Old 10-01-2006, 06:00 PM   #5626
andyh's Avatar
Default Andy on 5th Gear
Andy on 5th Gear
http://video.google.co.uk/videoplay?...92491462766951
http://fifthgear.five.tv/jsp/5gmain....ion=On%20track
andyh is offline   Reply With Quote
Old 10-01-2006, 07:13 PM   #5627
does anyone know where i can get surikarn parts ?
zinger77 is offline   Reply With Quote
Old 10-01-2006, 07:16 PM   #5628
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
Originally Posted by lawtonlosi
Macros, got it and it will be up shortly. Thanks man.
Thanks for the kind words Jason. Once I get some cash together I will be getting the carpet chassis before I hit carpet. I gotta wait a bit on that though.
thanks!
Old 10-01-2006, 07:40 PM   #5629
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Depending on what you need you may have to hit up a few places.
Speedtech RC
Stormer Hobbies
Champs RC - Tokyo
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 10-01-2006, 08:15 PM   #5630
bigair78's Avatar
OK, I bought me a Cyclone S recently. I am upgrading parts as I break them. I need to know the stock number for some CVD's. These dogbones are driven me nuts. The next thing is some good turnbuckles and cups. I am ordering the spool and some other stuff. Do I need aluminum pivot blocks?
Anything else that you guys could think of that a new cyclone racer would need. Do I need a belt tensioner?
Thanks in advance.
Josh
bigair78 is offline   Reply With Quote
Old 10-01-2006, 08:23 PM   #5631
robk's Avatar
Trader Rating: 22 (100%+)
Scuba steve-
Why so much droop in the foam tire setup?
robk is online now   Reply With Quote
Old 10-01-2006, 08:28 PM   #5632
The Evicerator
robk- That's just the reading on the droop gauge that I used as a baseline...
that should translate to 2 mm uptravel from ride height both front and rear.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 10-01-2006, 08:30 PM   #5633
robk's Avatar
thanks!!
Old 10-01-2006, 08:38 PM   #5634
Steve-
How do you do that calculation?
Im trying to get caught up with the times.
Maclin | VP-Pro USA
Old 10-01-2006, 08:48 PM   #5635
The Evicerator
Well, there really isn't a calculation... it is dependant on your ride height and your tire size...
basically what I do is set my ride height (say 4.5 mm in the rear for example)
Then I will slide the gauge under the chassis until the car is 6.5mm high in the rear and set the droops so that the tires just come out of contact with the flat board.
Then I will take the tires off and check to see what the droop is set to via the gauge and generally try to keep that as a good reference and keep using the same sized tires... which is easy to do if you run new tires every run... but most people will be using used tires...so I recommend the ride-height gauge method.
Steve Weiss
Old 10-01-2006, 09:06 PM   #5636
Ah ok. So its mainly just a thing for foams to keep your setting consistant with tire wear. Gotcha. Thanks man.
Maclin | VP-Pro USA
Old 10-01-2006, 09:30 PM   #5637
Barry W's Avatar
Anyone have a good starter setup sheet for stock foam?
Corally Carpet Spec RDX
CRC Bloody Carpet Knife 3.2R
Tamiya M-04
www.pmhobbycraft.ca
Barry W is offline   Reply With Quote
Old 10-02-2006, 07:59 AM   #5638
I havent ran mine on carpet yet, but some have. Right now the only ones I know of were for the bmi conversion, you may be able to use that as a starting point. There are some setups posted on the Cyclone Depot site which is linked in my sig, or you can flip back a few pages and look for a post by Tim Stamper. He posted a setup, I think it was for stock, back there.
Maclin | VP-Pro USA
Old 10-02-2006, 09:19 AM   #5639
RaceAce701's Avatar
Trader Rating: 84 (99%+)
for carpet us haras setup from last years icc race
ill post mine later 2 day
mine is a few pages aback
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 10-02-2006, 09:22 AM   #5640
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
the Hara foam setup would get you close, although he was running Mod, and the bite might not be the same where you are... i would probably go lighter on the swaybars and give it a shot.
i am in the process of rebuilding my car with the BMI chassis... very nice piece! it is waaay stiffer than the stock set, even without the stiffener posts installed. hope to start running foams more soon, so should be good there...
Wes
Wes
Team Novak
Turbonium is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
