-2007, 04:13 PM   #7391
Stew Noble's Avatar
Thanks Phil.
Aluminium, its lighter
// S N F //
Stew Noble is offline   Reply With Quote
Old 02-28-2007, 06:58 PM   #7392
Send a message via AIM to Carpetracer92
Wow thats nice but do you think belt is better then shaft?
Check out Long Island Low N Slow
Garage= Slammed g37,Full Exhaust
Carpetracer92 is offline   Reply With Quote
Old 02-28-2007, 08:53 PM   #7393
karlo511's Avatar
the fastener-express ones match pretty well....
karlo511 is offline   Reply With Quote
Old 02-28-2007, 09:02 PM   #7394
losi09's Avatar
Send a message via Yahoo to losi09
The Cyclone is a great car that is suited for good driving skills. If you are hitting things or getting hit, the car will break, since its a bit weak in some areas. To make it strong, you need to get the following, especially if you run modified type motors: get titanium ball studs for the rear hub camber links. The stock ones tend to snap if hit hard, and it will ruin a perfectly fine Hub, since half the ball stud screw is stuck inside and there's no way of getting it out. The stock bones are also a bit fragile, and tend to bend quite easily. Get the heavy duty steel ones, or get the version 2 dog bones, which are bit beefier and stronger. Also, the rear diff- you must tighten it correctly, or you'll be pulling your hair out rebuilding it due to snapping diff screws or meltdowns...other than that, the Cyclone is great. All those issues are non-issues with the Hara and WCE kits, but you can can always upgrade parts and make them as strong and reliable as the WCE. Hope that helps...
Ok Cool thanks for the info yeah that will help me out a lot with the car.
losi09 is offline   Reply With Quote
Old 02-28-2007, 10:09 PM   #7395
rc-zombies's Avatar
just don't use those aluminum screws on lower chassis..especially the bulkheads, suspension mounts or high stress areas.... wounce they break..it's a pain to get them out. the pros only use aluminum screws on the upper deck.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
