Old 01-29-2007, 01:25 AM   #6886
kfa
kfa's Avatar
Originally Posted by khunballz
help explain please ,what are we will gain an advantage from this setting?
1 mm. under front arm mount / 1.5 mm.under rear arm mount [ at the front ]
1 mm. under front arm mount / 1.5 mm.under rear arm mount [ at the rear ]
or lower front arm mount / higher rear arm mount
anti-dive for the front makes the front-train stiffer when cornering. pro-squat for the rear makes the car lean easier backwards when acclerating. Had you for the rear suspension placed 1.5mm on the front, and 1mm on the rear arm mount, you'd get anti-squat which makes the rear more flat when accleating.
//Kaare
kfa is offline   Reply With Quote
Old 01-29-2007, 06:11 AM   #6887
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
Originally Posted by AngryAsian
Does anyone have a spool setup for rubber asphalt?
Low traction outdoor track, medium size. Lots of corners...
I don't particularly like the spool, but I'm giving it another go.
i got one for you check your pm
Old 01-29-2007, 06:33 AM   #6888
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I ran 19t rubber on carpet this weekend and it was pretty fun. I ran some old 27's which were giving up a lil on lap times compared to the new 24s etc people were running. The carpet is low bite.
What tires do yall recommend, setups etc?
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 01-29-2007, 06:41 AM   #6889
Super Moderator
Marcos.J's Avatar
Im starting out with a set up that Jason (protc3) gave me for asphalt ,its very good.I m running it as a base setup at the birds. I ran it a few weeks ago at our snowbirds warm up with RP30's and was very good ( but i ran it with a 3.5 brushless motor)
Old 01-29-2007, 06:44 AM   #6890
My son bought one of these cars and I took some pictures of another car to get a good idea on the build ... for him not me ! As they say pictures paint a thousand words .. OH ... if you find these pictures too much I can remove then .. Just say.
Andyg01 is offline   Reply With Quote
Old 01-29-2007, 06:48 AM   #6891
About how much do the aluminum shock adjusters go for?
Thanks for the setup marcosj.
Maclin | VP-Pro USA
Old 01-29-2007, 06:52 AM   #6892
Super Moderator
Marcos.J's Avatar
no problem
Old 01-29-2007, 01:19 PM   #6893
rc-zombies's Avatar
Has anyone tried the new Hara Springset yet?
http://shopping.rcmodel.hk/index.php...72d4cfa36de3f1
Old 01-29-2007, 01:33 PM   #6894
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
it think it was the revised of excel spring kit for cyclone just different brand name.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 01-29-2007, 01:36 PM   #6895
Super Moderator
Marcos.J's Avatar
tamiya springs work fine for me!!
Old 01-29-2007, 01:41 PM   #6896
Guo Chean's Avatar
i know that some of the tamiya guy was runing hpi spring on their car.
Old 01-29-2007, 01:42 PM   #6897
Stew Noble's Avatar
For everyones information here are the rates in lb/in, the springs are refered to by Hara Products in kgf/mm, which would make seeing how these springs fit in with the HPI spring set difficult.
SS-Yellow-12.8
S-Grey-13.9
M-Black-15.0
H-Purple-16.2
SH-Red-17.3
// S N F //
Stew Noble is offline   Reply With Quote
Old 01-29-2007, 01:57 PM   #6898
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Originally Posted by floodo1
or you can just get MIP CVD's from the moorespeed kit
I have the moorespeed kit. I'm anticipating bending or snapping during asphalt use in 19t. I know this has already happened to one driver in the area with the same kit.......and this is a real good driver....former ROAR champ!!
Marcos,
Dave is the one that mentioned this issue to me.....
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 01-29-2007, 02:52 PM   #6899
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
You need to replace the stock balls studs for the Ti ballstuds. You will need them for the rear, for the ones that go on the rear hubs. The stock ones snap easily and can mess up a good hub, since half the screw will be stuck inside. Also, beware of the rear diff screw snapping, or it slipping or melting...you must get it right or else you'll have diff pblms with the Cyclone. However, the WC edition kit seems to be holding up very nicely for me. Its really strong and has taken the abuse very well. I'm happy Hb fixed this issue. Other that, the Cyclone is very strong and reliable.
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 01-29-2007, 03:00 PM   #6900
Super Moderator
Marcos.J's Avatar
Marcos,
you might want to get the steel axles instead there is a version 2 and you can still use the blades on them, I might have a set ill have to look, thats i did in the front and kept the purple ones in the rear
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
