Old 12-20-2006, 07:44 PM   #6376
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by jinkasama
17lbs. i had the white springs.. i dont know whats wrong but it influences the ride height. i havent try another spring yet.. the shock lenght is 64.5mm .. but probably putting the electronics on will decrease the initial ride height..hopefully
64.5mm!! you should have the shock lenght around 61mm to 62mm, that might help
Old 12-20-2006, 10:08 PM   #6377
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
shock length won't affect ride height, just where the piston is inside of the body.
Ride height is determined by the length of the lower shock end, spring length, collar position, number of shims under toe blocks, and whether you're using the outer hole on the a-arm like you're supposed to.
My guess is that he has the wrong lower shock end, or is using the inner hole on the a-arm.
floodo1 is offline   Reply With Quote
Old 12-21-2006, 05:30 AM   #6378
Super Moderator
Marcos.J's Avatar
you are correct , i dont know what i was thinking
Old 12-21-2006, 06:00 AM   #6379
stephen hilton's Avatar
anybody know if the new hot bodies ti nitrade diff screws break? snaped 2 edit screws and 2 normal
stephen hilton is offline   Reply With Quote
Old 12-21-2006, 06:04 AM   #6380
Super Moderator
Marcos.J's Avatar
im still puzzled how you guys keep breaking diif screws
Old 12-21-2006, 06:05 AM   #6381
what screw do you use marcos ?
Old 12-21-2006, 06:07 AM   #6382
Super Moderator
Marcos.J's Avatar
I use the stock screw and its the same screw (about a year old)
Old 12-21-2006, 06:07 AM   #6383
Super Moderator
Marcos.J's Avatar
are you using the shims on the nut side of the diff?
Old 12-21-2006, 06:17 AM   #6384
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default HOw to Build a Cyclone Diff
Marcos: Please help us fix this diff pblm once and for all! Please give us your tips on how to properly build the diff for Cyclones, especially for those of us running modified class motors- obviously we are doing something wrong, or there is some inside info/tips that we are ignoring or have missed...ANYONE with true, time and battle tested way of properly building a Cyclone diff for modified racing, please share that info now for all of us to see and put to the test...
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 12-21-2006, 06:22 AM   #6385
i build mine as per manual and on average breaking 1 per month now using the hb ti nitrade screw. which screw is the strongest the edit titanium the hb titanium nirade or the standard ?
Old 12-21-2006, 06:38 AM   #6386
Super Moderator
Marcos.J's Avatar
i build them pretty much as the instructions , i use some shims on the diif nut side ,and I mainly build them like Adrian from Schumacher showed me.
Old 12-21-2006, 06:38 AM   #6387
schreff's Avatar
Send a message via AIM to schreff
Man, I must be a the lucky one with these diff screws. Of course, now that I said that, I'll probably break one every run from here on.
yyhayyim - The Surikarn car you have coming from me has Associated diff screws in it. I had to drill out the outdrives to make them fit, but it is well worth it. I NEVER broke a diff screw on that car. I ran it in 19t and stock with no issues what so ever.
Also, the standard (black version) Cyclone that I am running right now has the delrin diffs and using the stock diff screws. I've run this car now for about 6 race weekends - mostly all in 19T - and have not had a problem at all.
What confuses me most is how these things just snap. My buddy Larry has gone through probably 6 diff screws already, 3 of which have been Associated screws. We even changed from aluminum outdrives to delrin ones to see if it made a difference and it seems to have helped somewhat - but they still break.
Moral of the story - I have NO idea what is going on with these diff screws. I fully expected my stock ones to snap within a couple packs, but they have been fine since I built the car. I know this doesn't help anyone and it doesn't help me either. Also, I'm not so sure titanium is the way to go. It's a harder material, but could also be more brittle. Maybe a much higher strength steel is the way to go.
Marcos, maybe we should get Breiner to make some diff screws.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 12-21-2006, 06:40 AM   #6388
Super Moderator
Marcos.J's Avatar
I have a list for him , im just waiting for him to get cought up!! (I need my new 1/12th scale for the birds )
Old 12-21-2006, 06:41 AM   #6389
Super Moderator
Marcos.J's Avatar
you lucky dog!! you got schreff's car!!! thats a great car
Old 12-21-2006, 06:42 AM   #6390
schreff's Avatar
You and me both pal.
-Jason Schreffler-
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
