Old 12-29-2006, 01:56 PM   #6511
protc3's Avatar
no problem daryl.just let me know.i can send one out to you or you can pick one up from me at the birds.i will have a pretty good inventory there.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-29-2006, 03:16 PM   #6512
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by stuey
can any body put a blank cyclone setting sheet on here or a link where i can get a copy
thanks
here you go you can edit it your self set up sheet
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-29-2006, 10:24 PM   #6513
I will. Even if I dont run the birds I would still like to try the kit. Send me a email at silvadaryl@hotmail.com
Daryl Silva is offline   Reply With Quote
Old 12-30-2006, 02:34 PM   #6514
Default CYCLONE 4 SALE
Never used cyclone in UK for sale.
INFO:
CLICK HERE FOR EBAY LISTING
I have a drift car with dbox ect listed too, and a HUDY 1/10 setup block.
Have a few bits not on ebay, not sure what i could get for them so if anyone has an opinion please mail stephen@sharkcode.co.uk
ORION ADVANTAGE CHARGER (LIPO EDITION)
HUDY COM LAITH with diamond cutter and hard case.
UKShark is offline   Reply With Quote
Old 12-30-2006, 04:19 PM   #6515
cyclone's Avatar
hi guys, just been looking at the car and have noticed that most people put the cf piece as aposed to the alloy piece on the motor side of the spur gear... would building the spur asembly with the cf piece on the cells side of the chassis cause any problems? it seems unlikely but im just checking before i race it like this...
cheers
cyclone is offline   Reply With Quote
Old 12-30-2006, 05:51 PM   #6516
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Does this mean you are going to produce a BMI for the cyclone?
If so what will it be designed for? Carpet?
Ie. 3mm chassis, stand offs on the topdeck etc....really stiff?
raving-monkey is offline   Reply With Quote
Old 12-30-2006, 06:33 PM   #6517
20 SMOKE's Avatar
Jason has a carpet kit out he has been working on his 12th scale alot but, he didn't for get the cyclone
Jamie W
Old 12-30-2006, 06:49 PM   #6518
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
If you are going to be running on foam tires on the carpet then the BMI Chassis is the one to have. I have never tried it with rubber tires though.
Kraig
KT Hobbies
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-31-2006, 06:20 AM   #6519
Ok, well foam carpet racing over in the UK seems like a thing of the past. Less and less of it by the looks of things.
The club i run at (well indoor carpet club) we run vtec 24r's (nosram/LRP)...your lot probably never heard of them. I haven't seen then for sale in the US anyway, on medium to high bite carpet.
Old 12-31-2006, 06:38 AM   #6520
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
How was my setup Matt?
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 12-31-2006, 07:46 AM   #6521
I aint got round to trying to yet, first meeting out with the cyclone....i was just sorting out a few teething problems so i didn't change anything.
Next meeting is on the 6th so i'll try it then
Old 12-31-2006, 09:03 AM   #6522
Trader Rating: 25 (100%+)
Ok cyclone guys.......I bought a used Cyclone and ran it for the first time yesterday. I loved the car and the setup was close. I run on a HIGH bite indoor asphalt track. The car is really good with off power turn in. I am losing it in the center of the turn and a little push comming off. Also, comming off the straight into the sweeper on power the car pushes too much. I tried moving the rear shocks out on the tower figuring it would free the car up. I was wrong. Any ideas???????? I am running a center and a front oneway.
I run pre-mount rp 30s. I tried CS32s but it was too loose.
Jamie Hanson is offline   Reply With Quote
Old 12-31-2006, 09:15 AM   #6523
protc3's Avatar
the kit works well with rubber tire carpet also.you just dont need to use the side standoffs.i had a guy test it out with rubber carpet and he said it worked extremely well and was easier to tune than the stock chassis
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-31-2006, 10:49 AM   #6524
dawgmeat's Avatar
How would your carpet chassis with the stock top plate work out for rubber carpet
dawgmeat is offline   Reply With Quote
Old 12-31-2006, 11:54 AM   #6525
Static_racing's Avatar
Jamie,
If you running up at Fredrick, I'm assuming your using a one-way. Have you tried a simple spring/droop change? Also, you can use alittle more toe to get steering out of the corners. You also might want to try changing the ackerman. If the car is still out to lunch, you might wanna get ahold of Brian Riegal. He had the car for a while and had it dialed at the "C".
Mike
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
