Old 12-17-2006, 03:00 PM   #6331
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by protc3
you running it at mireg jamie?
I think the carbon dust is getting to you (mireg ) i may be runing it this weekend as long as i get it together
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-17-2006, 03:16 PM   #6332
protc3's Avatar
jeez,im out of it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-17-2006, 03:39 PM   #6333
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
jamie if you need help with a setup let us know! also a have a full set of tamiya yellow springs if you need them
Old 12-17-2006, 04:09 PM   #6334
N4S
N4S's Avatar
Yeah , grab a set up from marcos ........ Then when i kick the snot out of you , you can look at mine and see what really works.
N4S is offline   Reply With Quote
Old 12-17-2006, 04:20 PM   #6335
Super Moderator
Marcos.J's Avatar
here we go again! and I was going to give you the hook up for tires at the birds
actually it was J set up
Old 12-17-2006, 04:23 PM   #6336
where can i find a screw set for the cyclone ?
zinger77 is offline   Reply With Quote
Old 12-17-2006, 04:28 PM   #6337
Super Moderator
Marcos.J's Avatar
sean you got your carpet chassis ready??
Old 12-17-2006, 04:29 PM   #6338
N4S
N4S's Avatar
You going to run foams or rubber..................
Old 12-17-2006, 04:30 PM   #6339
N4S
N4S's Avatar
Got it on the car but dont have it set up yet....
Old 12-17-2006, 04:44 PM   #6340
Super Moderator
Marcos.J's Avatar
im running foams
Old 12-17-2006, 04:45 PM   #6341
Super Moderator
Marcos.J's Avatar
get it ready for minreng,if you need springs for it let me know
Old 12-17-2006, 06:35 PM   #6342
tc3 racer sc's Avatar
Default changing camber links on cyclone for carpet
what advantage do you hve when running shorter or longer camber links and what a good position for carpet, and also what i need to do to get more steering out of my bmi chasis turn to right i get good left, i can really see the diffrent how it from stock chasis jason has done a good job on it but need to improve for snowbirds thxs for ur help fellow cyclone drivers
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 12-17-2006, 06:49 PM   #6343
Super Moderator
Marcos.J's Avatar
Jason should be able to answer that for you
Old 12-17-2006, 07:21 PM   #6344
|<R1Z |>'s Avatar
Send a message via AIM to |<R1Z |>
Normally, steering more in one direction than the other is caused by a radio or steering linkage setting. Make sure that your directional EPAs are equivalent in both directions. Make sure your steering linkage system is also set up properly and that it is centered. The links from the steering post to the knuckles should be nearly identical lengths.
also, if you could post your set-up, it might give others an idea of what to suggest.
hope this helps.
signature'd
|<R1Z |> is offline   Reply With Quote
Old 12-17-2006, 07:24 PM   #6345
protc3's Avatar
shorter camberlinks will allow the car to roll easier and react faster due to this.it allows the car to roll quickly back and forth.i went with the stock position that is in the instructions.it reacts quickly but is not twitchy.
as for the steering,check your endpoint adjustments and make sure they are equal.the way i set up my steering is first i set my steering trim and sub trim to 0,i set my EPA's to 100%.now i will take my servo horn off the servo and replace it to make sure that the steering rack is perfectly straight.if it is slightly off,you want to adjust it with your sub trim.now i readjust the steering turnbuckles so that the wheels are straight.after this you will want to measure the steering turnbuckles and make sure they are exactly the same length.the even lengths are very important because if they are different lengths it will change your steering geometry from left to right.once this is all set,redo all of your front toe adjustment.when you adjust your toe make sure you maintain even turnbuckle lengths.this should fix your problem buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
