Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 09-01-2006, 08:34 AM
  #5176
DavidAlford's Avatar
Trader Rating: 32 (100%+)
EA got the idea from Billy in Memphis
When Enid starts going big time in the next few months you might have to make a trip EA. More rubber tire fun. I know how much you like rubber tires
DavidAlford is offline
Old 09-01-2006, 04:40 PM
  #5177
Anyone tryed the Yokomo BD battery cages? very simple...they fit into the battery slots and contain the cells...
Barger is offline
Old 09-01-2006, 04:43 PM
  #5178
rc-zombies's Avatar
I have a set..they do not fit the cyclone battery slots..
you have to do some extensive dremel work to make them work.
rc-zombies is offline
Old 09-01-2006, 04:52 PM
  #5179
CarlosG.'s Avatar
Please, could someone help me? I need to know a good starting gear ratio for the Cyclone S. The stock spur gear was to small. What spur and pinion combo works in the car. I will be running on asphalt my first time in a long while with a TC. I have been mainly running 12th scale. I have seen the setups for mod, but I have not seen setups for stock. The motor that is going to be used is CO27. Any help would be greatly appreciated. Thanks again.
CarlosG. is offline
Old 09-01-2006, 08:14 PM
  #5180
2-Bad's Avatar
Trader Rating: 24 (100%+)
I heard you were getting a red car Bob.... not true
2-Bad is offline
Old 09-01-2006, 08:53 PM
  #5181
SchuMi2's Avatar
Trader Rating: 34 (100%+)
You heard correctly 2-Bad.....Barger will be piloting a red car as of next week
SchuMi2 is offline
Old 09-01-2006, 10:37 PM
  #5182
floodo1's Avatar
Originally Posted by Skill
Leaning the shocks inwards tends to create more grip and allows the car to roll more in the corners.
the car rolls because as you lean the shock in you decrease the stiffness of the shock, both oil and spring. you also decrease the linearity (softer initially, then ramps up).
this can be a valuable tool for bumps. it can also simulate a softer spring to a degree, since the spring may be initially as soft as the next step spring, but get a little stiffer with travel.
floodo1 is offline
Old 09-02-2006, 10:27 AM
  #5183
AZDemille's Avatar
Just completed building my Cyclone. The kit comes with a 100t spur. I'm using a Novak Brushless 4.5. Novak recommends running a final of 9.75-10..25 with this motor. Here is my problem: With the 100t spur you have to run a 25t pinion to get a final of 9.75. At 25/100 the pinion does not get even close to mesh up. I can get to 9.75 at 32/128, but I don't know if the large spur would clear the rear graphite brace. Who else is running a Novak 4.5 in this car and what gear ratio are you running? Thanks so much.
Ron
AZDemille is offline
Old 09-02-2006, 10:41 AM
  #5184
Ron
108 is the largest you can go on the cyclone dont know what you should run with the 4.5 but I have seen it posted at around 10 to 1
no1uno is offline
Old 09-02-2006, 11:26 AM
  #5185
AZDemille's Avatar
Thanks Dave.
Do you know if the aluminum heatsink bulkhead brace allows for a larger spur?
Old 09-02-2006, 11:46 AM
  #5186
108 is the biggest you can get on the car without some work. 110 pokes out the bottom just enough to make it not worth trying. With the new aluminum heatsink you have no problem with either gear.
Old 09-02-2006, 06:43 PM
  #5187
jag88's Avatar
What he said.
jag88 is offline
Old 09-02-2006, 08:16 PM
  #5188
Welcome to the gun show!
racenut123 is offline
  #5189
bigair78's Avatar
what is the model number on this new heat sink? will this also be an issue with the cyclone s?
can you run 48p spurs in a cyclone?
bigair78 is offline
Old 09-02-2006, 08:42 PM
  #5190
JoeyE's Avatar
Trader Rating: 45 (100%+)
You can run 48P spurs in a cyclone.
Heatsink
HB61391 Blue
HB61392 Purple
JoeyE is offline
