Old 02-04-2007, 01:09 PM   #6976
Just a note to Say Andy Moore won the mod at the two days carpet wars .. Try and post pixs of his car sometime, and maybe up load a vid.
Andyg01 is offline   Reply With Quote
Old 02-04-2007, 01:11 PM   #6977
Super Moderator
Marcos.J's Avatar
Trader Rating: 167 (100%+)
Originally Posted by xluis
My setup are:
Front:
Camber:2 , Caster:4 , Height:4.5 , Droop:6, Spool , Stb:1.4
Shocks: 40wt, 1.2 , 2 holes, Gold spring ,
1 mm below pivot balls, 1.5 pivot ball, 2 mm ackerman
Rear:
Camber:2.5, height: 5, Droop:5, stb:1.2 , toe: 3
30wt, 1.2 , 2 holes, silver spring
1mm below pb,
Tyres: GRP 35, Stratus 3.0.
The track are medium-low grip, cold (7).
The car work good i think, the mainly problem is the differential, i finish 8 in the Final A, but with more dificult car.
my set up is here
http://www.cyclonedepot.com/site/ind...&cid=4&start=0
Old 02-04-2007, 01:15 PM   #6978
Please post the pics as soon as possible
Cheers
benoitrdv is offline   Reply With Quote
Old 02-04-2007, 02:23 PM   #6979
fathead's Avatar
There am broken the screw, and in addition one becomes loose and it slides constantly, even tight to the maximum, begins very well and it ends up sliding. I put thread lock in the nut.I have changed everything, except the balls and diff rings.Not what it happens to him, i read here some broken screws, for me is the first. Any suggestion?
Thanks in advance.
My team mate had a similiar problem with his rear aluminium diff loosening off part way through a run even though it was tight at the start.
The problem was the thrust bearing was too tight in the diff half and was grabbing the diffhalf & diff bolt once the diff warmed up slightly, he changed the thrust bearing and now the diff works perfect.
To help stop the diff bolt breaking don't tighten the bolt right up and then loosen it off when building the diff, just slowly tighten it up until it is right while in the car.
Slavich Design
fathead is offline   Reply With Quote
Old 02-04-2007, 02:32 PM   #6980
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
If anyone would like to contribute at that site please let me know. I did not think anyone was using it so I took the link off my sig.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 02-05-2007, 02:18 AM   #6981
stephen hilton's Avatar
any body have a good rubber- 27t set-up for a medium grip flowing track with a techical infield tryed snowys and it never worked as the shock oil was too thick?
cheers stephen
stephen hilton is offline   Reply With Quote
Old 02-05-2007, 03:03 AM   #6982
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Marcos.J
Is there a trick to print this off as the resolution is crap to get it to A4 size paper...
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 02-05-2007, 03:52 AM   #6983
hear are some pics from carpet wars sadly no ones of cars tho. and of cause andy carter in his BQ pants had a awsom weekend piting with the hb team. andy and olly was awsom all weekend.....
bob33 is offline   Reply With Quote
Old 02-05-2007, 04:39 AM   #6984
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
You Bast................. lol
Was a eventfull weekend to say the least lol
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 02-05-2007, 05:03 AM   #6985
xluis's Avatar
ok, thanks, but this setup is for rubber, you use the same for foam?.
xluis is offline   Reply With Quote
Old 02-05-2007, 05:38 AM   #6986
xluis's Avatar
Thanks, i probe it. I have a similar problem 2 years later with a Serpent 710 rear ball diferential, i sand and pulled with a dremel tool the inner of outdrive.
Thank you very much.
Old 02-05-2007, 06:07 AM   #6987
Super Moderator
Marcos.J's Avatar
i have one for foam but it uses the BMI chassis
Old 02-05-2007, 06:24 AM   #6988
hi guys just rebuilding my diff. does anyone know that: if you use the standard diff balls your diff screw breaks as i have been told this
Old 02-05-2007, 07:05 AM   #6989
why should the screw snap when using the standard diff balls??!
this sounds pretty stupid to me, I've always used the HPI carbide balls and never had any issues with them.
BTW, I'm now using some (8) RDX spring washers instead of the standard diff spring, never had such a smooth and tight diff. Additionally you'll need a 1 - 1.5mm spacer instead of the 0.5mm black washer on top of the spring washers.
omoser is offline   Reply With Quote
Old 02-05-2007, 07:47 AM   #6990
omoser,
Could we get a pic of this?
jeremymoemorris is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
