Old 02-07-2007, 12:13 AM   #7021
Aid1970's Avatar
Originally Posted by Andrew_Carter
I pitted and worked with the Hb team all weekend,and ran the same setup as Andy,car worked really well!
But carnt go giving all the secrets away
So are the 1.5mm shims correct under the blocks and the oils that are at the top of the pic's
Aid1970 is offline   Reply With Quote
Old 02-07-2007, 12:23 AM   #7022
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Elliott Harper
We use the carbon middle deck indoors as it has different flex characteristics to the alloy one.
OK, thanks for that... but what about the CVD's...
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 02-07-2007, 01:50 AM   #7023
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
The Ver 2 CVDs have different characteristics over the MIP CVDs in regards the traction which is why Andy and Team HB use them on the rear of the car. The benefits of traction are lost on the front though because of the excess chatter that the Ver 2 CVDs have over the new MIP CVDs.
My suggestion to everyone would be to keep 1 set of MIP CVDs to use as a spare for your fronts, and use the Ver 2 CVDs so you can optimize your pace.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 02-07-2007, 08:35 AM   #7024
quick question regarding the layshaft.
do you guys use any shims in it to center the pulleys more?
how much side to side play should there be in the layshaft when the pullys and spur are on?
how do you guys set yours up?
chris_blakey is offline   Reply With Quote
Old 02-07-2007, 12:47 PM   #7025
stephen hilton's Avatar
Default spring nut
hi guys, do you know what your steering spring nut is set to as in the maual it says 1.5 what happens if i make it bigger?
thanks t.k
stephen hilton is offline   Reply With Quote
Old 02-07-2007, 01:22 PM   #7026
kfa
kfa's Avatar
thanks t.k
It'll brake on you faster.
Set it to 1mm
kfa is offline   Reply With Quote
Old 02-07-2007, 01:22 PM   #7027
Phil C's Avatar
Chris,
Put everything on the layshaft but don't fully tighten the grub screws, just have it so the pulleys and spur can slide on the flat spots. Then put the layshaft in as you would run it but without the belts on. If your running a 1way pulley then use the spur mount to push it over to the left and tighten the grub screw. Then move the fixed pulley to the right and tighten the grub screw, ensuring you leave a very small ammount of play. Its also best to have the layshaft as central as possible.
Stephen,
Tighten the servo saver down to the ammount stated in the manual, any more and the assembley will be under too much stress and as a result could break in an accident.
Hope this helps,
Phil.
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 02-07-2007, 01:25 PM   #7028
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
If you break your servo saver and do not have a spare try this:
Assuming you have some pro4 parts...
Take your broken servo saver and put the long plastic steering spacer from a pro4 up into the servo saver aluminum piece. Remove the servo saver spring and run the saver nut up and tighten it down good. Take a second nut and run it up to back the first nut.
You wont have a servo saver, but you will still be able to race. I guess you could do this and use a saver on the servo itself.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 02-07-2007, 01:29 PM   #7029
cheers guys
Old 02-07-2007, 01:56 PM   #7030
2-Bad's Avatar
cheers guys
Steve.. bout time you change that avatar isn't it????
Old 02-07-2007, 02:00 PM   #7031
2-Bad's Avatar
I use shims to take out the space between the pulley's... (1.5mm x 4mm shims - I think ), but this still should provide a little end-float.
Old 02-09-2007, 08:12 AM   #7032
rc-zombies's Avatar
anybody have the new blank Moore WCE setup sheet? or a link to it...?
will try to make a editable version.
http://www.hpiracing.co.jp/contents/...ndy070121C.pdf
Old 02-09-2007, 08:15 AM   #7033
I use shims on my layshaft as well.
Anyone tried using the WCE spool drive cups on a TIR spool center section?
Maclin | VP-Pro USA
Old 02-10-2007, 01:15 AM   #7034
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Originally Posted by Tez
Can anyone tell me how changing the front toe blocks from 1.5 to 2.5 will change the way the car handles??
Thanks.
I think it might increase initial steer before corners.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 02-10-2007, 01:47 AM   #7035
Tez
Thanks.
Tez is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
