Old 02-12-2007, 03:58 PM   #7111
A Ilievski's Avatar
Trader Rating: 39 (100%+)
ive raced the car a total of 15 times now. Worlds kit that is. Summernats weekend. and the rest local times. With the older cyclone/diffs they kept coming loose and i broke afew dif screws. So far i havnt broken a screw and it hasnt come loose. It must be the way you build it i guess.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 02-12-2007, 04:16 PM   #7112
Mhejjas's Avatar
What kind of motor you use? Power means a lot
Mhejjas is offline   Reply With Quote
Old 02-12-2007, 04:32 PM   #7113
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
i use the novak 3.5 with no problems the only time that i broke a diff screw is when my rear tire got hit by another car
Old 02-12-2007, 06:36 PM   #7114
AngryAsian's Avatar
LoL!!
In the time that I HAVEN'T broken a rear diff I've broken the following on my car...
2 x topdecks
1 x middle bulkhead (RHS)
1 x graphite bumper brace
1 x upper bulkhead
The irony is, the diff is beautiful, and I'm yet to break an arm, hub etc!!!
This is insane.. my Pro4 was a tank. But it seems I've only had bad bad bad luck with this car. This is more damage than all my years of RC put together!
FYI I run:
GTB + 3.5R
Spektrum gear and IB 3800's (wow.. these IB's are still going!)
AngryAsian is offline   Reply With Quote
Old 02-12-2007, 06:39 PM   #7115
AngryAsian's Avatar
My vanity forces me to add...
Not my fault!! - Spektrum just isn't working out for me. I'm finally going to pick up a micro and see if it does it. Otherwise I'm going back to HRS.
Last time the damn thing shut down I did a topdeck, bumperbrace and bulkhead in one go!!
(To be fair - The aerial was broken at the PCB, it's fixed now but I have no idea how it broke in the first place!)
Old 02-12-2007, 09:44 PM   #7116
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Ok guys, I got a ton of pms about my Snowbirds winning setup. The car was freaking awesome turning the fastest laps of the weekend in stock 10.3s and
tqing(Schreffler) and taking the win with no car support other than Jason at Bmi's great products and help.
Here's the setup, schreffler ran a similar one. Just subltle changes to suit our driving styles.
Moorespeed BMI Cyclone
Notes are I ran the + 1.5 Xray hexes on my car with an extra .5 shim on the back. To make the car about 190 all the way around
I also ran the delrin diffs all the way around they are super lightweight and really durable. Ceramics throught the car. No graphite spur gear holder, thats extra weight. I also had to add 2 ounces to the car distributed evenly. I'll take a picture when I get the car back but here is one on rc50.com.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 02-12-2007, 10:07 PM   #7117
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
I made a "small" modification on the original Cyclone diff:
Now it's extremely smooth and reliable. I have run it with an LRP Vector X11 5.5T Brushless motor hopped up with a sintered rotor (approx. 450 watts) for a whole day, and the diff was just as smooth at the end of the day as it was in the morning.
who can make this modification over United States?
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 02-12-2007, 11:40 PM   #7118
raving-monkey's Avatar
Send a message via MSN to raving-monkey
It just looks like he has drilled the long outdrive bigger inside to take the xray diff screw....and made another external adjustment hole aswell.
Also looks like he is using the xray thrust bearings and springs to.....not sure if the other parts are xray but if looks easy to do and i never had problems with my xray diffs when i run sexray
raving-monkey is offline   Reply With Quote
Old 02-12-2007, 11:57 PM   #7119
Trader Rating: 21 (100%+)
You need a groove cut in to hold the c-clip though
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 02-13-2007, 09:45 AM   #7120
rc-zombies's Avatar
has anyone tried the new Excel Low friction white belts yet?
Old 02-13-2007, 10:11 AM   #7121
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Once again larry great job dude,bringing it home for express,i bet Tag hasnt stop smilling yet! Car looks the ticket to! You no if RC50 got a video of you checking out?
@Zombies,
From the picture i saw at the birds it looks like hara ran them on his car
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 02-13-2007, 10:48 AM   #7122
Guo Chean's Avatar
low friction belt will help you to smoother your drive train. and it runing very quite compare to regular belt. it help you carry more smooth connering acceleration due to less drag.
Old 02-13-2007, 10:58 AM   #7123
CA$H's son's Avatar
Send a message via AIM to CA$H's son
was wondering if anyone had good setups or starting setups for the cyclone on high bite asphalt rubber tire
thanks
CA$H's son is offline   Reply With Quote
Old 02-13-2007, 01:18 PM   #7124
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
@Zombies,
He only had the belt on one of his cars by the end of the week; not sure if it was his Mod or 19T.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 02-13-2007, 01:32 PM   #7125
Static_racing's Avatar
- Hara edition Cyclone, $450.00
- Hudy 2mm Driver, $20.00
- Switching barbers before the race, Priceless!
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
