Old 01-21-2007, 04:04 PM   #6781
bmmer701's Avatar
Trader Rating: 17 (100%+)
Originally Posted by L.Fairtrace
Do you have shims under your pivot blocks? IF so take them out or put smaller ones in. that will solve the problem.
guys i was wondering where can you buy shims that you put under your pivot blocks? or what type of shims are you using? i have a set of shims on my pro4 but when i was about to use it in my cyclone i can only put the shims under the 2.5 deg. and 3 deg pivot blocks.
tia
bmmer701 is offline   Reply With Quote
Old 01-21-2007, 04:11 PM   #6782
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
tia
i use take offs shims
Old 01-21-2007, 04:23 PM   #6783
protc3's Avatar
Originally Posted by dawgmeat
U know what I was truley lookin' for some help from the Cyclone family so I can rep' the cyclone at the birds, FUCK ALL YOU GUYS MORE WORRIED WHAT PRETTY PULLEY SOMEONE HAS
so what you are saying is you like the pullies the arm sweep seems to give the car more off power steering.i always run the arm sweep with rubber tires.the less arm sweep the more on power steering you should have.being that i always run either a spool or a oneway i usually never worry about on power steering because you get so much with either.see you at the birds bro
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-21-2007, 04:30 PM   #6784
bmmer701's Avatar
thanks
Old 01-21-2007, 04:32 PM   #6785
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
On a more serious note the Stewart Noble setup is a really good starting point for rubber,if you copy it correctly that is
that can be found here,
http://www.rctech.net/forum/showpost...postcount=6494
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 01-21-2007, 04:52 PM   #6786
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
sorry i didnt know my pretty pullies were gonna piss in your information parade lol
DENNIS STORTI is offline   Reply With Quote
Old 01-21-2007, 06:14 PM   #6787
Super Moderator
Marcos.J's Avatar
no kidding
Old 01-21-2007, 08:46 PM   #6788
dawgmeat's Avatar
sorry I was havin' a bacardi 151 moment
dawgmeat is offline   Reply With Quote
Old 01-21-2007, 11:56 PM   #6789
raving-monkey's Avatar
Send a message via MSN to raving-monkey
May i ask where you got these from?
raving-monkey is offline   Reply With Quote
Old 01-21-2007, 11:58 PM   #6790
Trader Rating: 28 (100%+)
schumacher USA, APS international.
Team I'm Over It
racenut123 is online now   Reply With Quote
Old 01-22-2007, 03:34 AM   #6791
stephen hilton's Avatar
hi guys does anyone know if the mazda speed 6 body needs more cuttting at the bottom as my hot bodies mazdas are fine when i mount them around 2cm ground clearance. but the mazda speed 6 is nearly touching the floor?
stephen hilton is offline   Reply With Quote
Old 01-22-2007, 04:54 AM   #6792
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Well yesterday Andy Moore and Surikarn competed at the Team Orion Summer Nats in Australia. Moore won the event, Im not sure where Surikarn placed though, it was either 4th or 5th. Very good to watch.
Invitational:
1st Andy Moore ( Cyclone )
2nd Jake Zarb ( Xray )
3rd Simon Nicholson ( Cyclone )
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 01-22-2007, 05:21 AM   #6793
Stew Noble's Avatar
2cm/20mm?! Thats hugely high.
To get clearance you just move the clips in the body posts up (and/or add body spacers) no need to go cutting the sills down.....
Usually it's about right to have the sills at the same level as the bottom of the chassis, if it still bottoms out on track when its like this before i move up another bodypost hole ill use a Muchmore body o-ring to gain a little more height and thats usually just right.
// S N F //
Stew Noble is offline   Reply With Quote
Old 01-22-2007, 06:12 AM   #6794
bmmer701's Avatar
thanks
Old 01-22-2007, 06:40 AM   #6795
ok the only problem is i have cut the posts down and they wont go higher.and iam using washers aswell oh well lookes like new posts are in order thanks stew!
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
