Hot Bodies Cyclone
#6347
Super Moderator
Originally Posted by lawtonlosi
Anyone got a used surikarn / hara topdeck they would want to part with?
http://www2.towerhobbies.com/cgi-bin...?&I=LXNZK1&P=7
I have both the Hara car and the standard cyclone and the top decks are the same.(Im looking at both now and with the caliper)
#6350
Hey all, Does anyone know where I can get some replacement Dog Bones for my Surikarn Edition? I bent one and can find anyone who has them. Thanks!
#6351
Tech Legend
Trader Rating: 51 (100%+)
#6352
Super Moderator
Originally Posted by wyd
I bought a few things from Stormer Hobbies when I needed a few Cyclone parts. Use the steel ones for the front of the car and alum for the rear. Saves alot of greif from bent bones and especially if asphalt with a spool.
#6353
Originally Posted by Marcos.J
thats what i did, also you can use the Xray blades on the steel dogbones if you want to use them on the rear. version #2 is a little thicker
#6354
You guys have a part number for the steel blades??
#6355
Super Moderator
Originally Posted by omoser
really? I tried them on the new CVDs and they did not fit (the snap-on hole is too small). Did not try to get them onto the "old" v2 steel shafts since they looked same size regarding the pin. For us it would be great to use the Xray blades since they're much easier to get here than the hotbodies ones...
#6357
Registered User
screws
hello,
where can I find diff screw Strengthened, As that proposed by edit ?
thank you
Mr.Shookie
thank you
Mr.Shookie
#6358
hi hot bodies now make a stronger diff screw part number is HB61089 but it still snaps
#6359
drill out the short diff half screw hole to 2.5mm and it will fix it.
#6360
Hi guys,
My cyclone is finally nearlly in my hands... But im going to need to use it with foam tyres, 19turn carpet... i need help. What front diff type should i be using? Im imagining that a ball diff is required...? If so where can i buy one from? will i need alloy outdrives for it etc...? could somebody help me out with part numbers and what i need etc...? Also will a oneway diff or spool not be any good?
Cheers in advance
Andy (in the UK)
Cheers in advance
Andy (in the UK)
