Old 10-27-2006, 05:03 AM   #5956
JonboyGB's Avatar
Originally Posted by Scooby Horton
It is a must have!!! Thanks Jason!
Just ordered a new BMI chassis. Canít wait to get it and fit it.
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 10-27-2006, 07:45 AM   #5957
|<R1Z |>'s Avatar
Send a message via AIM to |<R1Z |>
Originally Posted by Guo Chean
if you going to run cyclone on foam carpet you must have cyclone BMI it will different completely you will be dial on the carpet track as Andy Moore say it was night and day better.
In addition to the handling characteristics that everyone is mentioning..... there are several other details that eveyone should be aware of and appreciate, if you have never owned a BMI conversion.
1. The battery slots are always pre-chamfered perfectly. The batteries will always sit perfectly flat in the chassis and you will be able to throw away whatever tool you currently use to file the slots.
2. The bottom of the chassis has a tape slot under the batteries. This allows your battery tape to be flush with the bottom of your chassis, rather than extending below your chassis. No more tech inspectors complaining that your ride height is too low because their measuring device is sticking to the edges of your tape.
3. All of the carbon fiber has the sharp edge removed. Rounding the edges is a pain to do by hand, and there is nothing worse than cutting yourself or splintering a piece of carbon fiber into your hand. All of the egdes are prepped and ready for whatever final treatment you do. (e.g. CA glue, nothing, etc).
The BMI cyclone kit includes all of these and is the best upgrade you can invest in for your car.
signature'd
|<R1Z |> is offline   Reply With Quote
Old 10-27-2006, 08:46 AM   #5958
rc-zombies's Avatar
I wish I can fully utilize the BMI chassis for foam carpet...but unfortunately..my local carpet track has switched to spec rubber tires.
I did have it on my Pro4... absolutely the best aftermarket chassis available.
I'll be looking forward to BMI's asphalt chassis if it gets released.
Old 10-27-2006, 10:07 AM   #5959
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i totally agree, its a very nicely done set, all i did to mine was lightly round the slots, and ca the edges...
works great on foams... at our local track, the grip is still fairly low, so i have been running mine without the stiffening posts...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-27-2006, 12:06 PM   #5960
ngo8's Avatar
Send a message via ICQ to ngo8
mine is on the way to cant wait either my car in peices waiting for there new home
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 10-27-2006, 12:08 PM   #5961
The Evicerator
You guys won't be disappointed in your BMI Cyclones!
They all ran great for us in Vegas!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 10-27-2006, 02:37 PM   #5962
jag88's Avatar
To make an already great chassis a little bit better I found that if you file the radius in the battery slot square then the pack will sit all the way down in the slot. You only have to do the negative battery end of each slot. Small detail I know but they all add up.
jag88 is offline   Reply With Quote
Old 10-27-2006, 03:29 PM   #5963
Super Moderator
Marcos.J's Avatar
Trader Rating: 151 (100%+)
here it is Jason ,ready for sunday
the car weighs 2 lbs 11 ounces (with out the body)
Old 10-27-2006, 05:22 PM   #5964
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Looking Good
Looking Good...........MJ
I want to see the 4.5 with the 4 cell in action @ Superior
Have fun @ B&B
Later,
E
RED-LINE M03 is offline   Reply With Quote
Old 10-27-2006, 05:47 PM   #5965
Super Moderator
Marcos.J's Avatar
Have fun @ B&B
Later,
E
you will
Old 10-28-2006, 09:09 AM   #5966
Mission_carbon's Avatar
Rite e o!
Picked up my Cyclone todaay, and i ammm very impressed.
Come across a problem tho with the rear Diff, i try and fit it to the bulkheads and it seems to "wide" one side will fit in and the other wont, also the diff seems to wobble left and right, i have tightend the diff, but no luck,
What you think?
Thanks,
Willz
Mission_carbon is offline   Reply With Quote
Old 10-28-2006, 09:12 AM   #5967
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Make sure u have the rite shims on the outdrives and that the bearing holders are lined up correctly,dont worry about the diff pulley they all do it,its not a problem.
Have fun
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 10-28-2006, 09:22 AM   #5968
Skill's Avatar
Also make sure that the bearings are all the way onto the diff outdrives, the fitting is quite tight so it might be that it's not quite all the way on.
Skill is offline   Reply With Quote
Old 10-28-2006, 10:42 AM   #5969
Aurra Sing's Avatar
I'd like to post some pics of my beloved Cyclone as well.
Fairly standard,
The VFS heat sink is made by Alex racing, the motor heat sink is made by a Hong Kong company called TOPCAD and that is a MMR diode behind it.
The Andy moore World Champion edition looks nice,
But I think I will simply upgrade my Cyclone rather than buy a new kit.
Aurra Sing is offline   Reply With Quote
Old 10-28-2006, 10:50 AM   #5970
ngo8's Avatar
Originally Posted by Mission_carbon
Rite e o!
What you think?
Thanks,
Willz
if you are talking about the pulley wobble thats normal you cant really do anything about that but ifyou are talking about the diff in beetwen the bulkheads you have add shims hope it helps.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
