Old 02-12-2007, 08:44 AM   #7081
stephen hilton's Avatar
Originally Posted by Andrew_Carter
I have ran the car for going on a year and a half and have only ever snapped 1 diff screw,It really is down to how you build,matain and run your diff. If your snapping diff screws every other week you really are doing somthing wrong.
Andy
i built them as per kit? but i think that maybe i was running them too tight so when i build them i tighten it up until theres just a fraction of slip
stephen hilton is offline   Reply With Quote
Old 02-12-2007, 09:16 AM   #7082
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
i found out over the weekend that you can use the schumacher thrust bearing insted of the bearing thats inside the cyclone diff, i had to add a little thin shim to take some play out of the diff pulley but it worked pretty good i got the diff pretty tight and it was still very smooth. I did it pretty quickly but i have a few bugs to figured out but i think that it will work really good . I ran it twice with no problems yet. Im going to work on it this week and see how it works at the next race.
Old 02-12-2007, 09:23 AM   #7083
cool! you gt the pt number?
Old 02-12-2007, 10:57 AM   #7084
Super Moderator
Marcos.J's Avatar
its the thrust bearing for the schumacher diff part # U1954, as soon as i figure out what shim to use ill let you know.so far so good
Old 02-12-2007, 11:00 AM   #7085
dawgmeat's Avatar
what's up marcos it was a pleasure to meet u and Jason, c ya soon
dawgmeat is offline   Reply With Quote
Old 02-12-2007, 11:02 AM   #7086
Super Moderator
Marcos.J's Avatar
same here!!good run(not bad for a squid) (j/k) ill make sure that next year i wont have brush problems
Old 02-12-2007, 11:06 AM   #7087
bxpitbull's Avatar
Default Squid!
Squid! Oo-Rah!
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 02-12-2007, 11:18 AM   #7088
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Has anyone tried the new spool drive cups on the old TIR center section?
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 02-12-2007, 11:24 AM   #7089
Dont think its possible, the pins are in the wrong place.
Dan Hughes is offline   Reply With Quote
Old 02-12-2007, 11:36 AM   #7090
Super Moderator
Marcos.J's Avatar
Originally Posted by bxpitbull
Squid! Oo-Rah!
SEMPER FI
Old 02-12-2007, 11:42 AM   #7091
From what I have seen it goes rough very quickly, more than other makes ... I run a RDX, my son has the HB...
One other point that spur gear .... I have seen a few cars with massive runout .. To me it looks like the holder has the wrong size for the shaft ...
Is the 'edit' shaft a better fit ?
Andy
Andyg01 is offline   Reply With Quote
Old 02-12-2007, 12:14 PM   #7092
i have found that the wider pullys on the diffs make your diff smoother and it stays smooth for ages
hth t.k
Old 02-12-2007, 12:15 PM   #7093
part number a495
Old 02-12-2007, 12:17 PM   #7094
Thanks,
Ignore the PM !
Andy
Old 02-12-2007, 12:29 PM   #7095
too late!
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
