Old 10-17-2006, 09:44 AM   #5836
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
We put up a few setups from Vegas using the BMI kit on Cyclone Depot after vegas, the link is in my sig. There is also the editiable pdf there as well.
I have added a few more setups, and I have another to add. I just have not had time yet. As always if anyone would like to contribute setups... setups@cyclonedepot.com
It would also be pretty cool to have some reviews of all the new cyclone goodies that are out on the market.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 10-17-2006, 10:02 AM   #5837
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Originally Posted by L.Fairtrace
Anyone have an editable setup sheet. I'll get to work if you do
http://www.gearchart.com/setup/setup...lone_blank.pdf
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 10-17-2006, 10:40 AM   #5838
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Ok heres my carpet setup. Still working on it but its pretty good for a starting point.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 10-17-2006, 11:00 AM   #5839
RaceAce701's Avatar
Trader Rating: 83 (99%+)
what size tires were you running
im tryin to figure out what gearing to run
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 10-17-2006, 11:55 AM   #5840
with that gearing 56.2 tires. The droop is 1 mm uptravel, front and rear.
Old 10-17-2006, 12:00 PM   #5841
RaceAce701's Avatar
Alex "ACE" Kubilus
ACE design works
Old 10-17-2006, 05:05 PM   #5842
JimmyMac's Avatar
Thanks for the post Larry. The setup is actually very close to what I'm running without the BMI chassis (yet... ). But I'm running XRay 30lb spring up front and HPI Red 22.4lb rear. Same piston, oil wt. (except I don't run foam in bladder), same ride height, camber, caster, toe.. etc. Man... I can't wait for the BMI chassis!!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 10-17-2006, 06:55 PM   #5843
Static_racing's Avatar
Anyone know where I can get a Surikarn edition at a reasonable price?
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 10-17-2006, 07:47 PM   #5844
protc3's Avatar
in the same place you can find a Sasquatch let me know if you find one
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-17-2006, 07:58 PM   #5845
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
how do you measure uptravel 1mm? thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 10-17-2006, 08:30 PM   #5846
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
lol
Old 10-17-2006, 09:05 PM   #5847
JimmyMac's Avatar
I'm not Larry, but what that means is the chassis will raise up 1mm before the tires lift off the ground. So if the rear ride height was say... 5mm. You lift up the chassis 1mm, the tires will just start to lift up off the ground (ride height guage would read 6mm at this point).
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 10-17-2006, 09:14 PM   #5848
Guo Chean's Avatar
oh ya this is te most easy way to do. thanks
Old 10-17-2006, 09:15 PM   #5849
Guo Chean's Avatar
oh ya this is the most easy way to do. thanks
Old 10-17-2006, 10:03 PM   #5850
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Heres the ticket on the 2 different ways of measuring suspension extension.
Rubber Tires: Measure the height of the a-arm relative to the bottom of the chassis. Either by placing the chassis on a flat surface and using a ride height gauge, or by using the kit included tool. In either situation more suspension extension (droop screws unscrewed) is a numericall lower number.
Foam Tires: Measure the difference in ride height change needed until the droop screws limite extension. First measure ride height, then keep lifting on the chassis until the tires lift off the ground. the difference between this height and ride height is the droop. as in previous examples: ride height is 5mm, so you lift up the chassis to 6mm, which is 6-5=1mm droop.
Each method fits the situation. With rubber tires its best to measure the suspension itself since the tires are soft and deform, thereby changing diameters. So when you use the ride height method it is inaccurate to gauge when the tire lifts off the ground. Furthermore rubber tire diameter barely changes with wear (at least under race conditions).
The problem with measuring the suspension is when the tire sizes change. As the tire wears you have to adjust the ride height, which means you also need to adjuster your droop to keep the same amount of relative droop. Furthermore foam tires dont deflect much at all, so it is easy to tell when the tire lifts off the ground. in this way it is easy to keep the droop consistent for varying tire sizes.
Simply put: use the tool with rubber tires, and the lift method for foams.
floodo1 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
