Old 07-24-2006, 09:49 PM   #4741
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
I also ran the 1.1mm 2 hole piston on my Pro4
Old 07-24-2006, 10:29 PM   #4742
Originally Posted by Marcos.J
what class are you running?
Hi Marcos, currently, i'm just running 23t stock.. And 1 thing, I've added 2mm shimms underneath the bulkheads front and rear, just like everyone did in Malaysia, is tat alright? I understand tat is for antisquat purpose. After i added those shimms, i found my car more stable but very difficult while entering corners, this is what happen...
mun fei is offline   Reply With Quote
Old 07-24-2006, 10:59 PM   #4743
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
which track a you runing? HPC or SS19?
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 07-24-2006, 11:03 PM   #4744
Guo Chean's Avatar
shims under the pivot block is for you to adjust to reduce you tire overheated in 5min it depends on track condition. if not mistake it call roll center the more you put the more traction you gain it work on low traction track, and the less you put the less traction you will have it work on high traction track
Old 07-24-2006, 11:16 PM   #4745
XrayFK's Avatar
No one has asked, but what tires/inserts are you running? If you have the wrong tires, it won't matter how you setup your car. I think that if the car is handling so horribly that it must be a tire choice error, unless you are a horrible, horrible driver
XrayFK is offline   Reply With Quote
Old 07-24-2006, 11:59 PM   #4746
Guo Chean, I'm running on SS19.. we had a race on last Sunday, open 23t stock.... what i wanted, is to fine tune my car...
Old 07-25-2006, 02:27 AM   #4747
AngryAsian's Avatar
Ditto - I run 2 hole pistons too...
But i run 2.5mm under the pivot blocks front and rear. In the stock settings, the car rolls too much on a high speed track causing understeer.
The purpose of raising the blocks is to reduce the tendency for the car to roll.
This effectively presses the outside tires harder into the ground resulting in more grip. The tires are being used on their whole contact patch, rather than rolling onto their outside edges when the car starts to roll during cornering.
Antisquat refers to placing the spacers under the blocks, but only on the front blocks (on the rear of the car). I've not run my car with antisquat so i won't comment.
My setup is similar enough to Marcos. that i'd recommend giving it a go.
If you find the rear of the car stepping out then try running a little less droop than the front.
AngryAsian is offline   Reply With Quote
Old 07-25-2006, 04:01 AM   #4748
Nicadrauspro4's Avatar
Does anybody here have pics of the Cyclone equiped with the Pro4's steering column? Some owners have converted their Cyclone's steering using the one of the Pro4. Because it's much sturdy.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 07-25-2006, 04:41 AM   #4749
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Marcos.J - There is no track, or surface type listed?
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 07-25-2006, 04:57 AM   #4750
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Marcos J. - I see that you run with only 2mm of ackerman spacing. I believe this is supposed to make the car steer more aggressively and turn-in harder, is this what you have found? (going from 4mm to 2mm).
Thanks in advance.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 07-25-2006, 05:09 AM   #4751
XrayFK's Avatar
Thanks in advance.
Use Ackerman to keep a consistent steering arc between on and off power. So if your car steers well on power but pushes off power then use less Ackerman. As a rule off thumb, the more grip you have the less Ackerman you can use.
Old 07-25-2006, 05:29 AM   #4752
Super Moderator
Marcos.J's Avatar
Snowy.
my bad , asphalt!
Old 07-25-2006, 11:17 AM   #4753
Super Moderator
Marcos.J's Avatar
Here is a nother set up that you can try!
Old 07-25-2006, 12:19 PM   #4754
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
how about a oneway asphalt setup?
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 07-25-2006, 12:41 PM   #4755
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
What car are you running in Memphis Wes?
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
