Old 12-21-2006, 07:44 AM   #6391
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by schreff
You and me both pal.
it will be nice to meet you at the birds! Ill be pitting with Jason
Old 12-21-2006, 08:40 AM   #6392
Default Cyclone Diff
Using Cyclone in stock class is fine for the original diff screw, it works fine.
In Modified brushless (novak 3.5R or Castle 7700kv) it simply does not hold the power if the track is very fast and wide, if the track is mid to small, than no problem also.
The only way I was able to avoid diff screw to break was using Tamiya 415MSX diff screw, they are same size and diameter compared to the original Cyclone diff screw, just do not have the slot heat, means no adjustments from outside.
Anyway, diff screw does not break anymore using the Tamiya part, but it still unscrew in a fast and wide track using top brushless modified systems, even using thread lock on nut.
One thing that also helped was using Much More diff grease, they last longer than associated diff grease.
Using plastic joints with brushless (top ones) it simply melts the diff plastic joints.
Last week Ive tried the 3Racing aluminum diff joints, nut and nut holder, they worked very very well, it worth to take and they cost half of the price of the HotBodies aluminum diff joints.
But I am quite sure that the factory drivers must have something different to make their diff to work or they change the rear diff for each race heat.
Paulo
prmartins is offline   Reply With Quote
Old 12-21-2006, 11:30 AM   #6393
Static_racing's Avatar
Does anyone have the part number for the black, steele dogbones?
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 12-21-2006, 11:35 AM   #6394
Super Moderator
Marcos.J's Avatar
61043 fronts http://www2.towerhobbies.com/cgi-bin...?&I=LXNZD1&P=7
61044 rears http://www2.towerhobbies.com/cgi-bin...?&I=LXNZD2&P=7
Old 12-21-2006, 11:38 AM   #6395
|<R1Z |>'s Avatar
Send a message via AIM to |<R1Z |>
61043 - Front
61044 - Rear
61398 - ??
Not sure why the front and rear are different part numbers. Maybe because of a one-way vs. diff use issue? Anyway, these are the part numbers.
signature'd
|<R1Z |> is offline   Reply With Quote
Old 12-21-2006, 11:47 AM   #6396
Skill's Avatar
I think the 61398 are the V2 versions.
The main difference between the fronts and the rears is that the fronts are slightly thicker.
Skill is offline   Reply With Quote
Old 12-21-2006, 04:45 PM   #6397
protc3's Avatar
Man, I must be a the lucky one with these diff screws. Of course, now that I said that, I'll probably break one every run from here on.
yyhayyim - The Surikarn car you have coming from me has Associated diff screws in it. I had to drill out the outdrives to make them fit, but it is well worth it. I NEVER broke a diff screw on that car. I ran it in 19t and stock with no issues what so ever.
Also, the standard (black version) Cyclone that I am running right now has the delrin diffs and using the stock diff screws. I've run this car now for about 6 race weekends - mostly all in 19T - and have not had a problem at all.
What confuses me most is how these things just snap. My buddy Larry has gone through probably 6 diff screws already, 3 of which have been Associated screws. We even changed from aluminum outdrives to delrin ones to see if it made a difference and it seems to have helped somewhat - but they still break.
Moral of the story - I have NO idea what is going on with these diff screws. I fully expected my stock ones to snap within a couple packs, but they have been fine since I built the car. I know this doesn't help anyone and it doesn't help me either. Also, I'm not so sure titanium is the way to go. It's a harder material, but could also be more brittle. Maybe a much higher strength steel is the way to go.
Marcos, maybe we should get Breiner to make some diff screws.
larry broke 7 screws.what a pipe magnet.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-21-2006, 04:49 PM   #6398
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Not one of them from hitting a pipe. Its called horsepower, something you dont know about running 4 cells.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 12-21-2006, 05:01 PM   #6399
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
The best I can come up with is how you tighten your diff.
I never broken a diff screw on my hotbodies or pro4.
It is a steel screw and it streches. If you try to tighten it like a gorilla all at once it weakens the screw and snap shortly with use. If you slowly tighten the screw and build up the tension. .run the car...check for diff slip and adjust as needed you shouldnt have any problems.
People wreck all types of screws at my local track...they just have not learned what I like to call mechanic tight (ie never used any type of torque wrench in their life..lol.)
I dont think it is due to impact as I !@#@# destroyed a wall at full tilt in 19t 2weeks ago and broke a knuckle and that was it.
Jamie
J.Gonzalez is offline   Reply With Quote
Old 12-21-2006, 05:18 PM   #6400
Oh I have hit plenty but never once broke a screw on a hit. Its usually going onto the straight, when I rip on it.
Old 12-21-2006, 05:22 PM   #6401
2-Bad's Avatar
Trader Rating: 24 (100%+)
From what I've been told, all high tensile screw of this size (2mm) are of the high grade already (12.5g)
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 12-21-2006, 06:24 PM   #6402
protc3's Avatar
ripping fast stock.isnt that an oxymoron. just messin bro.no more 4 cell for me.i finished my testing
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-21-2006, 06:36 PM   #6403
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
well i gotta chime in i race with larry an he has broke alot of screws but i really think it is from all his rip an the way he yanks his car cause i hit shit an have not broken any either
and his car is fast
DENNIS STORTI is offline   Reply With Quote
Old 12-21-2006, 06:48 PM   #6404
I've broken 2 in stock and 4 in 19 turn. I think its more my driving style, FULL WOOD.
Old 12-21-2006, 07:44 PM   #6405
protc3's Avatar
you said wood
Jason Breiner
BMI Racing
Team Associated
J Concepts
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
