Old 12-09-2006, 09:08 PM   #6241
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by pinggoy
whats the 0.8 under the suspension spacer.
thanx by the way..... will try that setup this monday.
thats the antisquat , if you want start with 1.5mm in the rear instead of the 2.0/1.5mm
Old 12-09-2006, 09:12 PM   #6242
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
ok so your rear is 2/1.5 right and you ad .8 on top of the 1.5? or instead of 1.5 you put 0.8? sori for the confusion
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 12-10-2006, 05:13 AM   #6243
Originally Posted by stephen hilton
thanks! has anybody got a good indoor set-up that they wish to share? small technical indoor track on carpet preferably using a diff instead of a one-way
10-11 second laps thanks stephen
I ran my new moorespeed indoor last night. I was running CS22's 40wt front oil 35wt rear oil, stock setup, kit springs and all i did was play with rear droop and roll bars. Car was very very good. There is room for a bit of improvement though.
Rick Draper is offline   Reply With Quote
Old 12-10-2006, 06:24 AM   #6244
Super Moderator
Marcos.J's Avatar
dont worry about the .08 just put the 2mm shim in the front and 1.5 shim in the rear the .08 is NOT a shim
Old 12-10-2006, 06:33 AM   #6245
stephen hilton's Avatar
silver front gold rear? thanks stephen
stephen hilton is offline   Reply With Quote
Old 12-10-2006, 12:11 PM   #6246
hi does anybody know what lengths your shocks should be? i was told 61.5 front 62.5 rear but this is almost inpossible on the cyclone as i cant get it past 62.6 and then it just turns.i have already scratched a shaft trying so what length should they be? thanks stephen
Old 12-10-2006, 12:15 PM   #6247
I don't know who says 62 or something??
Mine are 65mm front and rear and work perfect!
Rob Janssen
Rob Janssen is offline   Reply With Quote
Old 12-10-2006, 12:15 PM   #6248
Super Moderator
Marcos.J's Avatar
cut the ball cup some , a little at a time
Old 12-10-2006, 02:18 PM   #6249
thanks for replies, does anyone have an editable blank cyclone set up sheet. I have tried downloading from hot bodies site but link is not working.
Thanks Stephen
Old 12-10-2006, 02:22 PM   #6250
Super Moderator
Marcos.J's Avatar
Thanks Stephen
try this one
http://www.gearchart.com/setup/setup...lone_blank.pdf
Old 12-10-2006, 03:51 PM   #6251
pinggoy's Avatar
thanx for the help marcos.. ill probably see you next season of fseara...
TAMIYA TRF416X
Old 12-10-2006, 04:47 PM   #6252
Gold front silver rear. Its a very good base setup.
Old 12-10-2006, 06:58 PM   #6253
Super Moderator
Marcos.J's Avatar
thats cool, racing mod? we need some more mod entries!! anyways if i can be of any help with the cyclone let me know
Old 12-11-2006, 08:27 AM   #6254
Stew Noble's Avatar
You can use spacers on the shaft inside the shock body to shorten the length, if you want to go down the route.
I cant remember off the top of my head the length, but a good starting point is just to screw the bottom eylet up to the top of the thread then measure the length and make sure all 4 shocks are the same.
// S N F //
Stew Noble is offline   Reply With Quote
Old 12-11-2006, 08:55 AM   #6255
pinggoy's Avatar
not this year... i will run stock and 19t.... i know you guys is trying to have a new rules in modified.... i will try brushless stock this time... if liking it will try to go up...
TAMIYA TRF416X
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
