Old 07-13-2006, 05:00 AM   #4636
He's also using a straight right centre bulkhead instead of the usual curved one. Anyone know where to get this????
crangon is offline   Reply With Quote
Old 07-13-2006, 05:15 AM   #4637
XrayFK's Avatar
Originally Posted by Teddy
Did you notice that Hara switch to another speedo?
I think the new one is from Keyence.
Someone know more?
I think that was a final effort to get rid of the glitching he had *cough*futaba*cough*
XrayFK is offline   Reply With Quote
Old 07-13-2006, 05:16 AM   #4638
XrayFK's Avatar
Square makes one, they are almost double the price of the stock one. Champ RC in Japan carries them.
Old 07-13-2006, 06:13 AM   #4639
thanks, mmmmm, maybe stick with the standard one....
Old 07-13-2006, 08:52 AM   #4640
JayL's Avatar
he should of just copied what Paulie was doing..futaba seemed to work ok in an Xray, podium and all....
JayL is offline   Reply With Quote
Old 07-13-2006, 03:29 PM   #4641
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default Set Up Sheets
Anyone know where to get some set up sheets for asphalt, low traction, outdoor w/ rubber tyres? All the ones they have on HB website is for med-high traction...thanks
yyhayyim is offline   Reply With Quote
Old 07-13-2006, 03:34 PM   #4642
rc-zombies's Avatar
start with the med-high set-up and adjust from there..
maybe softer compound tires and inserts.
remove the sway bars
lighter springs and shock oil.
etc.
Old 07-14-2006, 04:33 PM   #4643
tc3 racer sc's Avatar
etc.
has andy post his set up yet anyone know
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 07-15-2006, 05:46 PM   #4644
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Although they are certainly dearer than the stock version, they are much stronger and resist tweaking after a crash....money well spent IMO.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 07-15-2006, 07:52 PM   #4645
AngryAsian's Avatar
I picked one up in HK the other day... time will tell if it resists bending better than the stock one... (Yup.. i bent that )
Does anyone know of a supplier that has the upper deck and front belt in stock??
(BOo HOoo.. I broke my upper deck. The first time i've damaged a major chassis component on an rc.. )
AngryAsian is offline   Reply With Quote
Old 07-15-2006, 08:14 PM   #4646
Try RC Champ in Japan. If they don't have it in stock, its likely that its on its way to them. They are pretty good with filling orders.
Old 07-15-2006, 08:43 PM   #4647
AngryAsian's Avatar
Ta.. thanks....
after 3 wks.. no rc... I am itching to go to the track.. LoL!
Old 07-16-2006, 04:42 PM   #4648
Robertw321's Avatar
R/C Tech Charter Subscriber
Does anyone have a setup for a unprepared concrete parking lot track? It's you typical concrete parking lot with the usual bumps dips and expansion joints with medium to low bite. Tires of choice are TakeOff CS series.
TIA
Bob Williams
Robertw321 is offline   Reply With Quote
Old 07-16-2006, 06:14 PM   #4649
protc3's Avatar
its hard to say for me on that style surface being that i have never run on it but you can try the box stock setup because it is very neutral.the only things i would change from stock are changing to a spool instead of the oneway,locked layshaft pulley and run a 2mm spacer under the ballstuds on the steering rack instead of the 4mm under each stud.this will give the steering back that you would have lost from changing to the spool.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-16-2006, 07:26 PM   #4650
Hi Jason,
What would be the difference in changing the front pivot block to 0 degrees compared to the box set-up 2.5 degree block? What do you lose or gain with either?
Also do you have any recommendations for a spool set-up for a med-high grip carpet track run on foams? A back straight of about 15 or so metres. No tyre additives permitted. 12T limit mod, Standard Cyclone.
Cheers
Anthony
jimbobmahua is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
