Old 01-21-2007, 10:41 AM   #6766
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
well i started to build my snowbirds car. Andy Moore worlds edition with some Jet Racing,3 Racing hopups.they are always nice when there new.
Hot Bodies Cyclone-cyclone-001.jpg   Hot Bodies Cyclone-cyclone-002.jpg   Hot Bodies Cyclone-cyclone-003.jpg   Hot Bodies Cyclone-cyclone-004.jpg
DENNIS STORTI is offline   Reply With Quote
Old 01-21-2007, 10:46 AM   #6767
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Originally Posted by Marcos.J
it will help, are you traction rolling on every turn?
More or less, in the 2nd round it was literally every other corner...in the 3rd round i was recomended to put 4mm shims underneath the front camber links (on the bulkhead)..this helped some more.
In the final (i was in a crappy final so i had chance to test things) someone said to run 0 deg camber and lay the front shocks down (3rd hole in) and then it was doing it only a few times a lap. That was until about 4 mins in and it started doing it every other corner.
raving-monkey is offline   Reply With Quote
Old 01-21-2007, 10:59 AM   #6768
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Do you have shims under your pivot blocks? IF so take them out or put smaller ones in. that will solve the problem.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 01-21-2007, 11:04 AM   #6769
dawgmeat's Avatar
Originally Posted by dawgmeat
set for rubber carpet.......is it really needed for the front a-arms to be swept at 2.5 degrees, what the differance from 0-3 degrees???????
bump
dawgmeat is offline   Reply With Quote
Old 01-21-2007, 11:51 AM   #6770
Pivot blocks being the purple/black thingies that the hinge pins go into?
If so, then i don't have any shims..but someone said to put 1mm shims underneath all round.
Edit - Does it make a difference that i'm running the black version?
Old 01-21-2007, 12:01 PM   #6771
Stew Noble's Avatar
Originally Posted by raving-monkey
Well i was running the setup that Stew posted (with vtec 24r rubbers) on medium-high bite carpet.....and i just couldn't stop rolling.....no matter what i altered i couldn't stop it rolling. I got most of the problem away, it was just when my tyres got fairly warm that it started again.
Now, would roll bars stop this from happening?
My setup?..Yet you began without the 4mm under the front inner upper camber-link, front shocks not mounted in tower hole #2 and without any spacers under the piviot blocks.
Please follow the setup more precicely and im sure there will be minimal problems, the only time i had issues with the setup feeling like it wanted to lift wheels and traction roll was when 6/4 droop was tested, i reverted back to 5/5.5 and most tested this and found it to their liking also.
Also your addative routine/brand may be an issue in this too, also if your using tyre warmers....
// S N F //
Stew Noble is offline   Reply With Quote
Old 01-21-2007, 12:06 PM   #6772
I should i said stew. I didn't have everything to follow your setup exactly, so i run it closest i could.
I'm running full additive with LRP carpet. I have ordered some more spacers etc so i can use your exact setup. I'm yet to try carters exactly aswell.
Also, your running a mod with locked centre pulley, will this make a big difference from running 19t with a one-way centre pulley?
Old 01-21-2007, 01:29 PM   #6773
Just a simple question, are those "white center pulleys" standard with the
Moore WC Edition kit?
benoitrdv is offline   Reply With Quote
Old 01-21-2007, 01:35 PM   #6774
Trader Rating: 28 (100%+)
no, I think they are 3 racing pullies.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 01-21-2007, 02:29 PM   #6775
yes the pulleys are 3 racing very nice setup they give 16,17,18 tooth pulleys
Old 01-21-2007, 02:39 PM   #6776
Lookin' good! Do keep us updated!
oldfartjohn is offline   Reply With Quote
Old 01-21-2007, 03:01 PM   #6777
Ok I see. Thank you
Old 01-21-2007, 03:02 PM   #6778
Wink
Thank you for the precision
Old 01-21-2007, 03:43 PM   #6779
dawgmeat's Avatar
U know what I was truley lookin' for some help from the Cyclone family so I can rep' the cyclone at the birds, FUCK ALL YOU GUYS MORE WORRIED WHAT PRETTY PULLEY SOMEONE HAS
Old 01-21-2007, 03:45 PM   #6780
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
my self and Jason (protc3) are running Cyclones at the birds , look for us im sure Jason and I can help
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
