Old 08-01-2006, 01:52 PM   #4876
The Evicerator
*pokes his head in and looks around a bit*
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 08-01-2006, 02:10 PM   #4877
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Its a steve
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 08-01-2006, 02:54 PM   #4878
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default Cyclone Rear Diff
In Coral Springs, FL. Its me a a friend with a Cyclone, and a lots of Yokomo BD's LCGs, etc. My friend had the same problem with his stock plastic Yok BD rear diff, and when he rebuit it, he CA glued the rings to the outdrives, and has never had diff melt downs again...has anyone heard of this "trick"? Just re-ordered new diff set from stormer hobbies...speedtech has the aluminum ones comming in by the weekend. I just want to make sure they don't melt on me again! I followed the book, and it seems they just start getting loose...and then if you tighten a little more, they fry!!!
yyhayyim is offline   Reply With Quote
Old 08-01-2006, 06:53 PM   #4879
is anyone here can give me a help to setup the car on carpet?... What shock oil and piston hole should i use?... i never played on carpet before
mun fei is offline   Reply With Quote
Old 08-01-2006, 07:06 PM   #4880
AngryAsian's Avatar
Originally Posted by JBRacing
I think that the problem isn't going to be bottoming out as much as going over rails/dividers and/or corner dots/markers…..
I would suggest sticking with the 108 and even adding a small and narrow piece of masking-tape on the bottom in order to keep small stones away from the spur.
Please DON'T use tape there... Tape actually sticks small stones/grit right under the spur where it hurts most. The cut-out there actually releases anything that's made its way there..
And besides - better you take the edges of a few teeth, than to wedge a small stone in there - totally ruining two teeth, and having it ruin your pinion too..
AngryAsian is offline   Reply With Quote
Old 08-01-2006, 08:59 PM   #4881
tandman's Avatar
Send a message via Yahoo to tandman
Mun fei; 50 wt. HPI in the front, stock pistons and 33lb xray springs, 40 wt. HPI in the rear, stock pistons and 28lb xray springs, thats what I have run for 19 turn foam on carpet.
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks
tandman is offline   Reply With Quote
Old 08-01-2006, 09:18 PM   #4882
i got it.... "I have run for 19 turn foam on carpet" which means u used foam tires? .... what about Sorex 20? ...
Old 08-02-2006, 12:15 AM   #4883
Bing's Avatar
I found this interesting site. See how HARA built his Cyclone.
Click Here
Bing is offline   Reply With Quote
Old 08-02-2006, 12:19 AM   #4884
XrayFK's Avatar
Click Here
It's been up for a while, it's in the thread from ways back.
XrayFK is offline   Reply With Quote
Old 08-02-2006, 07:21 AM   #4885
Has anyone ever seen blades in stock anywhere?
Maclin | VP-Pro USA
Old 08-02-2006, 08:58 AM   #4886
dizzy1's Avatar
Trader Rating: 24 (100%+)
Good luck getting the blades or alot of the other parts. Local shops can't get the blades, aluminum diff or the 1 piece spool and even the US online shops have been out of stock for months. Parts support has been poor so far, reminds me of the Pro4 when it first came out, it took months for some parts to be available.
Steve or Thad, please tell the bosses to get the parts out to the shops!
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 08-02-2006, 09:17 AM   #4887
XrayFK's Avatar
If you want, I can pick up some blades for you here before I return to the states.
Just shoot me a PM
Old 08-02-2006, 09:26 AM   #4888
XrayFK you have pm!
Maclin | VP-Pro USA
Old 08-02-2006, 12:17 PM   #4889
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Click Here
this web site had the hara tips built on cyclone long time ago
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 08-04-2006, 06:07 AM   #4890
yyhayyim's Avatar
Thumbs up Cyclone Dog Bones
Hey fellas! My Cyclone's FR and FL dog bones have bent, and its time to replace them. They are the regular Cyclone simple/stock bones(which seem very weak). Will the pro 4 aluminum dog bones work on this car? If not, which dog bones do you recommend that are stronger and have longer life(with part numbers, please)
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
