Hot Bodies Cyclone
#6436
Originally Posted by nf_ekt
My only other question is: if I run the front diff sorta tight will diff screw problems occur? I got my rear dif a tad loose no problems, but I don't want to deal with any issues like some have had when run tighter.
I can't really give anyone any tips or tricks because I don't have any, just assembled the diffs as per the instructions and never had a problem. At one point with my Pro 4 I was running Schumacher mini pins on carpet which gave mega traction, still no breakage.
#6437
Super Moderator
Originally Posted by Takata
Were are you running Marcos? I'm a bit confused. I run with 108/26 (10.125 frd) on carpet with foam tires , Novak 4.5 and it shut in overheating protection after 4 minuts.
What do you think ? Is this possible ? Please help to understand.
#6438
Super Moderator
#6439
Originally Posted by Marcos.J
what size tires are you running ? im running the same gear combo as you and i have no thermal issues. Im running a 46mm tire.try droping it to 25/108
I use 59mm tires. I'm planning to go to 25/108 but I need a major grinding work on the motor support. Does anybody have a picture and let me know how to do it?
#6440
Super Moderator
Sorry Marcos, but you made a conversion error. 46mm is to small.
#6441
Super Moderator
#6442
Super Moderator
here is a pic , i grind a little bit ata time to keep the original shape around the motor, i took off around 2mm to 2 1/2 mm or so i was able to move the motor closer , i can go down to a 24 pinion ( 64pitch)
then i made the motor screw holes a little longer to be able to move the motor further back, i have a 25 pinion now and i can still move it back a little more.
on my asphalt car i just run a 110 spur and i dont need to grind any material out.but the spur sticks out of the bottom of the chassis about .5mm but i dont want to take that chance on carpet.
#6443
i have done that dremaling trick to my car it works a dream can get 2 teeth lower now
#6445
hi, has anybody tried this kinda thing on there cyclones...? will it be ok to do this to the bottom deck top deck, shock towers and maybe even bumber brace...? cheers..
http://www.teamcrc.com/crc/modules.p...rder=0&thold=0
#6446
A lot of people do a similar job on their cars, makes for a very nice finish. If you have got the time, take the effort, the end result is worth it.
#6449
hi guys.. just got my electronics for my cyclone (gtb and 13.5)
and while im installing them . i notice that the electronic side is so heavy than my bettery side(gp3300) by adding weight on it i probably need more than 40g ..so would that make my car heavy and run sluggish.
here is electronics
ko propo 2343 servo
amb (stick on the back of my servo)
spektrum sr3000 (spektrum capacitor)
gtb
13.5 motor
and iam using a 3300gp batteries. (will use for practice)
if anybody knows the weight of each of those electronics and the battery i would appreciate if you give me the weights. since i dont have any scale....
thanx guys.. will be testing it tom.
here is electronics
ko propo 2343 servo
gtb
13.5 motor
