Old 01-03-2007, 09:19 AM   #6556
andyh's Avatar
Originally Posted by Hugo
The ones that we run on the Cyclone:
Blue
silver
pink
gold
white etc...
..linear
andyh is offline   Reply With Quote
Old 01-03-2007, 09:22 AM   #6557
Are the following springs linear or progresse???
6542 2 Racing Shock Spring 14x25x1.4mm 6 coils (2pcs) $5.00/pr
6543 2 Racing Shock Spring 14x25x1.5mm 6.5 coils (2pcs)(Kit Part) $5.00/pr
6544 2 Racing Shock Spring 14x25x1.5mm 6 coils (2pcs)(Kit Part) $5.00/pr
6545 2 Racing Shock Spring 14x25x1.4mm 5.75 coils (2pcs) $5.00/pr
6546 2 Racing Shock Spring 14x25x1.4mm 5.5 coils (2pcs) $5.00/pr
6547 2 Racing Shock Spring 14x25x1.5mmx5.25 (2pcs) $5.00/pr
6548 2 Racing Shock Spring 14x25x1.5x6.25 coils (pink / 2pcs) $5.00/pr
Hugo is offline   Reply With Quote
Old 01-03-2007, 09:23 AM   #6558
Ok so they are linear.
Now my question is : What is the difference between linear and progressive springs???
I guess the feeling of the car....but can you explain a little bit more
Old 01-03-2007, 10:08 AM   #6559
Stew Noble's Avatar
Originally Posted by Aid1970
can anyone help i am setting my moorespeed up to stew noble's set up but the kit comes with a 2.5 front suspension block and number 2 shock pistons . will the setup still work with these parts or will i need to change it to somthing else
Hi,
The 2 hole pistons won't feel a huge amount different, but the full potential of the setup won't quite be realised.
I'd definatly recommend purchasing a selection of toe blocks, the 2.5* will not allow the car to rotate so much, which is important indoors.
The 2.5* is usually used outdoors to make the car feel more aggressive upon entry.
Feel free to try it with the 2.5*, but on carpet the 1.5* and sometimes the 1* are best I've found.
For all those discussing springs, here is a chart of all HPI springs, I think it's a little easyer to read and compare than just a text list of springs, almost all Cyclone drivers use springs from the Pro4 set.
HPI Racing
// S N F //
Stew Noble is offline   Reply With Quote
Old 01-03-2007, 10:28 AM   #6560
rc-zombies's Avatar
Originally Posted by Marcos.J
Part # Description Suggested Retail Price
6743 4 Shock Spring 14.5 x 117 x1.2mm x 25 Coils (Red/4pcs Medium) $7.00/pr
6744 4 Shock Spring14.4x118x1.2mmx23.5 Coils (Green/4pcs) $8.00/pr
6745 4 Shock Spring14.4x117x1.3mmx26 Coils (Blue/4pcs) $8.00/pr
6746 4 Shock Spring 14.4 x 117 x 1.4mm x 26 Coils (Purple/4pcs) (Super Firm) $8.00/pr
6749 4 Shock Spring 14.4 x 117 x 1.4mm x 26 Coils (Black/4pcs) (Super Firm) $8.00/pr
you have to have the monster truck shocks to be using these...
Old 01-03-2007, 10:30 AM   #6561
rc-zombies's Avatar
progressive springs...the more the spring is compressed the harder it gets.
linear is consistant when compressed.
Old 01-03-2007, 10:36 AM   #6562
Aid1970's Avatar
Cheers Stew should i use 40wt oil in sted of 45wt due to lack of holes
Aid1970 is offline   Reply With Quote
Old 01-03-2007, 10:52 AM   #6563
Stew Noble's Avatar
Yeah, that can have a similar effect, wont be quite the same but pretty close.
A note to that setup is that i used Pro Competition shocks, which give a slightly different action to the normal type anyway, so it might be a case of having to play with the shock internals (oil, o-ring, piston) a little to get it feeling to your liking with the normal shocks.
// S N F //
Old 01-03-2007, 11:40 AM   #6564
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Old 01-03-2007, 01:22 PM   #6565
Aid1970's Avatar
Now i am confused what type of springs should i use going off Stew's setup i was told that the yoke springs were the same as the hpi one's only diff was that yoke were white and not black is this true or not do i need to buy hpi springs if so what type there seams to be 3.
Old 01-03-2007, 01:32 PM   #6566
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Whats the crack with all this spring business then Marcos?
HP75175 HPI PRO4 SPRING SET (7 PAIRS)
Is all you will ever need on rubber tyres
Blue-15.3lb
Silver-16.9lb
Pink-18.0lb
Gold-19.0lb
White-20.3lb
Yellow-21.7lb
Red-22.4lb
And if your running foams i belive the corally set is really good,i had Ashpalt and Rubber sets when i ran the RDX.
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 01-03-2007, 01:35 PM   #6567
|<R1Z |>'s Avatar
Send a message via AIM to |<R1Z |>
deleted pretty picutre
thats a good one. how long did it take you to make that.
signature'd
|<R1Z |> is offline   Reply With Quote
Old 01-03-2007, 01:39 PM   #6568
Stew Noble's Avatar
Its from the HPI Racing site, i posted it earlier today, i didn't post as an image though as it made the other posts kinda difficult to read having to constantly scroll horizontally at the end of each line
// S N F //
Old 01-03-2007, 01:44 PM   #6569
|<R1Z |>'s Avatar
you gotta be joking....... thats real???????????????
lets hire lara croft to decode that one. seriously.... could they make it any more complicated?
signature'd
Old 01-03-2007, 01:56 PM   #6570
Aid1970's Avatar
help Stew !! on the spring thing in my last post
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
