Old 01-26-2007, 02:42 PM   #6871
rc-zombies's Avatar
Originally Posted by Isaac
Ok who has the 6 degree castor blocks in stock?
if you're unable to find one... PM me.. I have a set I can sell you.
new and nerver been used.
Old 01-26-2007, 04:53 PM   #6872
just want some advice how to generate more roll on turn..? which one will i adjust..pivot block spacers? of camber link spacer.?this is for asphalt.
jinkasama is offline   Reply With Quote
Old 01-26-2007, 05:07 PM   #6873
protc3's Avatar
i usually shim the blocks up 1.5mm and anything more that needs to be done i do with the camberlinks.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-26-2007, 05:26 PM   #6874
cause im runnin a oneway right now. and i just want it to roll through the corners. i got 1.5 shims on pivot block and 3mm on front camber link.and 1mm on rear...(i dont have .5mm interval shim ) how a bout 2 mm shims on the block?
if only my printer is colorsi wanted to print blank setup sheet to help me out with changes.but sad to say my printer isnt.
Old 01-26-2007, 05:29 PM   #6875
protc3's Avatar
try shortening the camber link a little.this will increase the roll.you can also lay your shocks down more.you dont want to raise the inner ballstud too high because you will lose your camber gain
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-28-2007, 05:37 PM   #6876
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
I have the possibility of having either some thicker aluminum or stainless cvd's machined....is there any other interest, especially the guys running spools?? Naturally, this is for the front end but I have something in mind like what Specialized R/C did for the Corally RDX or something along the lines of the old thicker blue ones AE came out for the TC3.
Any feedback would be appreciated. Thanks!
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 01-28-2007, 05:53 PM   #6877
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
scott you can run the pro4 cvds but you need to use a thinner axle bearing on the inside of the hub (pro4 cvds are a little longer) but it works like a charm
Old 01-28-2007, 06:12 PM   #6878
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
or you can just get MIP CVD's from the moorespeed kit
floodo1 is offline   Reply With Quote
Old 01-28-2007, 06:32 PM   #6879
Super Moderator
Marcos.J's Avatar
true but i already had the bearings and the cvds from my old pro4 so no money spent and i had them 6 months ago before the moorespeed came out
Old 01-28-2007, 09:03 PM   #6880
rc-zombies's Avatar
but..doesn't that push the axle and pin out farther from the hubs?..and make the car wider?
Old 01-28-2007, 09:08 PM   #6881
Super Moderator
Marcos.J's Avatar
only about 1mm
Old 01-28-2007, 10:44 PM   #6882
AngryAsian's Avatar
Does anyone have a spool setup for rubber asphalt?
Low traction outdoor track, medium size. Lots of corners...
I don't particularly like the spool, but I'm giving it another go.
AngryAsian is offline   Reply With Quote
Old 01-28-2007, 11:38 PM   #6883
swerv512's Avatar
i need some help with tweak...
i just got the mip twaek system and it says that my battery side is too light. how can this be? i have to push the front shock collar down alot to equal the tweak in the front. anyone else's setup been this far off. i use a NOVAK gts ecs (0.75g), sanwa 94357 servo (2g)and a sanwa 93836 micro receiver (1g), and an epic x stock motor(?g). is it normal for all the elctronics to weigh more than the battery? to which side do you guy shave to mount weights to balance your chassis?- i'm speaking of ni-mh, not lipo.
swerv512 is offline   Reply With Quote
Old 01-29-2007, 12:11 AM   #6884
2-Bad's Avatar
Trader Rating: 24 (100%+)
swerv512,
Before you start measuring tweak, is your chassis flat? You can use your tweak station to confirm this.
First, remove the tires and place the car on 10mm Hudy blocks to lift the chassis off the tweak bars of the Station. If it’s in error, then you’ll need to get a little violent with the chassis, as it may take some twisting of the chassis to get it flat however this gives you a good starting point.
Next,
Is everything the same length? (shock shafts, spring collars, springs)
If so, bolt on a set of “Set-up wheels” (preferable 63mm dia) then put the car on the Station with one Hudy block under the rear of the car. Check the bubble at the front to see if the front suspension is out?
If so, then it maybe just the positioning of the bulkheads, shock tower, and/or pivot blocks that are causing this. It’s a common misconception that countersunk screws will self centre. This is wrong and the tweak maybe caused by the misalignment of these suspension components.
If you still have Tweak, then if you can, try and replace components one at a time (with a friend's car, if you can).
Once the front end is fix, remove the Hudy block from the rear and repeat the exercise.
Hope this helps.
Peter
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 01-29-2007, 12:31 AM   #6885
help explain please ,what are we will gain an advantage from this setting?
1 mm. under front arm mount / 1.5 mm.under rear arm mount [ at the front ]
1 mm. under front arm mount / 1.5 mm.under rear arm mount [ at the rear ]
or lower front arm mount / higher rear arm mount
khunballz is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
