Old 07-05-2006, 06:51 PM   #4516
protc3's Avatar
unfortunately i cant make it.flights were all charter flights and pretty expensive considering i could drive there in about the same time.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-06-2006, 12:05 AM   #4517
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Guy i have some Cyclone parts for sale here is the link http://www.rctech.net/forum/showthre...83#post2483083
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 07-06-2006, 09:29 AM   #4518
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default HELP!!! Center Pulley Prblm
Just built my Cyclone a few days ago. The time came to test it and I used a box to give it throttle and all all 4 tires off the ground. After hitting the throttle, I noticed that only the front tires spin forward, while the rear ones dont move at all. The belt and pulley for the rear tires just dont move. Checked for freedom of movement and its fine- its smooth. Took the spur gear, and manually moved that forward, and only 2 front tires spin forward. THen I took the rear tire and manually moved that forward, and then all 4 tires move forward! What the hell is going on here
yyhayyim is offline   Reply With Quote
Old 07-06-2006, 09:38 AM   #4519
rc-zombies's Avatar
your center one-way and direct pulley are installed incorrectly..swap them to opposite sides and all should be well.
Old 07-06-2006, 09:40 AM   #4520
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
first off
one way pulley on front belt !!
one way pulley rotating in the right direction
when spin up front wheels will carry on spinning when the rears stop when motor stops ,when you come of throttle
if you don`t know about one ways ,learn about them before you build
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 07-06-2006, 10:34 AM   #4521
yyhayyim's Avatar
Default THanks Rc Zombie
Page 12 of my manual has the center shaft pulley with the one way bearing on the other side. I belive its a mistake on their manual. Just inverted it as RC ZOmbie recommended and now I got 4WD again!!! Thank you guys...also, this kit comes with a plastic rear diff outdrives...It will not stand up to the heat of my Novak 4.5R brushless system. Can I use the Pro 4 delrin outdrives on the cyclone, or is there aluminum outdrives for the cyclone? What's the best place to get parts for the Cyclone?
Old 07-06-2006, 11:51 AM   #4522
yyhayyim's Avatar
Default Cyclone Outdrives
Will my PRO 4 delrin outdrives work with the Cyclone? Does the cyclone have delrin outdrives or aluminum? What's the best place to get parts for the Cyclone, as Hotbodiesonline has nothing there...thanks.
Old 07-06-2006, 12:00 PM   #4523
rc-zombies's Avatar
the stock diff outdrives are delrin like the Pro4..just in Black.
Aluminum outdrives are availalbe...they are stock parts on the Hara or Surikarn edition kits...and now available seperately..
speedtech has them listed..but out of stock at the moment.
you'll have to go overseas to get them..
and best place for parts... Speedtech or Stormer.
Old 07-06-2006, 04:13 PM   #4524
Ballsie's Avatar
Hi Guys,
Is there any disadvantage in running a large diode like the Much More 55amp diode over the 35 amp version?
Thanks.
Ballsie is offline   Reply With Quote
Old 07-06-2006, 04:43 PM   #4525
rc-zombies's Avatar
Originally Posted by Ballsie
Hi Guys,
Thanks.
very little advantage...
if you're running low turn mods..the 55amp is recommended
for the stock, 19T the 35amp is all you need..
Old 07-06-2006, 04:47 PM   #4526
protc3's Avatar
hey guys,
i finished my new cyclone hinge pin blocks today that allow me to run the wheelbase as long as about 264mm and the track width at 189.25mm with TRC wraps.this is also with 1.5 degrees of rear toe and 0 front arm sweep.i will be testing it out on carpet very soon.i am just waiting until i can make the 3 hour venture up to the track.i also have a local carpet race here on august 5th.i am very pleased with this carpet conversion so far.in theory it should be an animal.lets see if reality agrees.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-06-2006, 09:08 PM   #4527
jag88's Avatar
Originally Posted by protc3
hey guys,
Jason, will these blocks be part of the chassis kit or an option ?
Thanks.
jag88 is offline   Reply With Quote
Old 07-06-2006, 09:29 PM   #4528
I've lowered the price on my cyclone if anyone is looking for a good deal on one. Click Here
edit - SOLD
dway100 is offline   Reply With Quote
Old 07-07-2006, 04:16 AM   #4529
protc3's Avatar
Thanks.
they are going to come with the kit but also be an option part being that they will work on the stock chassis for widening the track width.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-07-2006, 04:36 AM   #4530
Jason,
Is the carpet car suited for foams or will it be suitable for rubbers on the rug too?
LEE UK is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
