Old 02-20-2007, 12:15 PM   #7231
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Originally Posted by academygaz
Anyone know the part numbers for the decal sheets of both the Cyclone and Cyclone S?
Also, an online shop stocking them?
Thanks.
Cyclone decals
Cyclone S decals
Old 02-20-2007, 12:35 PM   #7232
academygaz's Avatar
Thanks guys, but they are out of stock at Tower.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 02-20-2007, 01:00 PM   #7233
xluis's Avatar
Originally Posted by Tez
Hi,
The set up is as follows
50wt 2@1.1 to 60 - 70 WT
gold springs springs
hole 2 on tower
outside hole wishbone
1.4mm roll bar
1.5deg front sweep
hole 1 2.5mm under top link
1.5mm under lower arm front and rear
4mm ackermanto 2 mm
1.5 deg camber
4deg caster
5.5mm ride height
droop/ 4 all round to 6 mm droop
front spool
fixed centre
-2 camber
rear
50wt 2@1.1
silver springs
hole 3 on tower
middle hole on lower arm
3deg toe
wheelbase arms 1.5mm front 1.5mm rear
wheelbase hub 0.75 front 2mm rear
top link hole 1 1.75mm spacer
lower arms 1.5mm front and rear
1.2mm rollbar
ride height 5.5
-2 camber
Droop/ 4 to 5 mm droop
mazda 6
LRP 24r
As i said the car was really good everywhere other than a slow speed chicane where it seemed that the front would dig in to much or the rear was loose, not sure which.
any advice would be a real help. Thanks!!
For me, I would make these litles changes (in red), is posible the springs are litle soft,too.
xluis is offline   Reply With Quote
Old 02-20-2007, 01:02 PM   #7234
Super Moderator
Marcos.J's Avatar
yes springs are way too soft for the shock oil, you may want to drop to 35 to 40wt with gold and silver springs
Old 02-20-2007, 01:52 PM   #7235
Tez
Why is the oil too thick and the springs too soft? Im trying to learn and i want to be able to recognise what changes i have to make, so any advice will be a huge help guys. My learning curve is pretty steep at the mo .
Thanks!!!!!
Tez is offline   Reply With Quote
Old 02-20-2007, 02:09 PM   #7236
First change droop to 6/5 then if that is better then change springs to pink/blue. Otherwise its a pretty solid setup. Maybe change the ackerman to 2mm with a spool. If you still feel that the rear is lacking in grip then raise the inner link im running 2mm at the moment but im running 3.5 at the front and i may raise it to 4mm. I am running a 1way though and iv not run a spool on carpet before.
HTH
Dan Hughes is offline   Reply With Quote
Old 02-20-2007, 02:58 PM   #7237
stuey's Avatar
i don't think the springs are too soft if you go too soft with oil tez the car will be under dampted though the fast sweepers and tend to break away you saw my cyclone on sunday i ran 2 @1.1 6owt front 5owt rear you may find your car over stears cos your using too much steering lock
stuey is offline   Reply With Quote
Old 02-20-2007, 03:00 PM   #7238
stuey's Avatar
just some advice about 64dp im thinking of changing to 64 what spurs and pinoins should i buy to give me ratios from 5.0 to 9.4
Old 02-20-2007, 03:01 PM   #7239
Tez
HTH
Hi Dan
How will the change in droop change the car? If you raise the the inner link, does this increase the grip levels? I have found changing the ackerman to 2mm makes the steering far to aggresive for me. I do get on very well with the one way, but i thought i could try and give the car a lot more stick with the spool, gota try these things.
Thanks for the help.
Terry.
Old 02-20-2007, 03:05 PM   #7240
Tez
Yeah stu, your car was by far the best car there, what the hell motor did you have in? I could try the steering lock thing.
Terry.
Old 02-20-2007, 03:08 PM   #7241
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
my car came with a 100 try that and go HERE and find more ratio's that you want
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-20-2007, 03:11 PM   #7242
Phil C's Avatar
Tez you have pm.
When it comes to oil and spring combinations, the damping should always be adapted to the spring ratio. The suspension should never feel too 'springy' or too slow. Basicly pink/blue springs work well with 40wt oil 3x1.1mm pistons. Maybe up the oil to 45wt wen you change to gold/silver if you want to. Personally I don't think its that necessary, when going from pink/blue to gold/silver, to alter the oil.
As I said give that setup a try and see what you think, but start with 3mm under the links instead of 4mm stated on the sheet.
Cheers,
Phil.
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 02-20-2007, 03:28 PM   #7243
stuey's Avatar
what is the biggest and smallest 64dp spur that will go on the cyclone
Old 02-20-2007, 03:30 PM   #7244
jaz
110 or 112 I believe. I think the 110 and 112 might require some chassis modification though. I run a 108 right now with zero modification. I believe MarcosJ posted a while back on this so he will have a better idea.
jaz is offline   Reply With Quote
Old 02-20-2007, 04:39 PM   #7245
AngryAsian's Avatar
With the CF plate - the largest stock is 108.
If you grind the plate a tiny bit to clear the spur, you can fit a 110 in without any issues. The spur will protrude from the bottom of the chassis, maybe 0.5mm. Negligible. It lasts well. It's rare to completely ground the chassis on that point so your spur won't be damaged..
With the metal heatsink plate - you can fit the 110 without grinding as it has more clearance.
I don't know about the 112, but that would surely stick out of the chassis a significant amount.
I run my 4.5 and 3.5 with the 110 and there aren't any issues with it.
If you want to run lower than 110/26 then you'll need to grind the motor mount to allow the motor to move backwards towards the spur. Only a little grinding is needed. Both the mounting screw holes need to be enlarged towards the back, but also the curved side of the mounting plate - this is so the motor has clearance once it's moved back. It's obvious when you have a look at the car..
Cheers!
(Thank to Marcos who pointed me in the right direction to start with..)
AngryAsian is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
