Old 07-16-2006, 07:51 PM   #4651
protc3's Avatar
all honesty buddy,i havent got a chance to run on carpet with my cyclone yet.the 2.5 block seems to be good for asphalt racing.this will give you 2.5 degrees of front arm sweep.it seems to give a little more steering and hold the line better.0 degree arm sweep is ideal for carpet.the only problem you will run into is the it will make the car more narrow in the front.you will need to widen the car by shimming the rims about 1-1.5mm per side.run the 4mm shims under the ball studs on the steering rack and dont run front toe out.run it at 0 degrees.i will be able to be a bigger help after august 5th.i will be testing my new cyclone carpet chassis kit.i will post a good set up when i get it figured out.i am going to start with the setup that jagg88 sent me.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-16-2006, 10:35 PM   #4652
AngryAsian's Avatar
Does anyone know of a suitable upgrade for the stock camber link ballstuds?
Do units from other cars fit? I'm sick of snapping mine at the neck...
It's a bit of a heart wrenching moment ... the thought of having to bin a bulkhead because of a snapped screw is terrible!
AngryAsian is offline   Reply With Quote
Old 07-16-2006, 11:23 PM   #4653
Thanks alot Jason. Good luck with the carpet racing on the 5th of August.
jimbobmahua is offline   Reply With Quote
Old 07-17-2006, 06:15 AM   #4654
Ballsie's Avatar
I see this is KO Propo wiring, but is it 12GA, 14GA or 15GA.
What's the difference and advantage / disadvantage of one over the other?
Cheers.
Ballsie is offline   Reply With Quote
Old 07-17-2006, 06:37 AM   #4655
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Cheers.
is 12GA wire the advantage is your speedo can send more current to your motor. but compare to 14GA like QC2 or QC3 you wont feel much unless you are world champ.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 07-17-2006, 07:38 AM   #4656
XrayFK's Avatar
Square makes titanium ball studs specifically for HPI/HB cars. Those are the best you can get.
XrayFK is offline   Reply With Quote
Old 07-17-2006, 08:15 AM   #4657
Victor A's Avatar
Here are some pic's of Andy Moore's Cyclone
Vic
www.RcTouring.EU
Victor A is offline   Reply With Quote
Old 07-17-2006, 08:15 AM   #4658
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Cheers.
Anyone know why some people don't use the carbon fibre plate over the spur gear and just use 4 screws instead? (is there any advantages?)
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 07-17-2006, 08:28 AM   #4659
academygaz's Avatar
Anyone know what this bent piece of lexan over of the ESC is for?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 07-17-2006, 08:32 AM   #4660
Trader Rating: 16 (94%+)
on the original cyclone the carbon plate used to bind on the one-way pulley, they added a lip to the spur mount to stop that happening on the hara/surikarn cars, so the only other reason would be less rotating mass
domo is offline   Reply With Quote
Old 07-17-2006, 08:55 AM   #4661
Skill's Avatar
Anyone know what type of transmitter Andy was using? Is it some sort of KO Propo "Spectrum" Prototype?
Skill is offline   Reply With Quote
Old 07-17-2006, 08:59 AM   #4662
Ballsie's Avatar
Thanks, but I don't understand - what is QC2 or QC3 ? Is is Quantum Competition?
I use the Hara Twister 2.1 speedo
Old 07-17-2006, 09:05 AM   #4663
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
I think its for a fan garry
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 07-17-2006, 09:25 AM   #4664
academygaz's Avatar
Hmm, thats what I was thinking. I can't remember seeing anyone else using a fan on the ESC.
Skill: It was a KO Esprit 3 prototype, theres a thread about it somewhere.
Old 07-17-2006, 09:49 AM   #4665
Ballsie's Avatar
There's some great pics from the Worlds on RC-infos - shame it's in French!
-Worlds MAIN REPORT: http://www.rcinfos.com/2006/2006_07_...legno_race.php
Sub-reports:
-Worlds #1 - results: http://www.rcinfos.com/2006/2006_07_...d_champion.php
-Worlds #2 - Tamiya 415 of Rick Hohwart: http://www.rcinfos.com/2006/2006_07_...rf_hohwart.php
-Worlds #3 - Xray T2 of Mike Dumas: http://www.rcinfos.com/2006/2006_07_...o_t2_dumas.php
-Worlds #4 - Kyosho Stallion of Tony Rheinard: http://www.rcinfos.com/2006/2006_07_...o_rheinard.php
-Worlds #5 - HB Cyclone of Surikarn: http://www.rcinfos.com/2006/2006_07_...e_surikarn.php
-Worlds #6 - Corally of Chris Tosolini: http://www.rcinfos.com/2006/2006_07_...x_tosolini.php
-Worlds #7 - Xray T2 of Viktor Wilck: http://www.rcinfos.com/2006/2006_07_...y_t2_wilck.php
-Worlds #8 - AE Prototype of Craig Drescher: http://www.rcinfos.com/2006/2006_07_...o_drescher.php
-Worlds #9 - Schumacher Mi2 of Teemu Leino: http://www.rcinfos.com/2006/2006_07_..._mi2_leino.php
-Worlds #10 - HB Cyclone of Ronald Völker: http://www.rcinfos.com/2006/2006_07_...one_volker.php
-Worlds #11 - Tamiya 415 of Marc Rheinard: http://www.rcinfos.com/2006/2006_07_...a_rheinard.php
-Worlds #12 - Xray T2 of Paul Lemieux: http://www.rcinfos.com/2006/2006_07_...t2_lemieux.php
-Worlds #13 - Yokomo BD of Masami Hirosaka: http://www.rcinfos.com/2006/2006_07_...omo_masami.php
-Worlds #14 - HB Cyclone of Andy Moore: http://www.rcinfos.com/2006/2006_07_...lone_moore.php
-Worlds #15 - News and technique: http://www.rcinfos.com/2006/2006_07_..._technique.php
-Worlds #16 - Teams and drivres: http://www.rcinfos.com/2006/2006_07_...egno_teams.php
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
