Old 02-12-2007, 12:29 PM   #7096
stephen hilton's Avatar
stephen hilton is offline   Reply With Quote
Old 02-12-2007, 12:32 PM   #7097
padailey's Avatar
Originally Posted by stephen hilton
i have found that the wider pullys on the diffs make your diff smoother and it stays smooth for ages
Does the wider pulley use the same size diff balls?
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 02-12-2007, 01:09 PM   #7098
Phil C's Avatar
Double post
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 02-12-2007, 01:09 PM   #7099
Phil C's Avatar
Yer diff balls are the same size, the difference is the holes are square in the wide pulleys and the balls 'click' into place. This seems to make the diff better all round.
Old 02-12-2007, 01:16 PM   #7100
Mhejjas's Avatar
I made a "small" modification on the original Cyclone diff:
Now it's extremely smooth and reliable. I have run it with an LRP Vector X11 5.5T Brushless motor hopped up with a sintered rotor (approx. 450 watts) for a whole day, and the diff was just as smooth at the end of the day as it was in the morning.
Mhejjas is offline   Reply With Quote
Old 02-12-2007, 01:21 PM   #7101
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
what parts are those? xray parts? DId you tap the male half of the diff or what? Let me know I was thinking about trying that for a while now
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 02-12-2007, 01:24 PM   #7102
cool!
Old 02-12-2007, 01:47 PM   #7103
Static_racing's Avatar
Originally Posted by Marcos.J
SEMPER FI
Who's talking about squids?? Where my sailors at??
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 02-12-2007, 01:52 PM   #7104
Mhejjas's Avatar
I used the following parts:
- Corally ceramic thrust bearing (compatible with xray)
- Xray diff screw
- Xray diff pressure plates
- Xray secure ring
Modifications:
- Long outdrive: the 8mm diameter hole machined up to 15 mm depth, a 8.6mm diameter and .8mm thick groove is machined starting at 2.5mm depth.
- Short outdrive: M3 thread is made in the center hole. I've manually crafted a nylon nut to fit tightly from the outside (I used a nylon nut from a Protoform body set)
Old 02-12-2007, 01:56 PM   #7105
jaz
There was somebody on here a couple months ago that was going to try the 3Racing battery strap with the cyclone chassis. Whoever it was, did you have any luck with it?
jaz is offline   Reply With Quote
Old 02-12-2007, 02:03 PM   #7106
Corally bearing COR79164
http://www.corallyusa.com/
Andyg01 is offline   Reply With Quote
Old 02-12-2007, 02:22 PM   #7107
rc-zombies's Avatar
did not fit properly
but I'm still working on modifying it to make it work..
with some miner mods..works well with the pro4 chassis.
Old 02-12-2007, 02:29 PM   #7108
stuey's Avatar
i run tamiya diif bolt it needs cutting to length but never had any probs with this the car is perfect
the original pre production cyclone of haras had vertical ball stud on the stearing if it worked how they wanted it to im sure they would have kept that design.
stuey is offline   Reply With Quote
Old 02-12-2007, 02:42 PM   #7109
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
When the TC5 comes out I would check out that battery hold in setup. It appears that the posts the strap rides in are keyed to the tape holes.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 02-12-2007, 03:52 PM   #7110
jaz
Stormer has the regular black cyclone listed for $199. Does anybody know if this is a typo or their actual price?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
