Old 02-22-2007, 08:42 PM   #7276
Super Moderator
Marcos.J's Avatar
Trader Rating: 167 (100%+)
Originally Posted by dodgeguy
Does anyone know when using the fixed center gear. Do I really need the fixed shaft? Does 3 racing make one?
Which spool is the best?
BMI spool
Old 02-23-2007, 02:28 AM   #7277
Capt.Micro's Avatar
The fixed shaft has a 3rd flat spot so you can tighten the set screw for the pully on a flat. If you try to use the one-way pully shaft with the fixed pully, there is a good chance the pully will slip on the shaft under power.
Kevin Colgan
Team South Shore Hobby
BackBreaker Racing
Long Island Raceway
Capt.Micro is offline   Reply With Quote
Old 02-23-2007, 04:21 AM   #7278
Phil C's Avatar
The car should come with a fixed centre shaft... I definately wouldn't advise trying to use the 1way shaft. It will get damaged by the grub screw, and I'm fairly sure it won't hold.
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 02-23-2007, 06:57 AM   #7279
kfa
kfa's Avatar
Originally Posted by Essnowyt
KFA - They stop the sway bar from moving from left-right in the mounts.
Snowy.
Thanks. Do you know who stocks them ?
//Kaare
kfa is offline   Reply With Quote
Old 02-23-2007, 07:46 AM   #7280
rc-zombies's Avatar
//Kaare
those are just standard linkage collars.. like these.
http://www2.towerhobbies.com/cgi-bin...?&I=LXXJ92&P=7
check with your LHS... most of stock it. and available in a variety of colors
racers edge has them..
http://www.racers-edge.com/store/cus...me.php?cat=308
Old 02-23-2007, 11:23 AM   #7281
Super Moderator
Marcos.J's Avatar
Originally Posted by Mhejjas
We'll race on a 24 hour endurance event this weekend. I've modified our Cyclone to be a bit more robust for this race
nice mod , I guess X-ray are good for something after all
Old 02-23-2007, 12:44 PM   #7282
kfa
kfa's Avatar
They most certantly have. Thanks.
Old 02-23-2007, 03:09 PM   #7283
Skill's Avatar
Just thought I'd let you guys know that you should probably steer clear of the one-piece layshaft/spur gear holder made my 3Racing. I'd run mine a couple of meetings and then wanted to change my spur, when I loosened off the grub screw for one of the pullies the pulley was still on tight. After prising it off I noticed that the grub screw had deformed the layshaft and caused it to be a very tight fit. Anyway, racing on carpet tonight and after a smallish hit the layshaft gave way and broke on the pin holes (any ideas why there are even pin holes on it??).
It seemed like a good idea but it seems like the material is a bit too soft and the pin holes really do weaken the structure.
Skill is offline   Reply With Quote
Old 02-23-2007, 05:36 PM   #7284
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by stephen hilton
i second that!
got some mips today and they kick butt!
but i think tir maybe slightly stronger
and the mips are smoother and dont chatter
where did you buy them at? and what's the part #?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 02-23-2007, 06:07 PM   #7285
Trader Rating: 194 (99%+)
Thanks for the info guys. I thought the car came with a center one way.
Does the BMI spool have replacable outdrives?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 02-23-2007, 09:15 PM   #7286
padailey's Avatar
I'm sure its so it can be used on a Cyclone 'S' with the stock plastic pulleys which require the pin.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 02-24-2007, 05:38 AM   #7287
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
What's the internal ratio on the car? Also, why do I have so much side to side play with the layshaft? Thanks for any help....
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 02-24-2007, 05:48 AM   #7288
Skill's Avatar
The internal ratio is 2.4375.
You need to adjust the position of the two belt pullies to get just the right amount of play on the layshaft. Loosen them off and push them out right to the outside, then tighten. Check how freely the layshaft on it own spins (without belts attached) and if properly set it should spin very freely. If not then loosen on of the pullies off and push it towards the spur gear a little and retighten and check again.
Old 02-24-2007, 08:19 AM   #7289
Super Moderator
Marcos.J's Avatar
scott how do you like the cyclone so far?
Old 02-24-2007, 10:23 AM   #7290
Static_racing's Avatar
Ladies and gentlemen, your search is over!! Up for sale is a Hot Bodies Cyclone "Surikarn Edition". This car is loaded with all the goodies. The rolling chassis features:
- BMI Carpet Chassis
- Acer Racing diff balls, thrust bearings, and full bearing kit.
- JET Racing zero degree rear hub carriers, front steering knuckles, and servo saver horn (all blue)
- PDub Racing hard front bumper
- Hot Bodies harded alloy diff outdrives front and rear with AE hardend diff screw
I'm including over $350 dollars in NEW parts!!
- JAAD Racing Diff covers - 3 sets of F/R arms - CVD rebuild kit - 2 sets of blue titanium turnbuckles - bumper/body post set - hardend axles - hardend dogbones - blue alum dogbones
- diff rings - hinge pins - assorted screws - alum shims - alum spacers - 3 sets of shock parts - 2 sets of steering parts - block/hub set - 3 pairs of CVD blades - new F/R belts
- 4 servo saver sets - ball ends - 13 pairs of assorted caster blocks(0,2,4,6) - origional out-door chassis, 2 spools, front and center one-ways - Blue alum chassis stiffner - Blue suspension block set - F/R springs, and swaybar kit.
The price is $450 FIRM. PM me with questions.
Thanks, Mike
Hot Bodies Cyclone-dsc01639.jpg   Hot Bodies Cyclone-dsc01641.jpg   Hot Bodies Cyclone-dsc01640.jpg
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
