Old 01-17-2007, 11:11 AM   #6721
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Excel finally release low friction white belt for cyclone.
here is the part number
EH008 low friction belt FRONT
EH009 low friction belt REAR
EH007 low friction belt set
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 01-17-2007, 11:21 AM   #6722
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Originally Posted by dawgmeat
stay out of my way or I will peel ya
Old 01-17-2007, 11:36 AM   #6723
stuey's Avatar
where can i get these from
stuey is offline   Reply With Quote
Old 01-17-2007, 11:45 AM   #6724
Guo Chean's Avatar
it only release the belt at the end of Jan mostly you can get those belt from Champs.
Old 01-18-2007, 01:54 AM   #6725
burito's Avatar
Here's Ronald Voelker's setup from the DHI-Cup...
Reto Koenig
burito is offline   Reply With Quote
Old 01-18-2007, 06:47 AM   #6726
dawgmeat's Avatar
what the purpose of sweeping the front a-arms for oneway or spools??? tight-vs-free flowing
dawgmeat is online now   Reply With Quote
Old 01-18-2007, 06:51 AM   #6727
dawgmeat's Avatar
the droop setting is that up-travel added to ride height, also the tire is that the time he bake them using warmers?
Old 01-18-2007, 10:06 AM   #6728
stephen hilton's Avatar
Default oneway
hi guys got a race comming up and i have been told that for that track a one-way would be best. i have been racing for 9 months and for 8 months of that time i have been running the safe option a diff. but now as iam getting better i felt that i needed to go faster so i needed to change to a spool iam getting better with a spool and slighly more consistant per lap but not as consistant as a diff but fastest lap is much quicker . so what do you have to do to drive a oneway right? e.g a spool i turn in early and power around it. also when running a oneway do you use the oneway pully or the fixed one cheers stephen
stephen hilton is offline   Reply With Quote
Old 01-18-2007, 10:12 AM   #6729
I have found that the fixed centre pulley works quite well on carpet.(Assuming you are running on carpet.) The only other thing I change when using a one-way is the ackerman. I change it to 4mm.
Team Durango, ORCA, MuchMore, Sanwa, Protoform, Tonisport, MR33, Roche, Custom Blitz Bodyshells
Elliott Harper is offline   Reply With Quote
Old 01-18-2007, 11:14 AM   #6730
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I'm still learning rubber carpet but I found that a oneway is almost a second a lap quicker than a spool but the spool is much easier to drive.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 01-18-2007, 11:27 AM   #6731
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Hey Larry are you guys running rubber tires at Horshem as a class or just practicing for the Snowbirds? Think that would be alot of fun to run rubber tires on carpet.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-18-2007, 12:01 PM   #6732
Phil C's Avatar
Elliott pretty much hit the nail on the head, I only ever run a spool on carpet when using low wind motors (7t) purely because most of the time brakes are needed to some extent. If your running stock or 19t then a 1 way with a fixed centre pulley will be the quickest in my opinion.
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 01-18-2007, 12:06 PM   #6733
Talking thanks guys
yep currently running stock but i dont want to make a fool of myself will a one way be really hard to drive? as one quick lap is no good thanks for the replys stephen
Old 01-18-2007, 12:13 PM   #6734
hey guys, has anyone ran the cyclone with foams with just the stock chassis??
ARC/HobbyWing/ Protoform/ Team Integy/ R1 Wurks/ACTIVRC
HEWITT is offline   Reply With Quote
Old 01-18-2007, 01:07 PM   #6735
BigDaddyT's Avatar
Send a message via MSN to BigDaddyT
Hey Stephen - I run rubber stock all the time at our club. The one-way is definitely the way to go for Stock. Once you get used to it, it will allow you to maintain your momentum and corner speed a lot better out there.
The car will initially feel like it has way more (too much) steering. You can dial this back a bit on the radio and then soften up the rear end of the car a bit. When it's working, it will have really aggressive steering, but not oversteer. It will take some tweaking to get it right for your carpet. I find that I usually start with the rear shocks laid down pretty far and then stand them up a hole as traction comes up on the track.
T-Bang Hobby Technology Inc. - www.t-bang.ca
Extreme Performance RC Motors and Racing Supplies - Vancouver, Canada
Team Corally - Trinity - Dekelz.com
BigDaddyT is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
