Hot Bodies Cyclone
#7007
Originally Posted by AngryAsian
Raising the roll centres makes the tires work harder to generate more grip. Instead of the chassis allowing itself to roll deeper into the corner, the chassis effectively "stands" on the suspension to generate grip..
You only raise the block up on low traction surfaces where you're looking for grip. On a high traction surface like carpet, keep the blocks low..
#7008
Originally Posted by Aid1970
correct me if i am wrong but i thought that if you lowered the block or raised the link you raised the roll centre and got more grip
They run no shims under the lower mounts on carpet generally because they use tiny foam tyres and if you don't lower the lower mounts you end up with the arms at a funky angle because of the small tyres
#7009
#7010
As far as I know...
Lowering the block lowers the roll centre... Check your manual!!
Or rather - the Xray tuning guide or the old pro4 manual..
The reasons:
A low roll centre is "low" because it's further away from the car's CG. A "high" roll centre is closer to the cg. Imagine a car with such a high roll centre that it passes from the cg. then the car would not even roll through a corner because the links aren't acting on the car vertically. Only laterally through the CG.
Low roll centres - the suspension forces actually cause the chassis to roll down. The rolling moment means an effective reduction on the force pushing the tire down onto the ground.
Grip = tire adhesion * weight. More weight, more grip.
A high roll centre means the suspension, instead of having a moment that rolls the chassis, resists the rolling moment. Why? The rolling moment is smaller and passes closer through the CG.
This resistance means more weight is transferred ONTO the tire. More weight = more grip.
make sense?
The reasons:
make sense?
#7011
As far as I know...
The reasons:
make sense?
The reasons:
make sense?
....nope. I think you have it backwards.
#7012
Can anyone tell me how changing the front toe blocks from 1.5 to 2.5 will change the way the car handles??
Thanks.
Thanks.
#7013
Andy Moore's car from www.carpetwars.co.uk
Spur gear was 108.
Shock oil 55/50
1.5mm on all blocks
That's all I know
Spur gear was 108.
Shock oil 55/50
1.5mm on all blocks
That's all I know
#7014
I pitted and worked with the Hb team all weekend,and ran the same setup as Andy,car worked really well!
But carnt go giving all the secrets away
#7015
#7016
Originally Posted by 2-Bad
If you need a setup for foam then try Diasuke Yoshioka for the "Summer Nats"... 7th from the top
Its very good in modified.
http://www.hpiracing.co.jp/contents/.../download.html
#7017
Russ stuck a spool in for finals,carnt have been that bad... perhaps should of tried 1 way! Next time
#7020
We use the carbon middle deck indoors as it has different flex characteristics to the alloy one.
