Old 07-10-2006, 09:36 PM   #4591
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by domo
john deere green?
No actually......, more like “Todd Hodge” green…..
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 07-10-2006, 11:01 PM   #4592
Damian....I think he is already GREEN with envy
Barger is offline   Reply With Quote
Old 07-11-2006, 03:25 AM   #4593
Send a message via MSN to Grindog001
if they were to relese a Andy Moore version, what do you think they could/would do to improve on the Hara/Surikarn kits?
Grindog001 is offline   Reply With Quote
Old 07-11-2006, 03:57 AM   #4594
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Originally Posted by XrayFK
Waaaait a second, what's up with your car in the first pic?
Yah, check out the chassis in the first pic from Nexus Racing. Who makes that?
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 07-11-2006, 07:35 AM   #4595
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
make it black!
include the rear heatsink plate (the one that replaces the graphite piece)
floodo1 is offline   Reply With Quote
Old 07-11-2006, 08:18 AM   #4596
ooliganRC's Avatar
Send a message via MSN to ooliganRC
release it with the option of either moorespeed shells.
And range of c-hubs of varying degrees and rear hubs of varying degrees....
oh and a X brace for the bulkheads.
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 07-11-2006, 10:31 AM   #4597
Nicadrauspro4's Avatar
...and a thicker upper deck.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 07-11-2006, 11:17 AM   #4598
Nexus Racing's Avatar
Snowy.
I made that when I was running the HB on carpet...completely hand made .
Originally Posted by lawtonlosi
do yall have the part numbers of the needed parts to do that mod?
floodo1 mentioned it...A471, but you will need two of them for the whole car.
XrayFK, The original cyclone shock ends are not even round on the inside, so there isn't a ball that will fit!
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 07-11-2006, 03:18 PM   #4599
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default Atsushi Hara & Andy Moore Body Shell
Does anyone for sure know what shell Atsushi Hara normally uses? I know he used the RI TSX body, and now I have read in forums that he was using a hotbodies stratus version? Others say he was using the Yokomo stratus E type body, like the one Masami Hirsosaka uses. Who knows the truth and nothing but the truth?
yyhayyim is offline   Reply With Quote
Old 07-11-2006, 03:23 PM   #4600
rc-zombies's Avatar
only the best handling bodies that suites the track..
at the worlds it was the Yok. STratus E
at the Roar Nat's it was the Protoform Mazda 6
at the TITC thailand it was the Ride TSX
Old 07-11-2006, 03:31 PM   #4601
dizzy1's Avatar
Hara used a Mazda 6 at the worlds for qualifing and the mains, per Dale Epp, owner of Protoform.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 07-12-2006, 06:38 AM   #4602
yyhayyim's Avatar
Default PRO 4 Shocks VS Cyclone Shocks
I am having trouble w/ the Cyclone shock caps. They keep on getting loose when trying to adjust the ride height. Never had these problems with the PRO 4 shocks and caps. Can I use my PRO 4 shocks on the Cyclone? Are they the same height/legth? Thanks...
Old 07-12-2006, 06:58 AM   #4603
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Yep,you should be ok witht them,Most Cyclone drivers use the Pro Competion shocks fromt he hara Pro 4 anyway,
Just out of intrest have you tried a few drops of oil on the shock collars to loosen them when adjusting them? That will also help if you havent!
L8rs!
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 07-12-2006, 07:00 AM   #4604
ooliganRC's Avatar
in a word ....yes...
problem with cyclone ones is they ae slighty deeper than pro 4.
used a rubber o ring from associated shocks in mine...no problem now
(put it ibside the shock cap above the shock mount)
Old 07-12-2006, 07:19 AM   #4605
XrayFK's Avatar
Are the Pro4 shock caps the same way? Or the Hara versions (competition shocks)
XrayFK is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
