Old 02-03-2007, 12:19 PM   #6961
Static_racing's Avatar
I'm running two 2mm blue shims forward and one black plastic 1mm shim aft.
Hope this helps.
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 02-03-2007, 12:24 PM   #6962
Protc3 you have PM
jeremymoemorris is offline   Reply With Quote
Old 02-04-2007, 05:54 AM   #6963
John Doucakis's Avatar
You might find this interesting regarding EDIT parts.
More about it in my blog.
Click at my signature below.
John Doucakis is offline   Reply With Quote
Old 02-04-2007, 06:22 AM   #6964
John D you have PM
Old 02-04-2007, 06:44 AM   #6965
hey guys,
little problem with chatter in the front wheel while under full lock and on the power, any power!
i have checked everything obvious and everything seems to be free but i must be missing something. any one else had the same probs?
its a standard hara edition if that helps!
thanks
chris_blakey is offline   Reply With Quote
Old 02-04-2007, 06:53 AM   #6966
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
my first guess is the cv's do you have wear on the out drives
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-04-2007, 06:58 AM   #6967
With the wheels on, at full lock, there is always chatter. With stock CVD quite a lot, with MIPs maybe some less, but there is always some chatter.
That is not a problem. It occurs with all designs.
Once the car is on the surface, this is no longer a problem as it dissapears.
It only appears when wheels are on the air due to physics..
Can't explain it well.
Check whether you have chatter whithout the wheels.
If it still occurs, then you might have to disassemble your drive shafts and check for any wear.
Old 02-04-2007, 07:27 AM   #6968
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
here is a easy fix to the chatter, cut down your steering rate
Old 02-04-2007, 01:12 PM   #6969
xluis's Avatar
Hello, this weekend, we had one of the first important races of the year, i have a good setup, but the car has not worked well, with many problems in the back differential, until the moment donīt had no problem with it. There am broken the screw, and in addition one becomes loose and it slides constantly, even tight to the maximum, begins very well and it ends up sliding. I put thread lock in the nut.I have changed everything, except the balls and diff rings.Not what it happens to him, i read here some broken screws, for me is the first. Any suggestion?
I run with foam in asphalt, with motor Nosram 4.5.
Thanks in avance.
xluis is offline   Reply With Quote
Old 02-04-2007, 01:14 PM   #6970
2-Bad's Avatar
Trader Rating: 24 (100%+)
Yepp.. dead on Marcos.....
I run 18 degs of steering throw left & right.... Thats all that is needed, no chatter, and you get reduced tire wear to boot.....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 02-04-2007, 01:15 PM   #6971
Super Moderator
Marcos.J's Avatar
Thanks in avance.
whats your current setup? I have one for the it for asphalt, i run the novak 3.5 and the 4.5. Its a really good set up for mod
Old 02-04-2007, 01:29 PM   #6972
xluis's Avatar
My setup are:
Front:
Camber:2š , Caster:4 , Height:4.5 , Droop:6, Spool , Stb:1.4
Shocks: 40wt, 1.2 , 2 holes, Gold spring ,
1 mm below pivot balls, 1.5 pivot ball, 2 mm ackerman
Rear:
Camber:2.5, height: 5, Droop:5, stb:1.2 , toe: 3
30wt, 1.2 , 2 holes, silver spring
1mm below pb,
Tyres: GRP 35, Stratus 3.0.
The track are medium-low grip, cold (7š).
The car work good i think, the mainly problem is the differential, i finish 8š in the Final A, but with more dificult car.
Old 02-04-2007, 01:50 PM   #6973
stephen hilton's Avatar
any one got the cyclone depot link? cant find it anywhere
stephen hilton is offline   Reply With Quote
Old 02-04-2007, 01:53 PM   #6974
20 SMOKE's Avatar
http://www.cyclonedepot.com/site/
Jamie W
Old 02-04-2007, 01:54 PM   #6975
xluis's Avatar
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
