Old 01-09-2007, 06:39 AM   #6616
Hey guys, I had run the Pro4 for quite a while before I got the Cyclone, and I've got a pretty good method for dealing with the servo-saver.
First, the 1.5mm thing is WAY overkill. Given how thin the walls of the threaded tube are, I think this much preload will eventually cause the saver to fail, even with no additonal stress. I run mine just past flush, to make sure it won't bind on the chassis surface once it's all installed.
Second, when you build the servo-saver, use some of the grey thrust-bearing grease. Put some on the purple aluminum tube where the spring and the turnbuckle arm turn. Then put some on the faces where the turnbuckle arm meets the piece that keys into the hex-shaped top. This will keep everything from binding. I was breaking these regularly until I started doing this, and I haven't broken one since.
Mike
Johnboy Walton is offline   Reply With Quote
Old 01-09-2007, 10:04 AM   #6617
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Default Novak Race Setup
Hello all that run the Cyclone with rubber tires. This past weekend I finished 8th overall at the Novak Race in Stock Rubber tire. Here is my setup for you all to use. The car was much better than 8th. In the first A main i had a battery bar fail. In the final two A mains the driver was the problem. But it was still a fun weekend.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 01-09-2007, 10:10 AM   #6618
Thanks for the setup
How would a setup for a Hara convert to one for the Moore?
Is the Moore so similar to the Hara you can just use an Hara setup?
vassago is offline   Reply With Quote
Old 01-09-2007, 10:36 AM   #6619
rc-zombies's Avatar
the Moore car started life as a Hara...
both cars are basically identical.
Old 01-09-2007, 10:42 AM   #6620
|<R1Z |>'s Avatar
Send a message via AIM to |<R1Z |>
Snowy.
What is the reason for running heavier oil in the rear shocks?
signature'd
|<R1Z |> is offline   Reply With Quote
Old 01-09-2007, 10:53 AM   #6621
Doesn't mean much, the geometry may still be slightly different.
(thought I read something about that)
Old 01-09-2007, 11:06 AM   #6622
Trader Rating: 28 (100%+)
He just told you they are basically identical in the way they are setup.Unless running a 3 piece spool,or hardened diff screws/hingepins is changing the car enough you would have to alter setup.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 01-09-2007, 11:09 AM   #6623
Excuuuuuse me for not believing everything I read
Too much bullshit on forums not to aks a bit further.
Old 01-09-2007, 02:06 PM   #6624
Almost finished builing my Cyclone Moore-speed WCE and it goes together like a dream. All parts fit perfectly, build quality is at least on par with Xray (of which I have build 5).
The manual could be a bit more clear and some parts are not in the bags where you expect them. Only minor stuff.
Can't wait to run it
If it drives as it looks,
Old 01-10-2007, 12:21 AM   #6625
Hi Guys
Just finished putting together my WCE cyclone.
The only problem i have is that when i turn the shock collars to change ride hight the shocker turns aswell (the purple cap on top and the thread) so to turn the collar i have to hold the purple cap.
Is this normal or have i done somthing wrong?
Andy.
Hotbodies Cyclone
Gm Racing
MuchMore
Andy__+ is offline   Reply With Quote
Old 01-10-2007, 12:50 AM   #6626
S_fender's Avatar
Put oil on the shock body and turn the shock collars. It will be a little better.
S_fender is offline   Reply With Quote
Old 01-10-2007, 12:50 AM   #6627
Originally Posted by Andy__+
Hi Guys
Andy.
I believe on the cyclone it is common, i have seen a couple of remedies, one to put a diff bearing spacer under the cap. When i rebuild i plan on trying this.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-10-2007, 01:16 AM   #6628
2-Bad's Avatar
Trader Rating: 24 (100%+)
Hi Guys
Andy.
On my Surikarn it not only turn, but also leaked. I ended up filing 0.5mm of the cap so it would tight right down. No more leaks and the top shock collar stayed firm.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 01-10-2007, 02:35 AM   #6629
one shop selling in good price for andy moore edition.hope can help any fans.
I think the best is the best now!
http://www.racing11.net/shop/product...oducts_id=2725
initialrays is offline   Reply With Quote
Old 01-10-2007, 07:58 AM   #6630
rc-zombies's Avatar
when buildng the kit and especially the shocks...did you guy look at Hara's building tips.. he goes through the entire process in building the kit..from start to finish. the link has been posted here many time.....
sorry don't remmember it off hand.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
