Old 12-02-2006, 06:08 PM   #6196
protc3's Avatar
i would get the HPI spring set for your car.they are only like 30 bucks and come with 7 pairs of springs.it will have all you need for asphalt.as for which springs to run,are you running the spool or oneway?
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-02-2006, 06:14 PM   #6197
im planning to run diff first try to figure out the cars handling. then will try spool... my car is still comming.its a hara edition.. whats the lbs ratings for the 7 springs??
thanx for the reply jason
jinkasama is offline   Reply With Quote
Old 12-02-2006, 06:19 PM   #6198
protc3's Avatar
blue:15.3
silver:16.9
pink:18.0
gold:19.0
white:20.3
yellow:21.7
red:22.4
i would start with the spool right off the start and try pink fronts and silver rears with 35 wt oil front and rear.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-02-2006, 07:00 PM   #6199
thanx
Old 12-04-2006, 04:46 AM   #6200
Originally Posted by Marcos.J
you can run a basic asphalt setup on carpet, i have a really good asphalt set up , that i also ran on carpet with rubber tires.
Can you post or PM me your Carpet Rubber setup.
Cheers
Smartypants is offline   Reply With Quote
Old 12-04-2006, 04:53 AM   #6201
Default diff screw ... resolved?
I broke many diff screws until i drill a 2.5mm hole through the right diff hub (nut side). In fact i enlarge the factory hole (near 2.1mm) to a 2.5mm.
Before the life time of the screw was less than 6 runs. Now I didn't break any screw during the 4days of the worldcarpetcup...
alex-fr is offline   Reply With Quote
Old 12-04-2006, 01:36 PM   #6202
Tez
What make of springs do you guys use if you want to go over the over the red hpi springs on the rear? The top guys at my club use 30lb all round and i have some x-ray light purple but they dont work if you want 5.5mm ride height, any ideas? Thanks!!!!
Tez is offline   Reply With Quote
Old 12-04-2006, 01:40 PM   #6203
Super Moderator
Marcos.J's Avatar
Trader Rating: 151 (100%+)
try Schumacher,AE or Tamiya springs
Old 12-04-2006, 02:01 PM   #6204
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I use corally springs on my car. They are cheaper than xray and feel better on carpet to me. Get a Silver and Black spring set and you'll have all you need. I run 33s on the front and 19s on the rear in carpet foam. The car was really really really good in stock last week. I tqed by almost a lap over 30 other guys with my BMI Cyclone.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 12-04-2006, 08:46 PM   #6205
are those diff screw problems are just occuring on mod? is there any problem with that on stock.
Old 12-04-2006, 08:50 PM   #6206
Ive broken a few in stock. But I think we have it under control now. You gotta not overtighten the diff and use plastic outdrives. They seem to hold up really well with that combo. For some reason ceramic balls seem to help too.
Old 12-04-2006, 09:02 PM   #6207
Static_racing's Avatar
I've found that with the aluminum outdrives, if you slightly enlarged the diff screw hole you'll have less of a problem with breakage. I run the AE diff screw and have not have any issues.
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 12-04-2006, 10:53 PM   #6208
ngo8's Avatar
Send a message via ICQ to ngo8
Ive broken 2 so far in the front only and they where hotbodies diffscrews i am using associated diff screw in the back an so far its all good so ill try it in the front as well and i was running 19t on foam carpet .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 12-05-2006, 08:13 AM   #6209
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
You know now that you said that... when I bought my outdrives for the front, hole didnt seemed machined out enough for the diff screw. I havent broke one up front and have been using ae screws all around. I broke some of those, but that stopped when they took out the roadrails.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 12-05-2006, 08:41 AM   #6210
padailey's Avatar
Are you guys just using the ae diff screw and not the nut? I can't seem to get the ae stuff to fit right. Did you do any modifications?
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
