Old 09-16-2006, 10:27 AM   #5341
schreff's Avatar
Send a message via AIM to schreff
Originally Posted by tandman
Thanks EA......Shreff are you going to have a setup for stock foam for the Cyclone with the BMI kit???
I will most definitely have a setup for the car.
I'll post it, most likely, when I get back from Vegas. Since HB doesn't have an editable PDF like Xray does, I have to fill it out and scan it.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 09-16-2006, 11:00 AM   #5342
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Good luck in Vegas. remember what goes on in vegas, stays in vegas!!!
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 09-16-2006, 11:13 AM   #5343
protc3's Avatar
Originally Posted by bigb11
Jason, when will it be on the website?
i will have it on there right after the vegas race.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-16-2006, 11:29 AM   #5344
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Ditto the comments made,good luck to all of those attending the vegas race! Especailly those laying it down with eXpress POWER!!
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 09-16-2006, 02:34 PM   #5345
need some help dudes,
Ive been running my cyclone for a while now, in the beginers class, id like to move up to the next class wich happens to be 19t, im going to pick a new motor up tomorrow.
Obviously im gona have to make some changes, the kit oneways will probably have to go, its a small high grip track were we run on slicks with addative. i guess the spool would be the fav option for a small twisty track were im guessing lap times will be aroung 10 secs, so if i use a spool what changes need to be made from my oneway set up? and can any one point me in the direction of a good spool that doesnt wear out at an alarming rate.and were abouts should i start with gearing? my lhs has the C2, the orion V2 and the money motor so if you could recomend a starting ratio for each of these i would be very gratefull as i dont know wich one ill buy yet!
Thanks in advance
thanks in advance
Xrayskid is offline   Reply With Quote
Old 09-16-2006, 02:43 PM   #5346
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
C2 wouldnt be bad but a KD based 19t would be better. It gets a little warmer but they are dang fast. If you use a kit spool, make sure to keep it well greased. What hurt mine was a few hard hits that spread out the aliminum. As for setup, I would start with using only on shim under the bellcrank ballstuds. Im a using the kit toe blocks, 4 deg castor in the front, 40wt oil with kit pistons, ae silvers front and rear. I have my rear link inside on the hub and all the way inside on the bulkhead, and the front I have it two from the outside. I have about 1.5mm of shims under the toe blocks.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 09-16-2006, 11:36 PM   #5347
tandman's Avatar
Send a message via Yahoo to tandman
Shreff....I will be in Vegas for the IIC.....I will need the setup info then if possible, I am building my BMI Cyclone wednesday morning
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist Fantom Racing
Team Sweepracing
tandman is offline   Reply With Quote
Old 09-17-2006, 12:47 AM   #5348
NM. I had a question about team almighty but my account shows my order as delivered.. Ill check my mail in the morning.
Maclin | VP-Pro USA
Old 09-17-2006, 08:19 AM   #5349
hi,
can any one help me with the effects of the front pivot block, am i right in thinking the higer the number the higer the level of front grip and more steering?
Old 09-17-2006, 01:31 PM   #5350
had the first run with the cyclone hara..
all i can say is fast, easy to drive and stable.
but i had a few probs to say the lest
rite first prob i bent a black front drive shaft (i dont no what it was as it was a od one in the car wen i got it) then i snaped a front purple drive shaft again i dont no what thta are but all other 2 are the purple ones... so could u tell me what ones to get??
i had a prob with the rear diff as in it keeps losining and it has got quite alot of play in the pully what do i do.
and the rear belt keeps turning over withch way do i turn the bearing holders to tighten the belt up?
thanks much apretiated
and i realy like the cyclone
bob33 is offline   Reply With Quote
Old 09-17-2006, 01:44 PM   #5351
Skill's Avatar
Get the Ver.2 44mm Steel driveshafts for the front of the car and you shouldn't have any more problems.
Put a bit of thread lock onto the diff screw and nut and this should stop it loosening. All the diffs have play in the pulley, this is normal and doesn't affect the performance.
Couldn't tell you off hand which way to turn the bearing holders, just turn them one way and see what happens, if it makes the belt looser turn it the other way
Skill is offline   Reply With Quote
Old 09-17-2006, 02:05 PM   #5352
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
is there anywhere on the net that still has some surikarn edition cars for sale ?
wallstreet is offline   Reply With Quote
Old 09-17-2006, 02:06 PM   #5353
Crashmaster's Avatar
Has to be said, the cyclone was emense today Bob, never known anything quite like it!! But the 415 will return, hopefully. lol
Crashmaster is offline   Reply With Quote
Old 09-17-2006, 02:30 PM   #5354
bigb11's Avatar
eri distrubing or ultimate hobbies.
Old 09-17-2006, 03:17 PM   #5355
dawgmeat's Avatar
running stock chassis on foam carpet the hardest spring I have are X-ray dark blue and purple should I increase the shock oil up to 60 or 70?
dawgmeat is online now   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
