Old 07-12-2006, 11:45 AM   #4621
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Originally Posted by cyclone
hi all, ive got the spring set being talked about above but im racing carpet and i really think that i should be using harder springs than the 22.4lbs...
what do you reckomend? is there another hpi set or am i supposed to get another makes? which are best (for hard springs...)
cheers
andy
I take it your running foams?
Hara ran Xray springs on his foam car at last years IIC in vegas.
http://www.peakmotors.com/peak/image..._hara_foam.jpg
Theres a link to a picture of his car,Xray purpules on the front and a hpi spring on the rear.
Hope that helps!
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 07-12-2006, 11:47 AM   #4622
Originally Posted by rc-zombies
I want some too...
but I thought he was using CheckPoint batteries.
is the pic Hara's car? looks like a Keyence speedo in there.
Batterys do look dailed!!
Its Haras car allrite,bottom left of his TD design pit board it has his name.
Maybe the keyence was a last ditch attempt to get rid of his interfearnce?
Old 07-12-2006, 11:50 AM   #4623
ngo8's Avatar
Send a message via ICQ to ngo8
i want some of those hara battaries to
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 07-12-2006, 12:18 PM   #4624
cyclone's Avatar
hi andrewC, yes im running foams, but i want a range, you think i should get an xray set then?
cyclone is offline   Reply With Quote
Old 07-12-2006, 12:28 PM   #4625
hi every one
ive noticed that my v2 shock shafts are doing funny things, when i push the shock rod in it extends smoothly then almost stops for ever such a slight instant then pops out, i think tyhe third groove in the shaft is causing this, i dont think it will be a problem in the car because the shocks wont fully extend, does anyone else have this problem?
Xrayskid is offline   Reply With Quote
Old 07-12-2006, 12:55 PM   #4626
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by Xrayskid
hi every one
You need to add a 2mm shim/spacer in the shock (as per Hara's setup tips) to take out the additional length.
Hope this helps.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 07-12-2006, 01:03 PM   #4627
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
this will fit the cyclone:
#A787 SHOCK CAP 12mm (PURPLE ANODIZED)
will they? i know the material on the top of the cap is thinner on the cylone caps than on those (stock pro4 (non hara) aka old style shocks), but i never checked the lenth.
floodo1 is offline   Reply With Quote
Old 07-12-2006, 01:05 PM   #4628
floodo1's Avatar
Originally Posted by TFR
Where can I get some AHRP batteries?
Just for those killer looking labels!
wow it sure looks like he's living it up with futaba!
i wonder if he misses the days of simplicity with ko rx and twister speedo.
now it seems like he's having major problems. even has a keyence speedo in there? and thats a lot of foil!!
interesting that there is no MM diode with the keyence speedo.
Old 07-12-2006, 01:09 PM   #4629
floodo1's Avatar
Originally Posted by Nexus Racing
Hey floodo1,
I switched over to tamiya-style shock mounting on my old pro4 and cyclone. It worked really well! I used the same parts you mentioned, but...
Instead of using shims, I threaded a plain (non-nylon) 3mm nut onto the shock shaft before threading the shock end on and it worked as a perfect spacer. (As a bonus, I was able to tighten the shock end to the nut and it automatically made all of my shocks the same length!)
Here are a couple of pics of my car with the completed mod:
wow, after looking closer at my shock ends, they have developed a LOT of slop very quickly i think its from taking them on & off
I think im going to use the tamiya balls at the top, for quick shock changing, and go back to hpi screw/ball for the bottom because of slop.
Old 07-12-2006, 01:18 PM   #4630
Nexus Racing's Avatar
I forgot to mention...there is a HD version of the shock end that a buddy of mine used. I'm not sure what the part # is, though. That should solve your problem.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 07-12-2006, 03:24 PM   #4631
I wouldnt get a whole spring set if i was you.I used to own a Xray before i moved to HotBodies.The spring set is very dear and it dosenT come with all the springs,theres loads of diffrent sping set.
I personally purchased the springs speratly when i owned a xray as it was cheaper and i got what i wanted.
Just a word of advice
L8rs
Old 07-12-2006, 07:26 PM   #4632
XrayFK's Avatar
Maybe I should just get some TRF shocks.
XrayFK is offline   Reply With Quote
Old 07-12-2006, 07:32 PM   #4633
floodo1's Avatar
can you find out the part number?
Old 07-13-2006, 01:18 AM   #4634
XrayFK's Avatar
Never mind, figured it out.
Old 07-13-2006, 02:43 AM   #4635
Teddy's Avatar
Did you notice that Hara switch to another speedo?
I think the new one is from Keyence.
Someone know more?
Teddy is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
