Old 01-25-2007, 03:54 PM   #6856
pug 205 gti's Avatar
checkout the trf415 thread matt and all will be revealed
pug 205 gti is offline   Reply With Quote
Old 01-25-2007, 03:56 PM   #6857
vtek's Avatar
I just got the bmi chassis i got 2 questions. do guys sand and glue the edges on the shock towers and top deck? and there is a hole on the front battery side to the right of the post, what is it for? thanx much
vtek is offline   Reply With Quote
Old 01-25-2007, 04:23 PM   #6858
raving-monkey's Avatar
Send a message via MSN to raving-monkey
You traitor.....get out of this thread immediatley
vtek, i on'y run the standard chassis but i sealed the top deck and shock towers...mainly just to make them look a bit better. But i think sealing the chassis is almost essential.
raving-monkey is offline   Reply With Quote
Old 01-25-2007, 04:34 PM   #6859
Originally Posted by chris_blakey
hi guys,
just picked up a mint hara cyclone and it looks amazing. trying to sort out my electrics out. the problem i have is that my ariel wire is running very close to the belt!! too close actually. any of you guys got pics of how you mounted your receiver next to the servo and how close your ariel wire comes to the belt?
i have a futaba PCM receiver if that help size wise.
any help would be appreciated!
Hi Chris,
i have a mate who has put a little bit of fuel tubing around the antenna from where it exits the receiver to where it meets the antenna post. He runs it above the lower half of the belt. Taping it to the chassis may not be ideal as the belts do run quite low on load.
jimbobmahua is offline   Reply With Quote
Old 01-25-2007, 05:10 PM   #6860
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
hi guys,
just put a 4mm shim under the antenna mount!
Old 01-25-2007, 05:12 PM   #6861
Super Moderator
Marcos.J's Avatar
i left mine bmi chassis alone
Old 01-25-2007, 08:03 PM   #6862
padailey's Avatar
I have the 3racing universals and on one the pin fell out. I assume the 3racing uni is pretty much the same as the ver 1 cyclone uni. Does anyone know if there is a rebuild kit or what size uni pin I might need?
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 01-25-2007, 08:13 PM   #6863
padailey's Avatar
Geeez... isn't that the way things go... I've been searching for hours and couldn't find anything. So I post the question and the next place I go there it is ... Hot Bodies Universal Rebuild kit (2 pcs) HP75188. Sheeesh!!
Tamiya TRF416X
Old 01-25-2007, 10:24 PM   #6864
what you guys use to prep the chassis when glueing the side? except for the sand paper.
jinkasama is offline   Reply With Quote
Old 01-25-2007, 10:55 PM   #6865
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
I found several differnt levels of emory cloth will work much better then sand paper. And then apply the CA with a cuetip not right out of the bottle, your chassie will come out amazing.
Just remember take your time.
Kave is offline   Reply With Quote
Old 01-26-2007, 04:59 AM   #6866
kfa
kfa's Avatar
Lots of q-tips. Try emry cloth/fine sand paper - black permanent marker or perhaps a "posca marker" - then CA. Gives you a black glossy finish.
kfa is offline   Reply With Quote
Old 01-26-2007, 07:01 AM   #6867
TWiZTiD's Avatar
by gluing the ends what does it do for the car apart from looks
TWiZTiD is offline   Reply With Quote
Old 01-26-2007, 07:03 AM   #6868
make the chassi solid. wont chip... especialy on asphalt
Old 01-26-2007, 02:41 PM   #6869
Ok who has the 6 degree castor blocks in stock?
wilsonproperties1.com
Isaac is offline   Reply With Quote
Old 01-26-2007, 02:45 PM   #6870
ASM
ASM's Avatar
Originally Posted by jimbobmahua
Hi,
could you guys also tell me which pivot blocks come standard with the Moorespeed WCE Cyclone? is it the 2.5 degree block front, and 3.0 degree rear like the Hara and Surikarn versions?
Yes, that's what comes in the kit. Just got my WCE kit from my local shop yesterday. Can't wait to get this thing together
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
