Hot Bodies Cyclone
#5776
Originally Posted by DENNIS STORTI
here some pics of my BMI CYCLONE
I was thinking of trying one this season... How do u like so far??
#5777
I have been using Precision for 3 years....have had only one problem when it was a little late arriving....otherwise no problems at all.I find it cheaper that most US shops because of postage to Australia.....If you DO have a problem email James at Precision or ring him and he will fix it.As stated before...this type of forum is only a last resort if you have a problem....it can give a lot of negitive feedback that might not be warranted...so be fair ...not only to Precision but any shop..... use this forum as a last resort.
From a business owner...not RC
#5778
Originally Posted by bigair78
1 x HB70743 (Direct Layshaft)
1 x HB70711 (Spur Gear Hub)
2 x HB70725 (16T Direct Pulley)
Josh
#5780
My grub screws seem to rub the metal plate on the right side of the car unless I put a washer in between the bearing and the pulley on each side. But when I do that it feels like it might be binding. With that shaft and pulleys are you suppose to have spacers in between?
#5781
just to make it 2 for & 2 against Precision RC i'll weigh in that i've had perfect exeriences with them.
As it seems with all foreign (to the US) sellers its best to double check stock before ordering. When doing that i've never had a problem with ANY of the major oversees seller.
but seriously, post a thread if you want to discuss this
#5782
Originally Posted by KilRuf
Nothing but good service from Precision RC for the past few years....
Reggie, when you coming back to the Wood? I'll hook ya up with a starting setup whenever you come over this way..
#5783
where did you get that battery strap from?
el
el
Originally Posted by John Doucakis
some pics of my car.
could work as wallpaper.
#5787
Originally Posted by lawtonlosi
Try centering the shaft in the bearings, and then adjust the pulleys.
#5790
Originally Posted by bxpitbull
Thats for real on those pics but, what program did he use to get his pics to be that big, all that resolution and is small enuf to be uploaded? Thats what I want to know.
