Old 02-20-2007, 05:28 PM   #7246
Mhejjas's Avatar
111 will also fit. Minimum total teeth number must be at least 135.
e.g. 111/24, 110/25 etc.
By a relative "healthy" milling of the motor mount You can reduce number of total teeth to 133. It means a 111/22 or a 110/23
Mhejjas is offline   Reply With Quote
Old 02-20-2007, 05:46 PM   #7247
Mhejjas's Avatar
We'll race on a 24 hour endurance event this weekend. I've modified our Cyclone to be a bit more robust for this race
Old 02-21-2007, 12:30 AM   #7248
stephen hilton's Avatar
i think he means dont use many cyclone parts! (jkin)
stephen hilton is offline   Reply With Quote
Old 02-21-2007, 01:43 AM   #7249
diesel's Avatar
Default Nice Mod!!!
Nice mod there Mhejjas. Care to share how you go about doing it? Xray's diff a direct fit onto the cyclone?
diesel is offline   Reply With Quote
Old 02-21-2007, 01:51 AM   #7250
Default one-ways
hi guys how long should your oneway spin for mine seems to spin for around 5 seconds and does a more free running oneway make for better lap times? cheers t.k
Old 02-21-2007, 01:53 AM   #7251
i think he is also using xray driveshafts in the rear
Old 02-21-2007, 03:15 AM   #7252
diesel's Avatar
Yup those are indeed the xray driveshafts. But, my main concern is the number of teeth on the rear pulley...if they the same as that of the cyclone pulley.
Old 02-21-2007, 05:52 AM   #7253
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by jaz
110 or 112 I believe. I think the 110 and 112 might require some chassis modification though. I run a 108 right now with zero modification. I believe MarcosJ posted a while back on this so he will have a better idea.
for the 110 spur
to move the motor further back
Old 02-21-2007, 06:40 AM   #7254
I am new to the Cyclone, what I notice with most I should say all Cyclone is they have the sway bars on, is it a must that you run the sway bars? I am racing mostly on carpet with foam tires. The car I ran before was the RDX and I didn't have to use the sway bars, I just work with spring I guess because the car was very stiff I didn't have to use the sway bars.
Ramyuras is offline   Reply With Quote
Old 02-21-2007, 11:22 AM   #7255
stuey's Avatar
thanks for the advice i don't think i will be grinding any think tho i will just use the ratios availble
stuey is offline   Reply With Quote
Old 02-21-2007, 11:28 AM   #7256
stuey's Avatar
Originally Posted by Tez
Yeah stu, your car was by far the best car there, what the hell motor did you have in? I could try the steering lock thing.
Terry.
hey tez
the motor was no faster than anybody elses on the race track but my car just didin't slow down if you want one tho i used a co27 from smart racing using axiom motors there website is smartracing.co.uk or axiommotors.co.uk
give them a try they are pretty good
Old 02-21-2007, 12:31 PM   #7257
Mhejjas's Avatar
The diff is basically an Xray diff. I took and older wide Cyclone pulley, and cut out the whole inside of it. Only a ring remained with the 39 teeth on it. It fits exactly on the Xray pulley (after some sanding). The two pieces are glued together with Loctite 3450 "Liquid alloy". You can see the original teeth of the Xray pulley on the parts' photo.
Xray driveshafts (and also axles and couplings) are used simply because cyclone outdrives do not fit into the Xray driveshaft slots. BTW, other dimensions of the driveshafts are exactly identical, you can use e.g. Xray axles with cyclone dogbones and xray couplings (or any other combination).
Xray axles are worth for a try: they are lighter (4g to 4.5g) and seem more durable than the original Cyclone ones. (xray axles have two different positions to secure driveshaft pins therefore they have two lives.
Old 02-21-2007, 12:34 PM   #7258
have you tried the mip ones are amazing!!!!! but there not as durable as the xray ones and they dont bind at all!
Old 02-21-2007, 12:41 PM   #7259
Mhejjas's Avatar
To be honest, I cannot tolerate purple anodized parts
I bought a black version cyclone, and bought almost all options separately just because I hate purple parts. Unfortunately the Surikarn edition is not available anymore.
Old 02-21-2007, 12:49 PM   #7260
rc-zombies's Avatar
there's a brand new Surikarn kit on ebay right now... and few here in the for sale section right now as well...
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
