Old 11-28-2006, 12:10 PM   #6151
Originally Posted by Guo Chean
the edit titanium diff screw also having the same problem. is better you go for TC 3 diff screw
I'll try that if the edit one goes on me. Thanks for the tip.
Dan Hughes is offline   Reply With Quote
Old 11-28-2006, 01:44 PM   #6152
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Default AE diff screw
I actually broke several TC3 diff screws in stock.... needed a stronger screw quick for 19T carpet at the Indoor Champs and fast!
I found an excellent alternative and have broken none since.
UNITED TITANIUM sells very high grade 6-4 titanium screws. They are a bit pricey at $10 a piece and a minimum order of $100, but a small price to pay to finish your race and if you have friends that also need them.
The screws I bought are 2-56 x 1 inch socket cap 6-4 Titanium
(equivelent to Grade 5 Steel in strength)
Contact Info:
www.unitedtitanium.com
3450 Old Airport Road - Wooster, Ohio 44691 - USA
1.800.321.4938
I spoke with Ed and told him that I'm sure others would be calling
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 11-28-2006, 03:33 PM   #6153
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default Xray T2 Steering Knuckles Work with Cyclone
FYI: Xray T2 front steering knuckles and hubs work nicely with the Cyclone. We have found them to be a bit stronger, too, and gives a bit better steering and ackerman.
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 11-28-2006, 04:23 PM   #6154
AngryAsian's Avatar
On the topic of parts from other manufacturers fitting well..
Someone told me that the tamiya cvd rebuild kits workd perfectly in the cyclone cvd's as well.
Part number 53500.
I've also heard of Tamiya guys swapping tamiya arms/c-hubs and knuckles out for the Cyclone equivalents for better strength!
AngryAsian is offline   Reply With Quote
Old 11-28-2006, 10:04 PM   #6155
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Originally Posted by raceblast
I am out to buy a cyclone and I want to know the differences between the hara edition and the Andy Moore edition? Do both of them come with front one way, front spool, mid one way and rear diff? Or are they optional parts?
Moorespeed has a lot to offer. Added parts on the kit is a great deal.
#61090 Front Shock Tower 3.5mm NEW
#61091 Rear Shock Tower 3.5mm NEW
#61086 Front Solid Axle Set (Ver 3) Black
#73086 Graphite Bumper Brace
#61392 Hetasink Middle Chassis (Purple)
#61092 Wheel Nut M4 Serrated NEW
#61089 Diff Screw M2x27mm Titanium Coated NEW
#61098 Suspension Shaft 2.5x24.5mm Titanium Coated (2PCS) NEW
#61099 Shock Shaft 28mm Titanium Coated (2PCS) NEW
#61088 MIP Cvds World Champion Edition (2sets) NEW
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 11-30-2006, 01:56 PM   #6156
Tez
Can anyone tell how the 2mm or 4mm anchorman settings affect the car? Also ive got a oneway in at the moment for carpet, i like the turn in but it reacts just too quickly any ideas on how to change that, im using a 1.5 front toe bar. Thanks!!
Tez is offline   Reply With Quote
Old 11-30-2006, 03:06 PM   #6157
2-Bad's Avatar
Trader Rating: 24 (100%+)
Not 100% sure, but I believe going from 4mm to 2mm will make the car more reactive to steering change, eg. more aggressive......
There are many things you can tune to reduce steering, but what are you chasing, less turn-in, less turn-out, less reactive steering, or reduced steering overall?
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 11-30-2006, 03:48 PM   #6158
protc3's Avatar
you will want to stay with 4mm shims on the steering rack.reducing the amount of shims will increase your mid corner and exit steering which will give a funny feel with the oneway.to tone the steering down,i always make sure to grease the oneway bearings to eliminte some of the freewheel action and then from there i mess with diff tension.i will tighten the rear diff a little at a time to tone down the rotation of the car.i do this in small increments as i drive the car.hope this helps.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-30-2006, 04:18 PM   #6159
Originally Posted by AngryAsian
Yellow S15 - don't have my pinions handy atm.. but I'm guessing around a 110, 24-25?
That said - some slight grinding on the motor mounting holes on the motor-mount will allow you to move the motor closer to the spur.
I haven't done it myself, but it shouldn't be too hard..
Just a quick dremel job..
just thourt i would say it is not the screw slots u gota grind. it is the atchle motor mount its self wer the motor sits in if u push it as far back as it goes u will see it hits the edge (the stickyout bit lol) so u have to dreamal that back and make it slighty larger i t wont dramal far tho as i have done it im runing 48dp at the min (til i get some cash) and by dreamaling it out i gaind space to fitt 2teeth smaller pinion.
and if anyone noes whats the bigest spur in 48dp i got a 81 on at the min n not quite out the bottom.
cheers bob
bob33 is offline   Reply With Quote
Old 11-30-2006, 04:34 PM   #6160
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
cheers bob
Im guessing it will be a 82 spur
Old 11-30-2006, 04:36 PM   #6161
Super Moderator
Marcos.J's Avatar
cheers bob
I grinded away too and with a 110 spur i can go as far as a 13.40 fdr
Old 11-30-2006, 04:55 PM   #6162
AngryAsian's Avatar
Hey Marcos.
Got a pic of your Cyclone with the mini Spekturm in it handy?
I pulled all the electronics out of the cyclone to try to reduce the amount of weight needed on the battery side.
I've got the GTB mounted on it's side right next to the topdeck now. I'd rather mount it flat per usual and hope that the mini fits in there without having to cut the ears off my servo and taping it down. (Don't like sticking things down in the car. Seems like it might move around. Esp. in sumemr when things get hot!)
Cheers!
Old 11-30-2006, 04:59 PM   #6163
Super Moderator
Marcos.J's Avatar
Hey Marcos.
Cheers!
yeah give me second and ill post it
Old 11-30-2006, 05:01 PM   #6164
Super Moderator
Marcos.J's Avatar
both car are set up the same way one is my carpet car the other asphalt
Old 11-30-2006, 05:04 PM   #6165
2-Bad's Avatar
I too have had trouble with the “Heavy Duty” diff screw, snapped about 4 now, all breaking at the neck of the shoulder and thread point of the screw. All screws broke while kissing the raised ripple of the corner. Car gets a little air on one side and bang… 2WD…hmmm.
Went to the AE version and it has lasted the longest, but the nut broke this time 2 weeks ago, (when a friend was using my car over several weeks).
Still trying to find a permanent solution....
I would be interested in how titanium goes... would have thought it would be weaker then high tensile steel... keep us posted please...
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
