Old 02-05-2007, 09:30 AM   #6991
Mission_carbon's Avatar
Originally Posted by bob33
hear are some pics from carpet wars sadly no ones of cars tho. and of cause andy carter in his BQ pants had a awsom weekend piting with the hb team. andy and olly was awsom all weekend.....
Haha Ace bob! Would love of been able to get there but as you know its miles away!
Willz
Mission_carbon is offline   Reply With Quote
Old 02-05-2007, 09:32 AM   #6992
Charles Godwin's Avatar
Good style Carter , hope you have some better luck lol. Good result to at the BIWS
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 02-05-2007, 09:36 AM   #6993
stephen hilton's Avatar
Arrow
Originally Posted by John Doucakis
You might find this interesting regarding EDIT parts.
More about it in my blog.
Click at my signature below.
yep that is a surprise but i think hb parts are ti nitride coated and the edit ones are just pure titanium
stephen hilton is offline   Reply With Quote
Old 02-05-2007, 09:43 AM   #6994
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Charles
Was in the main up until yesterdays 1 qualfing run,lost 4 seconds in my last run getting caught on the tape Was a good weekend anyway.
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 02-05-2007, 11:41 AM   #6995
Originally Posted by jeremymoemorris
omoser,
Could we get a pic of this?
I'll post pictures on Wednesday. Does anybody know if you can buy those spring washers seperately? Only found them in the complete diff rebuild kit (COR-79161)
omoser is offline   Reply With Quote
Old 02-05-2007, 12:18 PM   #6996
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by xluis
ok, thanks, but this setup is for rubber, you use the same for foam?.
If you need a setup for foam then try Diasuke Yoshioka for the "Summer Nats"... 7th from the top
Its very good in modified.
http://www.hpiracing.co.jp/contents/.../download.html
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 02-05-2007, 01:56 PM   #6997
JL
Guys,
I've just got myself a cyclone after having raced a TC3 for 2 years. I'm struggling to get it set up just now (foam on carpet) as the front end seems to just dig in at the corners and push and push and push. It's so slow and unresponsive! I've got a bit of work to do!
I've got a reasonable idea of what different set up changes do, EXCEPT that I've never played with roll centres. What do spacers under the pivot blocks and inner suspension links do on the cyclone?
Thanks,
Jason
JL is offline   Reply With Quote
Old 02-05-2007, 02:00 PM   #6998
turtle's Avatar
Hi,
I got a Cyclone S and thought I might post here for some help as no-one in the 'Cyclone S' thread could help me.
I brought a front spool for my cyclone S (part no. 61045) and tried to install in today, but it seems the dogbones dont fit inside the hubs.
Do you need to run uni's to use a spool?
If so, can someone give me the part no. for them.
Thanks.
turtle is offline   Reply With Quote
Old 02-05-2007, 02:08 PM   #6999
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by JL
Guys,
Thanks,
Jason
with foams i was told not to run any shims under the pivot blocks and under the cambelinks i run 2mm in front and 1mm in the rear,but im new to foam / carpet ,
Old 02-05-2007, 02:15 PM   #7000
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Originally Posted by turtle
Hi,
Thanks.
Is it the new spool?
If so then i believe you have to use ver.2 driveshafts...i think the CS comes with ver.1 shafts like the original black cyclone.
raving-monkey is offline   Reply With Quote
Old 02-05-2007, 02:43 PM   #7001
turtle's Avatar
I think I have the ver. 1 spool, cos on he Hot Bodies website it says that Part No. 61403 uni's are ver.2 and have larger end balls.
On the site I can't see and ver.1 uni's, so where can I find these?
Does Part No. 61088 MIP CVD's have a small end ball?
Old 02-05-2007, 02:53 PM   #7002
JL
Thanks Marcos,
Any idea why you shouldn't run any shims under the pivot blocks?
Old 02-05-2007, 04:44 PM   #7003
AngryAsian's Avatar
Raising the roll centres makes the tires work harder to generate more grip. Instead of the chassis allowing itself to roll deeper into the corner, the chassis effectively "stands" on the suspension to generate grip..
You only raise the block up on low traction surfaces where you're looking for grip. On a high traction surface like carpet, keep the blocks low..
AngryAsian is offline   Reply With Quote
Old 02-05-2007, 07:11 PM   #7004
how to let the chassis roll ? pitting some spacers?
jinkasama is offline   Reply With Quote
Old 02-05-2007, 07:39 PM   #7005
2-Bad's Avatar
Geee, very similar to the "SETUP" I posted earlier, what a coincidence ....
(Not having a dig at you Marcos...., just doing some stirring)
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
