Old 02-15-2007, 09:25 AM   #7141
I bet the spur gear does not run true ... even Andy Moore drops the carbon bit on the gear. You may need an additional grub screw to get this correct.
Originally Posted by Tyrone
Hello ,
I got my Cyclone WC Edition yesterday and i must say the car is great to build !!!
and here is a pciture of my car:
Andyg01 is offline   Reply With Quote
Old 02-15-2007, 10:19 AM   #7142
Hey
sry but why it wont run ? I dont understand ?
Tyrone is offline   Reply With Quote
Old 02-15-2007, 10:20 AM   #7143
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I have not had any trouble with the carbon brace. I do however use two grub screws in the hub that holds the spur gear. It has two holes, might as well use them both.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 02-15-2007, 10:26 AM   #7144
wobble !
Hey
Old 02-15-2007, 12:00 PM   #7145
Racers, I am in the mood to try the Cyclone but not shore which one to get there is the Hara and the Moore, the Moore cost a little more but what is the difference between the two? now if I decide to go with the Hara what do I need to get to race on carpet? does the Hara come with two diff? and if not what about the Moore does it come with two diff? that all for now thanks.
Ramyuras is offline   Reply With Quote
Old 02-15-2007, 12:38 PM   #7146
Super Moderator
Marcos.J's Avatar
Trader Rating: 151 (100%+)
none of them come with 2 diffs, if you are going to run carpet you need to get the BMI chassis conversion there are a few BMI cyclones for sale in the forsale forum here is one of them BMI cyclone for sale with lots of parts
Old 02-15-2007, 12:59 PM   #7147
2-Bad's Avatar
Trader Rating: 24 (100%+)
On both my Clones; Surikarn and Moore, the spur runs true.... and this was without ever thinking I needed to add an additional grub screw....
However you do need to be sure you tighten the spur screws up evenly.... (Just a thought)
Just another thought... I also use spacers to take up the gaps/slop between the pulleys, spur hub, and bearings on the layshaft... this may help in ensuring the spur runs ture.....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 02-15-2007, 01:07 PM   #7148
Hi Marcos J. I saw you driving at the snowbirds. Do you have any set-up from hara with rubber or any tips for the Cyclone...Please
benoitrdv is offline   Reply With Quote
Old 02-15-2007, 01:23 PM   #7149
padailey's Avatar
I've been reading all this about diffs and broken screws and such and all I can say is it must STOP! I start paying attention to my diffs and I break my first diff screw!! Sheeesh!! I'm kidding of course.... at least now I had some options on how to fix it because the LHS had no HPI diff screws.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 02-15-2007, 04:56 PM   #7150
Super Moderator
Marcos.J's Avatar
you dont want any tips from me in carpet you want to ask Schreff or L.Fairtrace they are really good on carpet , i ran schreff 's setup for foam and did as best as I could, for rubber I used my asphalt set up. but this was my second time running carpet (but im working on a carpet track for me and a few friends of mine in Florida )
Old 02-15-2007, 05:27 PM   #7151
tc3 racer sc's Avatar
I NEVER BROKE A DIFF SCREW I GUESS IM NOT A HARD DRIVER
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 02-15-2007, 06:56 PM   #7152
I have owned 3 cyclones but built 4 cyclones total and have never had any problem with the Spur Gear running true. Andy Moore and Hara no longer run the carbon spur holder because there is less rotating mass without it, and not because the spur gear doesnt run true.
jimbobmahua is offline   Reply With Quote
Old 02-16-2007, 04:05 AM   #7153
TWiZTiD's Avatar
or is it because the Andy Moore and Hara kits dont have a centre one way ?? or do they
TWiZTiD is offline   Reply With Quote
Old 02-16-2007, 04:10 AM   #7154
A Ilievski's Avatar
Trader Rating: 39 (100%+)
the worlds came with a centre one way not sure about the hara though
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 02-16-2007, 04:36 AM   #7155
AngryAsian's Avatar
It runs true if you use all 4 screws on the spur and tighten it as you would a top-deck. If you cheat a little and only use two then it will sometimes warp the gear.
As for the alu carrier running out, the two grub screw thing does help. (I had to do it with mine way back to get it to run true..)
AngryAsian is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
