Old 08-14-2006, 08:25 PM   #4981
Can anyone tell wats the difference between 2 holes and 3 holes damper pistons? anyone tested it before?
yakuza is offline   Reply With Quote
Old 08-15-2006, 02:40 PM   #4982
sonic31's Avatar
yakuza, the difference between 2 hole and 3 hole pistons is that the oil travels faster as there are more holes or bigger holes.
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 08-15-2006, 04:54 PM   #4983
chicmagnet's Avatar
with 2 holes pistons, the dampers is stiffer than the 3 holes pistons.
STRAIGHT LTD.
chicmagnet is offline   Reply With Quote
Old 08-15-2006, 06:55 PM   #4984
chicmagnet,sonic31.. so what kind of piston are you guys using? satisfied with your setup? currently i'm still using stock 2 holes piston, but i still found out that the dampers are still very stiff even though i use 35 shock oil for the rear dampers..
Old 08-15-2006, 09:24 PM   #4985
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
them using more softer shock oil will reduce the stiffer of your shock. 3 hole piston wont help much
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 08-15-2006, 11:45 PM   #4986
wagonman72's Avatar
Originally Posted by bigb11
have not built it yet. it will cost about $500.00 plus to upgrade to a regular cyclone.
Any pics yet?
wagonman72 is offline   Reply With Quote
Old 08-16-2006, 02:35 AM   #4987
rayman's Avatar
Anyone run HB Cyclone S? I heard its really good and very affordable. First impressions? Can it take tamiya metric spurs(415,tao5) because I only have sets of metric pinions and really dont want to buy sets of 64pitch pinions. Thanks.
rayman is offline   Reply With Quote
Old 08-16-2006, 06:42 AM   #4988
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Yes, I have been reviewing one for a magazine. The car is fantastic - just planted in Stock Class and is fairly competitive too in Modified. In fact, with a Monster Stock motor in the Cyclone S, I was only a few tenths slower then the top Modified guy (Mi2EC) in fastest lap, and quicker over the run!!
The thing handles great, very smooth drivetrain too.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 08-16-2006, 07:10 AM   #4989
pete68's Avatar
Default cyclone
need info
what do u guy's think about the car running on carpet and what the most common parts that break!!
thanks!!
Pete68
Yokomo BD7-15&16/YZ2 HOBBYWING/SMC/FUTABA/XPERT/MRT-PTX
pete68 is offline   Reply With Quote
Old 08-16-2006, 07:39 AM   #4990
RaceAce701's Avatar
Trader Rating: 83 (99%+)
I race mine on carpet and love it. Its just as fast as the corally and x rays.
U want 2 get some castor blocks and spindles ands maybe a pair of arms
and some ball studs
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 08-16-2006, 08:32 AM   #4991
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
i have gone back to the kit 2 hole .after trying the 3 hole the weight transfer was to upsetting on carpet with rubbers ,even with a diff up front we spent most of the night trying to stabelise it .very tight track
had 40wt oil front & rear , springs pink`s front ,silver rear
now gone 40 rear 50 front 2 hole all round ,i forgot this car has a very short wheelbase , so you can go to soft easily
i was only 2 tenth`s a lap of track record which for my old age is not bad in 27t
did try the kit setup ,it was pigging awfull
so i have copyied Hara indoor rubber setup exc;;spool.one way ,roll bars
but every thing else the same roll centre plates shock positions
on a side note HARA nearly allways have 2 hole piston indoor or out !!
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 08-16-2006, 06:58 PM   #4992
Thanks for the tip.. i just finished setup my car last night, with all round 2 hole 1.2 piston, 35wt front and 30wt rear, springs white in front and gold at rear.. 5.5 droop, running on spool on asphalt, i'll give it a try tonight, will let you know how is it.
i noticed that our car (cyclone) are actually quite stiff, so i prefer softer shock oil... and 1 thing Jolly, did u notice that Andrew Moore's setup from Italy was actually very soft too? i was suprised,and seems that he drove the car comfortably
Old 08-16-2006, 09:02 PM   #4993
rayman's Avatar
I see. With a $150 price tag in my area it really is a good deal. Looks like a direct competitor for the Tao5. I wish all companies had this kind of package. Something that runs great without breaking the bank. I think the only thing I would change are the the plastic shocks and dogbones.
Old 08-16-2006, 11:12 PM   #4994
Roger's Avatar
I just got a used cyclone without a manual. I have a few questions for this car (I prodominatly race mostly 1/10th and 1/8th on-road). Are hpi pro4 parts ( steering knuckles, arms, etc..... ) compatable for the cyclone ? Also, where can I find a spool for this awesome ride. Thanks guys.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 08-16-2006, 11:16 PM   #4995
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Hi, where can i find a set up for the cyclone for on carpet with foam tires? I was told to use hara's set up but i can find one.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
