Old 10-08-2006, 01:28 PM   #5701
John Doucakis's Avatar
some pics of my car.
could work as wallpaper.
John Doucakis is offline   Reply With Quote
Old 10-08-2006, 01:57 PM   #5702
Ballsie's Avatar
Absolutely awesome pics mate
And where did you get the new v2 endbell ?
Ballsie is offline   Reply With Quote
Old 10-08-2006, 03:09 PM   #5703
Trader Rating: 22 (100%+)
Originally Posted by protc3
post your setup so we can take a look at it.we can better help you then.
Car is set as per Andy Moore worlds setup with the difference being I am using 0.5mm anti squat in the rear and using standard shock pistons with 45w oil in front& 40w oil in rear.
Also using 19lbs springs front & rear.
I think you will be able to help me out Jason seeing the glowing appraisals about your carpet chassis.
bjspinner is offline   Reply With Quote
Old 10-08-2006, 03:14 PM   #5704
protc3's Avatar
can you post a link to it for me?i cant find andy's setup fromt the worlds
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-08-2006, 03:19 PM   #5705
protc3's Avatar
first thing i would try is softer springs and oil.the stiff springs seemed to make my car twitchy and scrub off speed because the car was not rolling and absorbing enough of the weight transfer.on a fast flowing track i ran 13.5lb. springs with 35 wt front oil and 30 wt. rear.for a tight track i normally bumped up the front spring tension a little and left the rear springs the same.i always stick with the same oil for our tracks.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-08-2006, 03:38 PM   #5706
My computer is crap it dont like doing that.
front
camber -1.5
castor 4
ride height 5.0
droop 5.5
spool
stab/bar 1.4
shock/pos 2 on tower 1 on arms
1.2mm shock piston 45w oil 19lbs springs
2mm under both pivot blocks (2.5 front block)
camber link pos 1 with 2mm spacer on bulkhead
Rear
camber -1.5
ride height 5.5
droop 5.5
stab/bar 1.2
shock/pos 3 on tower 2 on arms
1.2mm shock piston 40w oil 19lbs springs
camber link pos 1 on bulkhead 2 on upright no spacers
2.5mm under front/2mm rear pivot blocks (antisquat) 3 deg toe
Ackerman 2mm
Forgot Ihad changed the pivot block spacings from Andy's setup as he ran 1.5mm under pivot blocks.
Thanks Jason
Old 10-08-2006, 04:10 PM   #5707
protc3's Avatar
i would run 1.5mm shims under the blocks front and rear.try maybe 15 lb. springs all around with 35 wt front oil and 30 wt rear.if you need more entry steering try the anti squat.i also run a 1mm shim under the ballstud on the rear links and a 2.5mm under the front studs.which tires are you running?
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-08-2006, 05:22 PM   #5708
tc3 racer sc's Avatar
u can find the link under hpi racing.com click on the cyclone with andy
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 10-08-2006, 05:30 PM   #5709
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
You can also find it on our site Cyclone Depot along with many other setups for the car.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 10-08-2006, 11:22 PM   #5710
Thanks Ballsie.
Regarding the V2 endbell. I just happened to be at the right place at the right time, nothing more.
Old 10-08-2006, 11:42 PM   #5711
Rubber tires
Are you saying that by lowering the roll centre I will hold more corner speed?
I thought that would increase the roll into the corner hence more speed lost.
Have always liked a car with alot of steering.
Old 10-09-2006, 03:19 AM   #5712
protc3's Avatar
actually yes,on asphalt roll is good.if you generate too much side bite,the car will bind up.what you are looking for is the same amount of steering with a smoother less twitchey feel.this will also free the car up where you feel it is binding up in the corner and scrubbing speed.that loss of cornerspeed you are experiencing is too much side bite.give it a whirl and let me know how it goes.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-09-2006, 08:25 AM   #5713
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
front
camber -1.5
castor 4
ride height 5.0
droop 5.5
spool
stab/bar 1.4
Rear
camber -1.5
ride height 5.5
droop 5.5
stab/bar 1.2
Ackerman 2mm
Thanks Jason
normally 2mm shim under the block only used on high traction, high speed track, high track temp and modified motor will be only used this setup it help to decrease your tire overheat faster.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 10-09-2006, 08:52 AM   #5714
I'll have my setup posted tonight from this weekend. It was very hooked up. Just too much driver error.
Old 10-09-2006, 09:26 AM   #5715
Ballsie's Avatar
Originally Posted by John Doucakis
Thanks Ballsie.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
