Old 01-19-2007, 09:18 AM   #6751
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Originally Posted by stephen hilton
so my other question is is a centre fixed pully quicker or slower than a one way with a one way pully???????? and which is the easyest to drive
cheers
Hi! My experience with fixed center pulley makes the car handling easier to drive than center 1way. Fixed must be used on loose or dusty track conditions. On the other hand, center 1way is needed for tight track layouts or high grip surface that needs adequate turn in or steer on corners that results faster transition because you tend to be "on power" always.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 01-19-2007, 12:03 PM   #6752
Stew Noble's Avatar
Originally Posted by finch
Ive been racing my HB moorespeed for about a month now using stock motors (27t). I already had two titanium coated diff screws break on me and problems with the Mip driveshafts pins popping out.
Has anyone else been experiancing these problems, i know alot of people have had problems with the diff screws, has anyone come up with a solution or is there a different make diff i can use or diff screw?
The second diff screw i'm still puzzled how its broke, the car was fine at practice and going really well, taken the wheels of 2nite and noticed that the diff is now broke!
Any advice would be most appreciated
Mike
The 'solution' to breaking diff screws its quite simple, it's almost always down to the build and resulting in a too tightly adjusted or a stressed diff screw.
When tightening the diff screw don't over tighten then back off to the point at which the diff is smooth but no slip, instead tighten it up slowly in small increments untill the desired tension is reached, if you've got time this process is eased if you break the diff in prior to final tightening.
The MIP cvd's require the use of threadlock on the grubscrew and will need to be tightened up very securely.
// S N F //
Stew Noble is offline   Reply With Quote
Old 01-20-2007, 03:57 AM   #6753
Thanks for that stew, rebuilt the mip driveshaft yesterday, seems to be ok so far. Had a problem with one of the pulleys in the heat before the final. grub screw wont stay tight on the layshaft.
I'm thinking about trying the one way diff o wednesday when i go to practice.
Whats peoples views on the one way diff compared to the spool. My diving has been ok but obviously if adapting to a one way diff will help get my time down that little bit more.
finch is offline   Reply With Quote
Old 01-20-2007, 04:59 AM   #6754
Finch, I can't find whether you run foam or rubber. If you run rubber you really want to use the one-way with foam a diff or maybe spool.
vassago is offline   Reply With Quote
Old 01-20-2007, 10:45 AM   #6755
I'm running on rubber tyres mate.
Old 01-20-2007, 12:04 PM   #6756
stephen hilton's Avatar
hi finch still with a spool untill you have completely mastered it and then go to a oneway cya wednesday tk
stephen hilton is offline   Reply With Quote
Old 01-20-2007, 02:40 PM   #6757
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
with foams you dont want to use the spool
Old 01-20-2007, 08:14 PM   #6758
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Well i was running the setup that Stew posted (with vtec 24r rubbers) on medium-high bite carpet.....and i just couldn't stop rolling.....no matter what i altered i couldn't stop it rolling. I got most of the problem away, it was just when my tyres got fairly warm that it started again.
Now, would roll bars stop this from happening?
raving-monkey is offline   Reply With Quote
Old 01-20-2007, 09:18 PM   #6759
Hey Guys,
I know you have all heard way too much about this however, I am still having a problem with breaking diff screws. Can someone post how to use the associated diff screw? The one I have does not have a "T" nut and will not fit into the cyclones T nut. What are you doing to use the nut that comes with the associated diff screw?
jeremymoemorris is offline   Reply With Quote
Old 01-20-2007, 09:50 PM   #6760
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
You will need the ae diff nut as well. I had to take and exact to it just slightly to get it to fit securely in the outdrive. Also, make sure the screw will go through the center of the outdrive without binding.
Also look at Stew's post 6752.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 01-21-2007, 03:17 AM   #6761
Hey guys, i am getting a hotbodies cyclone moorespeed edition and i was just wondering would a spool be good for it on the local track i run on, its a small-medium tricky,fast apshalt track.
I have run a one-way in other cars but it wears stuff out quick and so iv heard the cyclone works great with a spool i just wanted your opinion.
Jamie
jamie814340 is offline   Reply With Quote
Old 01-21-2007, 03:47 AM   #6762
Skill's Avatar
A spool will put more stress on the drivetrain than a one-way so if you're worried about wear then it's not really the way to go. Having said that, I've run a spool for quite a while and seen no driveshaft wear or any other problems with the drivetrain. The only thing you have to watch is wear on the outdrives of the spool, depending on which version you have. I've not tried the new spool which comes with the Moorespeed kit but i imagine that it will be much better than the other 2 spools HB have released.
Skill is offline   Reply With Quote
Old 01-21-2007, 08:27 AM   #6763
Super Moderator
Marcos.J's Avatar
it will help, are you traction rolling on every turn?
Old 01-21-2007, 09:18 AM   #6764
And if that doesn't work enough, try harder compounds for your tires, like 27's or maybe 30's.
It could be overheating of your tires, and if that's happening you gonna make gripp rolls or losing grip.
Rob Janssen
Rob Janssen is offline   Reply With Quote
Old 01-21-2007, 09:43 AM   #6765
dawgmeat's Avatar
set for rubber carpet.......is it really needed for the front a-arms to be swept at 2.5 degrees, what the differance from 0-3 degrees???????
dawgmeat is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
