Old 01-15-2007, 09:43 AM   #6691
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
Originally Posted by SpeedTech
Hi guys,
Just want to post a quick note we now added a new section for the Andy Moore Cyclone World Edition Parts. I think all the new parts are now available separately
Steve Wang
cool
Old 01-15-2007, 10:10 AM   #6692
dawgmeat's Avatar
Rollcall who going to the birds? I'm reppin' rubber stock/19
dawgmeat is offline   Reply With Quote
Old 01-15-2007, 12:06 PM   #6693
Stew Noble's Avatar
Originally Posted by Rick Draper
I will go for a full shock and car rebuild and go from there. Out of interest do you usually run a moorespeed mazda 6?
Yes i have the new Worlds spec shock towers, my car is a Moorespeed edition. With regards shock pistons, which pistons did you say it was you were running 2 or 3 hole?
Oops, totally missed this post until now.
I dont really use the HB Mazda that often, it can be a bit overly aggressive, indoors anyway.
Okay, as without WC towers this setup would feel a little different...
3 hole, that setups sheet is abit funny like that as the ticks for the shock piston holes are set to one side and can be abit confusing some times.
In addition i was using the HPI Pro Competition shocks, this could be one of the reasons of a differance if your running the normal WCE shocks, although i believe adding a 2mm spacer under the piston inside the shocks alla hara guied will make them feel more similar....
// S N F //
Stew Noble is offline   Reply With Quote
Old 01-15-2007, 12:30 PM   #6694
Default set up for carpet
Stew noble!!! can you give the direction to find your set up for carpet foam? thanks
tqboy is offline   Reply With Quote
Old 01-15-2007, 04:09 PM   #6695
Stew Noble's Avatar
I'm affraid i can't really help you, I've never raced foam in my life.
I'm quite sure that the American drivers that are more familiar with this class will be able to help though.
// S N F //
Old 01-15-2007, 04:23 PM   #6696
protc3's Avatar
im in for stock foam
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-16-2007, 02:57 AM   #6697
BrainTeased's Avatar
Originally Posted by Kris Preisinger
Version 3 spool is great. After several club races, no signs of wear on the drive cups.
The part numbers are 61086 (spool) and 61087 (drive cups).
Thank you very much Kris
also what front CVD's were you using with the ver 3 spool? and what motor are you using?
i've only had 10 runs with my ver 2 spool (black 2 piece) and using the stock black HB cyclone CVD's with a novak 5800 motor and the outdrive on the spool has shown slight wear and tear.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 01-16-2007, 03:35 AM   #6698
2-Bad's Avatar
Trader Rating: 24 (100%+)
If you use the Tamiya Anti-wear Grease (53439) on the dogbone pins & outdrives it will reduce the spool wear greatly... 6-9 months out of a spool (in Mod).
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 01-16-2007, 04:04 AM   #6699
TWiZTiD's Avatar
im looking at getting back into rc cars again after 3 years off and i like the cyclone kits mainly the s cause i only plan on racing in 540 pro this time mainly for fun as i dont have time for alot of prac fo setups
is there anything i should know about the car first ?
is there an must have hop ups ?
and what spares do i need to have before racing again ?
TWiZTiD is offline   Reply With Quote
Old 01-16-2007, 04:15 AM   #6700
deadsethara's Avatar
Just a friendly advice, if I were you, I'd save up and buy the Hara or Moorespeed version. They're stronger and handles like a dream.
A fellow racer of ours started with an S in Stock 27 turn and is still upgrading his car to a handle at the level of the 2 kit models I've mentioned. So far he's changed the chassis, top deck, bulk heads, shock mounts, center shafts and pulleys, rear diff, front spool, shock towers and he is still not finished.
I hope this helps.
deadsethara is offline   Reply With Quote
Old 01-16-2007, 04:29 AM   #6701
TWiZTiD's Avatar
thanks for the info but i think alot of that is not need for 540 but i was thinking about just upgrading stuff if and we it needs it
would the car be better then my old xxxs grap plus with every hop up
Old 01-16-2007, 05:36 AM   #6702
|<R1Z |>'s Avatar
Send a message via AIM to |<R1Z |>
I have the version 3 spool in my hara car right now. I am running the steel bones as the aluminum ones tend to shear off on any impact when running a spool. The newer MIP cvd on the worlds car might be slightly stronger..... but I would still look for another option.
RIght now just running a stock..... but it can still break the cvd bone with a spool. I agree, the version 2 spool chips away pretty quickly.
signature'd
|<R1Z |> is offline   Reply With Quote
Old 01-16-2007, 02:16 PM   #6703
Hi all.
Which is the reference for the steel bones?
Pacopin is offline   Reply With Quote
Old 01-16-2007, 02:18 PM   #6704
Super Moderator
Marcos.J's Avatar
Originally Posted by Pacopin
Hi all.
front- 61043
rear- 61044
Old 01-16-2007, 02:56 PM   #6705
JonboyGB's Avatar
Hello all, need some advice with my BMI Cyclone. Iím running on carpet with CS22s in stock. The track is very tight and twisty (track overall is only 20m x 10m).
Has anyone got any suitable setups I could try? I guess I need something that would give me excellent steering for the tight stuff whilst keeping the rear planted.
I appreciate that some peeps have already been posting their setups but I think they are for bigger tracks using foams?
Any help would be really appreciated.
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
