Old 09-21-2006, 02:16 AM   #5386
hlj
Just a quick question,
what kind of gear ratio should i run on my cyclone with a 6x1 Reedy Ti and largeish outdoor track?
i'm guessing 7.5:1? or 8.5:1?
hlj is offline   Reply With Quote
Old 09-21-2006, 02:29 AM   #5387
bxpitbull's Avatar
8.75 or 9 flat. Those other two aint gonna do it.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 09-21-2006, 02:47 AM   #5388
dawgmeat's Avatar
Originally Posted by lawtonlosi
This may be a silly questions, but does the mark pointing forward on the diff accentric put more or less tension on the belt?
greta question I was thinking the same thing
dawgmeat is offline   Reply With Quote
Old 09-21-2006, 02:58 AM   #5389
On the rear diff yes when the mark is forward the belt will be at its tightest but the front belt will be at its loosest when the mark is forward on the front diff.
LEE UK is offline   Reply With Quote
Old 09-21-2006, 04:07 AM   #5390
AngryAsian's Avatar
The easiest way to tell is to take the ecentric holders out. It's pretty obvious where there's more material in them to space the diff out (thus tightening the belt..)
Rayman - generally speaking. More droop equals more grip as that end of the car can roll more and place more weight on the ourside wheel. Grip is a function of friciton co-efficient and weight.
In your case - more droop on the front will create more grip.
For the front:
Softer springs
More droop
Softer damping
For the rear:
Harder springs
Less droop
Harder damping
Can't really advise you on what I use. It's very much dependant on the track surface. Try the kit settings and increase the droop a little at a time.
AngryAsian is offline   Reply With Quote
Old 09-21-2006, 04:14 AM   #5391
i dont entirely agree with the above statement, i have found that running more droop on the rear will give you more steering due to the weight being allowed to transfer to the front when cornering, and vice versa.
Old 09-21-2006, 04:20 AM   #5392
i no this has probley been asked alot
but what is the biggest spur smalest pinion combo on the cyclone in 64dp and also in 48dp if anyone knows it??
oh and also i dont realy wana dremal up my bulkheads...
thanks bob
bob33 is offline   Reply With Quote
Old 09-21-2006, 04:21 AM   #5393
81- 48dp
110 i think 64dp
Old 09-21-2006, 04:23 AM   #5394
Originally Posted by LEE UK
81- 48dp
110 i think 64dp
thanks buddy do u no the smalest pinion u can get to mesh with them too?
Old 09-21-2006, 05:10 AM   #5395
AngryAsian's Avatar
It's tough commenting on things like this. You are totally correct. More rear droop does have a big effect on static steering. Just as more front droop can decrease steering under acceleration...
But there is a need to generalise these situations. Otherwise we would be here forever.
Old 09-21-2006, 05:56 AM   #5396
i know exactly what you mean, what i would suggest is set the droop on the car to 5 all round, try it and then try 1mm up or down front and rear (1 at a time though) and see what happens.
this is better than saying do this and do that.
Old 09-21-2006, 06:18 AM   #5397
miniracer's Avatar
Originally Posted by rayman
How much front and rear droop do you set for more steering and what spring combo? I dont have a setup board so I'll have to eyeball the grub screws.
place your kit on a glass top and use your ride height gauge to measure from the tip of the arms to the glass. same effect as using a droop gauge.
miniracer is offline   Reply With Quote
Old 09-21-2006, 06:31 AM   #5398
dizzy1's Avatar
Trader Rating: 24 (100%+)
lawtonHOTBODIES!-the mark on the diff eccentrics is the thickest side of the eccentric. If its pointing away from the center of the car, the belt tension would be loose. Pointing it toward the center of the car, the belt tension is at its maximum. Of course you could go with it pointing up or down to adjust it in between and depending if you rotate it around the top or around the bottom it also affects the diff height by a 1 mm-1.5mm.
All about that Hot Pockets again! Woot Woot! Tried the Russian rocket but tired of the 'part of the week'. All gold everything '15 only made a weekend, such a numb and overpriced car!
Team Hot Bodies- Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 09-21-2006, 06:42 AM   #5399
has anyone tried running the diffs at different heights and what have you found?
Old 09-21-2006, 07:32 AM   #5400
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Thanks everyone for the replies.
I will try to get my site with some of this stuff on it over the weekend early next week. I gotta wrench on my car this week though.
I had been wondering about loosening up the belt some for stock and 19t.
As for diff height, I know on my jrxs that was a good tuning option.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
