Old 06-29-2006, 09:57 AM   #4471
Ballsie's Avatar
Originally Posted by Xrayskid
does any one know if the following part fits the cyclone?
Tamiya TRF Damper Titanium Coated Piston Rod (2pcs)
Cheers
Edit do piston rods for the Cyclone / Pro 4. Very expensive though at 8 each!
Ballsie is offline   Reply With Quote
Old 06-29-2006, 11:19 AM   #4472
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Do you have any links for sites that show edits offerings for the cyclone?
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 06-29-2006, 11:22 AM   #4473
SpeedTech's Avatar
Originally Posted by rc-zombies
if it's 3mmx28mm...it should fit...
I think the new Ver2 shock shafts are stronger, and also the new shock shaft from Kyosho looks to be 28mm as well
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 06-29-2006, 11:25 AM   #4474
Stew Noble's Avatar
http://www.rc-edit.com/
// S N F //
Stew Noble is offline   Reply With Quote
Old 06-29-2006, 12:09 PM   #4475
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Is there a better fixing for the shocks to the tower ??
as opposed to purple shim ,insert collar, screw
it`s the insert collar that`s pissing me off
why oh why can`t the collar stay in the shock ends instead they fall out as you take the shocks off
top not so bad . but the bottom ones Arggghhhh
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 06-29-2006, 12:49 PM   #4476
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Cheers
i sure that i can fit well because my TA05 and TB EVO 5 are using cyclone titanium coated piston rod as well
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-29-2006, 02:26 PM   #4477
Originally Posted by Stew Noble
Thanks. I think im gonna check out that diffs crew and layshaft.
Maclin | VP-Pro USA
Old 06-29-2006, 03:11 PM   #4478
Ballsie's Avatar
My fixed layshaft is on back order.
Diff screws are very nice. They also offer Ti Inner and Outer hingepins
Old 06-30-2006, 07:12 AM   #4479
right ive been looking at drive shafts and found the v2 ali or the steel versions, wich is best? im taking steel will be stronger but weigh more, and ali lighter but will still bend. any opinions?
Cheers
Xrayskid is offline   Reply With Quote
Old 06-30-2006, 07:49 AM   #4480
Dan415ms's Avatar
Cheers
I run steel v2 shafts on front and alum on back, no probs.
Dan415ms is offline   Reply With Quote
Old 06-30-2006, 08:28 AM   #4481
JimmyMac's Avatar
I would run steel up front unless if maybe you are racing a National or something. I've bent a v2 aluminum one already (tire/nut snagged the edge of the board running a spool). And I've slightly twisted them up front as well. But with steel I have no issues.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 06-30-2006, 11:35 AM   #4482
The titanium drive shafts are very good. www.titaniumracing.com
Ricky
prodriver is offline   Reply With Quote
Old 06-30-2006, 11:38 AM   #4483
MR JOLLY's Avatar
Square racing does real good ones aswell
Old 06-30-2006, 12:56 PM   #4484
Are these the steel ones?
http://www.speedtechrc.com/store/ebp...id=472&id=6094
Maclin | VP-Pro USA
Old 06-30-2006, 12:58 PM   #4485
rc-zombies's Avatar
yes..
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
